    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 34.2k Views 14 Watching
      Mykle1 Project Sponsor Module Developer @Guest
      @Sean said in worldclock - nobody made this, so I did.:
      I like that circled flags
      https://www.shutterstock.com/image-vector/simple-circle-flags-vector-countries-flat-298861670
      https://image.shutterstock.com/z/avopix-199602161.jpg
        A Former User @nobita
        @nobita How about this?
        I cannot find any pretty flag images on the network, so I use flag-icon-css.
        @Mykle1 gave me good resources, but I feel some question.
        Should we store all the flags in modules? Each person needs only a few flags at once. Therefore I try to find some resources approachable on the internet directly, which might be already hosted via CDN or something like. The only one thing I’ve found was flag-icon-css.
        But… The flag is not so pretty as I’ve thought.
        Anyway, I added flags feature, you can upgrade your module now.
        [card:eouia/worldclock]
        Mykle1M N iMAGiCI 3 Replies Last reply Reply Quote 3
          @Sean
          Those look fantastic! Nice work Sean!
          • N Offline
            nobita @Guest
            @Sean Very Nice and Good Module for all
            • iMAGiCI Offline
              iMAGiC @Guest
              @Sean thanks for the module, could you advise how to hide time gap, default is showing, but I can’t hide it when set “false”.
              Choice * Judgment * Values
                A Former User @iMAGiC
                @iMAGiC in your custom css, add this.
                .worldclock .gap {
                display:none;
                iMAGiCI 1 Reply Last reply Reply Quote 0
                • iMAGiCI Offline
                  iMAGiC @Guest
                  @Sean thanks, but I can’t get it work, found alternative. Thank you.
                    @iMAGiC
                    Sorry for my improper instruction. At that time I was not in front of machine, so I just simply guessed,
                     .worldclock .world .caption .gap {
                     display:none;
                    will do.
                    • N Offline
                      nobita @Guest
                      @Sean , How to Change your digital Clock to Analog Clock
                      like as the default module clock (MM2)
                      Configuration options
                      displayType : Possible values: digital, analog, or both
                      analogFace : Possible values: simple for a simple border, none for no face or border,
                      or face-### (where ### is currently a value between 001 and 012, inclusive)
                      Thank so much for your all helps
                        @nobita
                        Unfortunately, worldclock doesn’t support Analog face. Sorry.
                          Arjen_lima
                          Hi There,
                          just starting out with MM and i like the module a lot.
                          one question i have is how to organize the clock’s in row instead of one below the other.
                          thanks
                          Arjen
                            A Former User @Arjen_lima
                            @Arjen_lima
                            Sorry for my English, I cannot catch your question.
                            The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
                            Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
                              Arjen_lima @Guest
                              @Arjen_lima
                              Hey Sean,
                              Its probably my english ;-),
                              now the clocks in the array are all vertically aligned one clock below the next clock.
                              in some of the screen shots they are in a 3x3 grid i was wondering how to get it like that
                              my current lay out
                              the lay out im looking for
                              ? 1 Reply Last reply Reply Quote 1
                                @Arjen_lima
                                Sorry for the confusion. that image was just sample of the different layout configuration. That was not real, it was photoshopped.
                                  Peter
                                  Can somebody help me to change the font size of this module?
                                  I would like to have the time a little smaller; about the same as the size of the citynames.
                                  Thanks.
                                  Peter
                                  • N Offline
                                    ninjabreadman @Peter
                                    @Peter This should work:
                                    .worldclock {
                                      font-size: 73%; /* adjust value as needed */
                                      Peter @ninjabreadman
                                      @ninjabreadman thanks!
                                      It works fine.
                                      Peter
                                        cookblook
                                        very nice module. Is it possible to have the clocks horizontal instead of vertical?
                                          A Former User @cookblook
                                          @cookblook
                                          You can redefine CSS of .worldclockand.worldclock .world to arrange horizontally with flex things of CSS3.
                                            cookblook @Guest
                                            @sean like display: flex;? tried that but it didn’t work
                                            • 2 / 3
