    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 31.3k Views 14 Watching
      A Former User @nobita
      @nobita
      Unfortunately, worldclock doesn’t support Analog face. Sorry.
        Arjen_lima
        Hi There,
        just starting out with MM and i like the module a lot.
        one question i have is how to organize the clock’s in row instead of one below the other.
        thanks
        Arjen
          A Former User @Arjen_lima
          @Arjen_lima
          Sorry for my English, I cannot catch your question.
          The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
          Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
            Arjen_lima @Guest
            @Sean said in worldclock - nobody made this, so I did.:
            @Arjen_lima
            Hey Sean,
            Its probably my english ;-),
            now the clocks in the array are all vertically aligned one clock below the next clock.
            in some of the screen shots they are in a 3x3 grid i was wondering how to get it like that
            my current lay out
            the lay out im looking for
            ? 1 Reply Last reply Reply Quote 1
              @Arjen_lima
              Sorry for the confusion. that image was just sample of the different layout configuration. That was not real, it was photoshopped.
                Peter
                Can somebody help me to change the font size of this module?
                I would like to have the time a little smaller; about the same as the size of the citynames.
                Thanks.
                Peter
                • N Offline
                  ninjabreadman @Peter
                  @Peter This should work:
                  .worldclock {
                    font-size: 73%; /* adjust value as needed */
                    Peter @ninjabreadman
                    @ninjabreadman thanks!
                    It works fine.
                    Peter
                      cookblook
                      very nice module. Is it possible to have the clocks horizontal instead of vertical?
                        A Former User @cookblook
                        @cookblook
                        You can redefine CSS of .worldclockand.worldclock .world to arrange horizontally with flex things of CSS3.
                        • 3 / 5
