    Electron CPU usage
    247 Posts 46 Posters 668.8k Views 42 Watching
    • W
      wtidwell @SashMare
      @SashMare @Mykle1 my
      I also downgraded electron to 1.4.15 and I’m seeing dramatically improved performance!
      D Mykle1M 2 Replies Last reply
        djsunrise19 @wtidwell
        @wtidwell said in Electron CPU usage:
        Do you have some CPU load Screenshots? As I read, around 55% is to high too.
        W 1 Reply Last reply
        • W
          wtidwell @djsunrise19
          @djsunrise19
          Not on hand but I’m seeing in the mid 20’s with newsfeed animations
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @wtidwell
            Well, that’s good news! :^)
            • Mykle1M
              You guys are both running MM 2.1.2? There has been some mention that this problem arose after the upgrade. My Pi3 B mirror is still running MM 2.1.0. :-/
              Just a thought.
              M 1 Reply Last reply
                mibafz00 @Mykle1
                @Mykle1
                Today, I tried the following:
                MM 2.1.2 + Electron 1.7.5 --> CPU 100% during transitions
                MM 2.1.2 + Electron 1.4.15 --> problem still there, CPU 100% during transitions
                MM 2.1.0 + Electron 1.7.5 --> problem still there, CPU 100% during transitions
                MM 2.1.0 + Electron 1.4.15 --> problem (probably) gone, CPU 40% during transitions
                So i guess you have to downgrade both, MM and electron…!?
                Mykle1M 1 Reply Last reply
                Reply Quote 2
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @mibafz00
                  @mibafz00 said in Electron CPU usage:
                  I’m curious. What is the CPU load at rest, when no transitions are executing?
                  In any case, that’s a good amount of testing on your part, and hopefully it will lead to a final diagnosis of the problem.
                    djsunrise19
                    Today, I tried a few things, too. Perhaps my results could be helpful for us. Sorry, this will be a long post ;). I have following the devices:
                    • Raspberry 3 Model B - my standard mirror device
                    • Asus Tinker Board
                    • odroid C2 (ARM64)
                    Software Versions MM:
                    • MM v2.1.2 on all devices
                    Electron Versions:
                    • Raspberry 3 Model B (v1.6.11)
                    • Asus Tinker Board (v1.4.15) but v1.6.11 works the same
                    • odroid C2 (ARM64) (v.1.8.0 - because of the x64; I uninstalled spectron, because there is no x64 support)
                    Configs:
                    • Standard (Calendar, Compliments, Newsfeed, Clock)
                    • MyConfig (Calendar, Compliments, Newsfeed, Clock, Todoist, Sonos, Netatmo, WheaterUnderground, Stocks, Reiseauskunft, Strava); here, cpu usage is a little bit higher, but the behaviour is the same.
                    The 100% usage topic seems to be a electron problem and I think it can be solved with some downgrades of MM2 and electron. v.1.7.5 seems to be bad. Whatever, here is what I found out:
                    1. nmon with the ATB (v1.7.5 electron here) and default config:
                      CPU usage while transitions is very high. Lagging!
                    2. nmon with the ATB (v1.4.15 electron here) and default config:
                      CPU usage is better but, to be honest, way to high for transitions (cpu peaks). And still some small lags.
                    3. nmon with the odroid and default config:
                      The best result. but still peaks while the transitions. Some lags here, too.
                    So, here is my actual config:
                    4) nmon with the Raspberry 3 Model B and MyConfig:
                    Same here, still lags.
                    The last thing I tried was very interesting. I opened my chromium on the ATB and put the webadress from my Raspberry 3 Model B device in it. So I openend that Rapsberry 3 Model B MM2 on my ATB. And that happens:
                    Absolutely smooth, no peaks at all.
                    BTW: My Raspberry 3 Model didn’t have any more cpu usage while that process.
                    Can anybody tell us, WHY?
                    ? 1 Reply Last reply
                      A Former User @djsunrise19
                      @djsunrise19
                      As I see, rendering engine of electron seems to be the reason of whole of thing. Electron has its own v8 and renderer. I doubt it goes worse on some late version. I don’t know why, but there is few things we could do.
                      Report this to electron, wait a patch. Or downgrade or… turn off the animation.
                        djsunrise19 @Guest
                        @Sean said in Electron CPU usage:
                        @djsunrise19
                        Seems logical. But I have to mention, that there is no MMv2 and electron version number combination that works without those peaks and small lags. The smoothest way ist the browser directly (like in MMv1 - everything was fine there).
                        So the question is: Anyone here who doesn’t have those peaks and lags while the transitions with MMv2 and electron?
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @djsunrise19
                          @djsunrise19 said in Electron CPU usage:
                          This topic is only 17 days old, yet it has 5.0k views already. So, obviously there is a lot of interest. My answer likely was lost somewhere above, so:
                          I do NOT have those peaks and lags
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Guest
                            With all due respect, I have to disagree. New versions can break existing installations in any software, not just MM. It’s the very reason for many patches. However, we don’t know the reason for this issue, and it may well be that electron isn’t the cause, but some users have had a small measure of improvement with earlier versions.
                            • L
                              loctruong96 @TiemenMoesker
                              @TiemenMoesker HOLY MOLLY, I am having this exact problem you guys are having. I double checked my hardware and revision. which are
                              hardware =BCM2835
                              Revision= a02082
                              and I DO have this problem, it seems nothing you guys tried work except downgrade , so I’m going to ask arrow to send me a replacement since i actually ordered BCM2837 not BCM2835. Let’s hope it work out! (mean while I will try the downgrade option, seemed to improve performance drastically for others)
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @loctruong96
                                @loctruong96 said in Electron CPU usage:
                                Please keep us posted
                                • L
                                  loctruong96
                                  OK, I can here by confirm that using MM 2.1.0 + Electron 1.4.15 improved performance massively. Each new transition now only uses 10-13% of CPU power (and very, very smooth). Even better than earlier report of 40%. For the specs of my pi 3 b
                                  hardware = BCM2835
                                  Revision = a02082
                                  micro sd card - 16gb - class 4 (that’s right, only 4)
                                  mouse + keyboard currently plugged in - no lag
                                  OS = RASPBIAN STRETCH WITH DESKTOP
                                  Thank you so much @Mykle1 for sharing your finding. Otherwise, I would be still trying to narrow down a potential work around.
                                  For those who not sure how to do this:
                                  1. Create a fresh install of RASPBIAN STRETCH WITH DESKTOP, connect to wifi, then run sudo apt-get update.
                                  2. sudo apt-get install npm
                                  3. sudo npm install electron@1.4.15 -g
                                  4. WAIT PATIENTLY FOR ELECTRON TO LOAD IN THE BACKGROUND
                                  5. a new line appear indicate electron has finished installing
                                  6. Go to your download folder, exact Magic Mirror 2.1.0
                                  7. Go to the newly exacted forlder, open another folder named config
                                  8. Change the file name Config.js.example to Config.js inside the config folder
                                  9. open terminal , cd Download/, cd MagicMirror-2.1.0, (OR whatever your location for the Magic Mirror 2.1.0 package is), npm install && npm start
                                    9.5 If encounter error “404”, try “npm install npm@latest -g” (NOTE: some users experienced issues since they do not have the latest npm as global variable) @Reotch2 @EventHorizon
                                  10. DONE!
                                  Hopefully I will be able to return my pi 3 for a better hardware version to use with the latest Magic Mirror package but here is an acceptable work around for the time being.
                                  Mykle1M R 2 Replies Last reply
                                  Reply Quote 5
                                  • Mykle1M
                                    You are most welcome. :^)
                                    I would like to give credit to everyone that is participating in this topic. By putting our heads together we’ve eliminated some possibilities but we haven’t pinpointed the problem, yet. We have narrowed it down a bit, though, and this workaround is helping some people. I’m glad you’re one of them.
                                    • E
                                      EventHorizon
                                      Just a quick post in an attempt to re-create the above steps. I get to the part where I have to type “npm install && npm start” and I get an error 404 ‘Not Found’. ‘types/node’ is not in the npm registry. ‘It was specified as a dependency of ‘electron’’
                                      Any idea what I’m doing wrong?
                                      Thanks.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @EventHorizon
                                        @EventHorizon it should be @types/node
                                        E 1 Reply Last reply
                                        • E
                                          EventHorizon @strawberry 3.141
                                          @strawberry-3.141 thank you for the quick reply. Just to confirm: where am I entering @types/node. Sorry for being a noob at this. Thanks for your help!
                                          EDIT: I got the node/type to work by updating using sudo npm install npm@latest -g
                                          Now when I run sudo npm install in the magic mirror folder I get an error code LIFECYCLE. errno 1. “electron@1.7.6” postinstall ‘node install.js’.
                                          ‘failed at the electron@1.7.6 postinstall script’.
                                          Any ideas?
                                          EDIT2: used sudo npm install -g electron --unsafe-perm=true.
                                          This seemed to work. I will monitor performance and let you all know.
                                          EDIT3:
                                          Been monitoring it for an hour or so now. CPU temp has not gone over 50. While before it was around a constant 60 - 65.
                                          Compliments and Newsfeed animations are SUPER SMOOTH.
                                          I can confirm that using MM 2.1.0 with Electron 1.4.15 has insanely improved performance! Thanks to everyone in this thread and to @Mykle1 for pointing this thread out for me.
                                          I just have ONE final question guys. I used my custom.css file from my newer build and all was fine after I removed the ‘everyday’ segment of the code from the compliments module. HOWEVER…I notice in the background (If i tab to terminal) This message pops up:
                                          “Fatal: not a git repository (or any of the parent directories): .git”
                                          However, it does not seem to affect the mirror? Or not in any way I can see? Is there any way I can pinpoint how this message is being generated? Like I said, it does not appear to affect any of my modules.
                                          Any help would be greatly appreciated.
                                          Cheers all!
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @EventHorizon
                                            @EventHorizon said in Electron CPU usage:
                                            If you read this entire thread then you know that I’ve been at this for three weeks. It started as a question from a single user and grew quickly and substantially. 148 posts and 6.0k views later showed there was/is an issue affecting many users, yourself included. I’m glad this workaround has helped you. Enjoy!
                                            I get these, too, when I do a manual installation of a module, or the MM software itself. What type of installation did you do?
                                            In any event, it does not affect the operation of the MM software. Perhaps someone will give us a more detailed description of why it appears.
                                            • 12
                                            • 13
                                            • 7 / 13
