    Electron CPU usage
    247 Posts 46 Posters 662.0k Views 42 Watching
    • Mykle1M
      Some mention here of high CPU usage. Maybe electron IS the culprit
      https://github.com/electron/electron/releases/
      electron v1.7.6 beta
      @electron-bot electron-bot released this 24 days ago · 233 commits to master since this release
      Bug Fixes
      Fixed query string parsing in PDF Viewer #10008
      Fixed crash that occurred when loading URL in detached WebContents #9819
      Fixed issues around update permissions and non-admin users #10071
      Fixed chrome storage access scope to be shared across domains #9951
      Fixed content scripts matches #10075
      Fixed bug that returned an object instead of an empty string when reading from an empty asar file with ‘utf8’ option #10160
      Prevented async tasks from crashing after the Node environment is destroyed #10099
      Linux
      Fixed issue where opening menu would cause high CPU usage on certain Linux distributions #10070
        djsunrise19
        Input from my side: I checked the issues with electron 1.8 beta. Same problems.
          roramirez Core Contributors @pedroken
          @pedroken said in Electron CPU usage:
          I’ll try to use @Mykle1 's version of electron. I`ll google it (how to). Never did it.
          Well, you let we know if with that version of Electron is fixed the CPU usage. You can modified by hand the package.json to say to npm what version to install of Electron.
            djsunrise19
            My two cents again ;): My electron pakackage.json version is v.1.6.10. I made a downgrade to v1.4.15. Code says “invalid”. But the installation seems to work? Do you guys know, where I can check the installed electron version?
            No effect. 55% CPU and very sluggish (256MB GPU Memory):
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @djsunrise19
              @djsunrise19 said in Electron CPU usage:
              You can see the installed version in this file MagicMirror/node_modules/electron/dist/version
              D 1 Reply Last reply
                djsunrise19 @Mykle1
                @Mykle1 Thanks. Yes, v1.4.15.
                • Mykle1M
                  I just had a thought (miracle). What version of MM is everyone using?
                  My Pi3 B mirror is running MM version 2.1.0. I’ve had no reason to update it. It’s rock solid
                    djsunrise19 @Mykle1
                    @Mykle1 said in Electron CPU usage:
                    I had this problems since the new MM2 Version. Very long so. But my version is the newest one. 2.1.2 I think.
                    • Mykle1M
                      uh oh! So you DIDN’T have this problem before the new version?
                        SashMare
                        Hi.
                        I made a downgrade Electron from v1.7.15 to v1.4.15.
                        CPU load up to 320% is gone.
                        Hardware: BCM2835
                        Revision: a22082
                        MagicMirror: 2.1.2
                        W 1 Reply Last reply
                        • W
                          wtidwell @SashMare
                          @SashMare @Mykle1 my
                          I also downgraded electron to 1.4.15 and I’m seeing dramatically improved performance!
                          D Mykle1M 2 Replies Last reply
                            djsunrise19 @wtidwell
                            @wtidwell said in Electron CPU usage:
                            Do you have some CPU load Screenshots? As I read, around 55% is to high too.
                            • W
                              wtidwell @djsunrise19
                              @djsunrise19
                              Not on hand but I’m seeing in the mid 20’s with newsfeed animations
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @wtidwell
                                Well, that’s good news! :^)
                                • Mykle1M
                                  You guys are both running MM 2.1.2? There has been some mention that this problem arose after the upgrade. My Pi3 B mirror is still running MM 2.1.0. :-/
                                  Just a thought.
                                    mibafz00 @Mykle1
                                    @Mykle1
                                    Today, I tried the following:
                                    MM 2.1.2 + Electron 1.7.5 --> CPU 100% during transitions
                                    MM 2.1.2 + Electron 1.4.15 --> problem still there, CPU 100% during transitions
                                    MM 2.1.0 + Electron 1.7.5 --> problem still there, CPU 100% during transitions
                                    MM 2.1.0 + Electron 1.4.15 --> problem (probably) gone, CPU 40% during transitions
                                    So i guess you have to downgrade both, MM and electron…!?
                                    Reply Quote 2
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @mibafz00
                                      @mibafz00 said in Electron CPU usage:
                                      I’m curious. What is the CPU load at rest, when no transitions are executing?
                                      In any case, that’s a good amount of testing on your part, and hopefully it will lead to a final diagnosis of the problem.
                                        djsunrise19
                                        Today, I tried a few things, too. Perhaps my results could be helpful for us. Sorry, this will be a long post ;). I have following the devices:
                                        • Raspberry 3 Model B - my standard mirror device
                                        • Asus Tinker Board
                                        • odroid C2 (ARM64)
                                        Software Versions MM:
                                        • MM v2.1.2 on all devices
                                        Electron Versions:
                                        • Raspberry 3 Model B (v1.6.11)
                                        • Asus Tinker Board (v1.4.15) but v1.6.11 works the same
                                        • odroid C2 (ARM64) (v.1.8.0 - because of the x64; I uninstalled spectron, because there is no x64 support)
                                        Configs:
                                        • Standard (Calendar, Compliments, Newsfeed, Clock)
                                        • MyConfig (Calendar, Compliments, Newsfeed, Clock, Todoist, Sonos, Netatmo, WheaterUnderground, Stocks, Reiseauskunft, Strava); here, cpu usage is a little bit higher, but the behaviour is the same.
                                        The 100% usage topic seems to be a electron problem and I think it can be solved with some downgrades of MM2 and electron. v.1.7.5 seems to be bad. Whatever, here is what I found out:
                                        1. nmon with the ATB (v1.7.5 electron here) and default config:
                                          CPU usage while transitions is very high. Lagging!
                                        2. nmon with the ATB (v1.4.15 electron here) and default config:
                                          CPU usage is better but, to be honest, way to high for transitions (cpu peaks). And still some small lags.
                                        3. nmon with the odroid and default config:
                                          The best result. but still peaks while the transitions. Some lags here, too.
                                        So, here is my actual config:
                                        4) nmon with the Raspberry 3 Model B and MyConfig:
                                        Same here, still lags.
                                        The last thing I tried was very interesting. I opened my chromium on the ATB and put the webadress from my Raspberry 3 Model B device in it. So I openend that Rapsberry 3 Model B MM2 on my ATB. And that happens:
                                        Absolutely smooth, no peaks at all.
                                        BTW: My Raspberry 3 Model didn’t have any more cpu usage while that process.
                                        Can anybody tell us, WHY?
                                        ? 1 Reply Last reply
                                          A Former User @djsunrise19
                                          @djsunrise19
                                          As I see, rendering engine of electron seems to be the reason of whole of thing. Electron has its own v8 and renderer. I doubt it goes worse on some late version. I don’t know why, but there is few things we could do.
                                          Report this to electron, wait a patch. Or downgrade or… turn off the animation.
                                            djsunrise19 @Guest
                                            @Sean said in Electron CPU usage:
                                            @djsunrise19
                                            Seems logical. But I have to mention, that there is no MMv2 and electron version number combination that works without those peaks and small lags. The smoothest way ist the browser directly (like in MMv1 - everything was fine there).
                                            So the question is: Anyone here who doesn’t have those peaks and lags while the transitions with MMv2 and electron?
                                            • 12
                                            • 13
                                            • 7 / 13
