    Electron CPU usage
    247 Posts 46 Posters 668.3k Views 42 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @pedroken
      @pedroken said in Electron CPU usage:
      PS: Great initiative, @Mykle1 !
      I’m just trying to get to the root of this problem. I may never figure it out but I will certainly try.
      Nothing ventured, nothing gained.
        roramirez Core Contributors @pedroken
        @pedroken I think this can because the Electron version. Can you tell us what version is for two case.
        You can see into the file node_modules/electron/dist/version
        Mykle1M P 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @roramirez
          @roramirez said in Electron CPU usage:
          Thanks for getting involved here. Just for reference purposes, my Electron version on my Pi 3 B is v1.4.15
          W 1 Reply Last reply
          • W
            wtidwell @Mykle1
            @Mykle1
            Sorry for the radio silence, it’s been busy lately.
            I can see what electron version I’m running tomorrow night, and I’ll try and change it to the same version you seem to be getting good performance on and report back.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @wtidwell
              @wtidwell said in Electron CPU usage:
              No worries, mate. Now that @roramirez is looking at this we may find the answer sooner than later.
                pedroken @roramirez
                @roramirez , the version in the high CPU scenario is v1.7.5. The animations are sluggish, even with only the default modules.
                The version of the lower CPU consumption but strange memory leak is v1.6.11.
                Thanks!
                I’ll try to use @Mykle1 's version of electron. I`ll google it (how to). Never did it.
                M R 2 Replies Last reply
                  mibafz00 @pedroken
                  @pedroken
                  I also have v1.7.5 and I do have the problem.
                  Didn’t find out how to downgrade so I’ll waiting for your results :-)
                  • W
                    wtidwell @mibafz00
                    @mibafz00
                    Forgive me if this is dumb, but couldn’t you just delete the electron folder and reinstall a specific version with
                    Npm install electron@version?
                    • Mykle1M
                      Some mention here of high CPU usage. Maybe electron IS the culprit
                      https://github.com/electron/electron/releases/
                      electron v1.7.6 beta
                      @electron-bot electron-bot released this 24 days ago · 233 commits to master since this release
                      Bug Fixes
                      Fixed query string parsing in PDF Viewer #10008
                      Fixed crash that occurred when loading URL in detached WebContents #9819
                      Fixed issues around update permissions and non-admin users #10071
                      Fixed chrome storage access scope to be shared across domains #9951
                      Fixed content scripts matches #10075
                      Fixed bug that returned an object instead of an empty string when reading from an empty asar file with ‘utf8’ option #10160
                      Prevented async tasks from crashing after the Node environment is destroyed #10099
                      Linux
                      Fixed issue where opening menu would cause high CPU usage on certain Linux distributions #10070
                        djsunrise19
                        Input from my side: I checked the issues with electron 1.8 beta. Same problems.
                          Well, you let we know if with that version of Electron is fixed the CPU usage. You can modified by hand the package.json to say to npm what version to install of Electron.
                            djsunrise19
                            My two cents again ;): My electron pakackage.json version is v.1.6.10. I made a downgrade to v1.4.15. Code says “invalid”. But the installation seems to work? Do you guys know, where I can check the installed electron version?
                            No effect. 55% CPU and very sluggish (256MB GPU Memory):
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @djsunrise19
                              @djsunrise19 said in Electron CPU usage:
                              You can see the installed version in this file MagicMirror/node_modules/electron/dist/version
                              D 1 Reply Last reply
                                djsunrise19 @Mykle1
                                @Mykle1 Thanks. Yes, v1.4.15.
                                • Mykle1M
                                  I just had a thought (miracle). What version of MM is everyone using?
                                  My Pi3 B mirror is running MM version 2.1.0. I’ve had no reason to update it. It’s rock solid
                                    djsunrise19 @Mykle1
                                    @Mykle1 said in Electron CPU usage:
                                    I had this problems since the new MM2 Version. Very long so. But my version is the newest one. 2.1.2 I think.
                                    • Mykle1M
                                      uh oh! So you DIDN’T have this problem before the new version?
                                        SashMare
                                        Hi.
                                        I made a downgrade Electron from v1.7.15 to v1.4.15.
                                        CPU load up to 320% is gone.
                                        Hardware: BCM2835
                                        Revision: a22082
                                        MagicMirror: 2.1.2
                                        • W
                                          wtidwell @SashMare
                                          @SashMare @Mykle1 my
                                          I also downgraded electron to 1.4.15 and I’m seeing dramatically improved performance!
                                          D Mykle1M 2 Replies Last reply
                                            djsunrise19 @wtidwell
                                            Do you have some CPU load Screenshots? As I read, around 55% is to high too.
                                            • 12
                                            • 13
                                            • 7 / 13
