    Electron CPU usage
    247 Posts 46 Posters 668.8k Views 42 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @djsunrise19
      @djsunrise19 said in Electron CPU usage:
      about 50-60%
      That is even high, in my opinion, based on my results
      • bheplerB
        bhepler Module Developer
        For what it’s worth:
        Hardware: BCM2835
        Revision: a02082
        And I do not have the problem.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @bhepler
          @bhepler said in Electron CPU usage:
          Hardware: BCM2835
          Revision: a02082
          It definitely helps. I think we can now eliminate the possibility that the difference in hardware has anything to do with this issue.
          Thanks!
          D 1 Reply Last reply
            djsunrise19 @Mykle1
            @Mykle1 Yes, you’re right. Yesterday I installed the new raspbian stretch and all MM tools manually, uninstalled electron and installed the @beta (1.8.). I wanted to give that a try. But still the same.
            As you can see, the problem is there , less or more, over months (with that 50-70% cpu usage). With 2-3 animations at the same time my raspi struggles (raspi2 and raspi3). But a few days ago, there were an github update. Since that update my mirror is unusable. Why?
            git pull && npm install
            says, that there was a change in the readme file only. But it doesn’t seem so.
            D Mykle1M 2 Replies Last reply
              djsunrise19 @djsunrise19
              • Mykle1M
                Since you are addressing me directly, I will answer, directly and plainly. I don’t know why your mirror is now unusable. I joined this topic because I was/am interested in determining why some people have this problem and others don’t. We have eliminated some possibilities but not all. I can sympathize with you, having struggled with problems of my own. There only seems to be a handful of people experiencing this problem. I am not one of them but I am trying to determine the cause using what little knowledge I have.
                  djsunrise19 @Mykle1
                  @Mykle1 I’m sorry. There is nothing directly to you. I only try to write as much as I find out in that situation to know as much as we can. I’m very thankful that you’re trying to help (and didn’t have our transition problem).
                  • Mykle1M
                    No worries at all my friend. We’'ll just keep trying and maybe others will get involved and help us figure this out!
                    Peace!
                      mibafz00
                      I’m joing the discussion because I’ve exactly the same problem.
                      Complete new RPi3 + clean installation but CPU load up to 320%.
                      Hardware: BCM2835
                      Revision: a02082
                      Micro SD: SanDisk Ultra 16Gb
                      At the moment I can not bring any new hints but you’re not alone ;-)
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @mibafz00
                        @mibafz00 said in Electron CPU usage:
                        The more people that share their information, the better able to diagnose the cause. So, thank you for your input.
                        Wait!
                        I have another idea. I will assume all risks.
                        I will buy one of the troubled Pi’s from someone in this topic. It has to be a:
                        • Pi 3 B
                        • Hardware: BCM2835
                        • Revision: a02082
                        • SD card, 8GB minimum
                        • Power supply
                        That’s right. I will pay you a fair price before you even ship it to me. I’m thinking PayPal. You’ll be paid with no risk to you at all.
                        So, if you are completely frustrated and you’ve had it with your current Pi (described above), sell it to me.
                        Does $25 US Dollars sound fair? I am buying something that has a problem, after all.
                        Who knows, I just might solve the CPU usage issue!
                        Why are you doing this, Mykle?
                        Because I like challenges and I like projects. I very well may wind up with a $25 brick, but the enjoyment I get from tinkering and troubleshooting is worth the cost to me, and you get something back. Just don’t send me an actual brick after I pay you. :^)
                        Anyone interested?
                        • Message me or post something here.
                          pedroken
                          Guys, same problem here.
                          Hardware : BCM2835
                          Revision : a22082
                          I just realized something. I’ve installed the MM in a clean Jessie. Results were:
                          I have an old backup from my first attempt with the MM, and the results (with same few modules) were:
                          But after 3 hours, look what happened: 0_1504376123617_Screen Shot 2017-09-02 at 01.35.48.png
                          A severe memory leakage. I tried with only the default modules, same thing happened. After sometime, the MM crashed. On screen log was showing free list.h:118 Memory corruption chromium.
                          I`m sure that the version of MM is different from one and another. Someone can tell me how can I see this? Thanks!
                          PS: Great initiative, @Mykle1 !
                          Mykle1M R 2 Replies Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @pedroken
                            @pedroken said in Electron CPU usage:
                            I’m just trying to get to the root of this problem. I may never figure it out but I will certainly try.
                            Nothing ventured, nothing gained.
                              roramirez Core Contributors @pedroken
                              @pedroken I think this can because the Electron version. Can you tell us what version is for two case.
                              You can see into the file node_modules/electron/dist/version
                              Mykle1M P 2 Replies Last reply
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @roramirez
                                @roramirez said in Electron CPU usage:
                                Thanks for getting involved here. Just for reference purposes, my Electron version on my Pi 3 B is v1.4.15
                                W 1 Reply Last reply
                                • W
                                  wtidwell @Mykle1
                                  @Mykle1
                                  Sorry for the radio silence, it’s been busy lately.
                                  I can see what electron version I’m running tomorrow night, and I’ll try and change it to the same version you seem to be getting good performance on and report back.
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @wtidwell
                                    @wtidwell said in Electron CPU usage:
                                    No worries, mate. Now that @roramirez is looking at this we may find the answer sooner than later.
                                      pedroken @roramirez
                                      @roramirez , the version in the high CPU scenario is v1.7.5. The animations are sluggish, even with only the default modules.
                                      The version of the lower CPU consumption but strange memory leak is v1.6.11.
                                      Thanks!
                                      I’ll try to use @Mykle1 's version of electron. I`ll google it (how to). Never did it.
                                        mibafz00 @pedroken
                                        @pedroken
                                        I also have v1.7.5 and I do have the problem.
                                        Didn’t find out how to downgrade so I’ll waiting for your results :-)
                                        • W
                                          wtidwell @mibafz00
                                          @mibafz00
                                          Forgive me if this is dumb, but couldn’t you just delete the electron folder and reinstall a specific version with
                                          Npm install electron@version?
                                          • Mykle1M
                                            Some mention here of high CPU usage. Maybe electron IS the culprit
                                            https://github.com/electron/electron/releases/
                                            electron v1.7.6 beta
                                            @electron-bot electron-bot released this 24 days ago · 233 commits to master since this release
                                            Bug Fixes
                                            Fixed query string parsing in PDF Viewer #10008
                                            Fixed crash that occurred when loading URL in detached WebContents #9819
                                            Fixed issues around update permissions and non-admin users #10071
                                            Fixed chrome storage access scope to be shared across domains #9951
                                            Fixed content scripts matches #10075
                                            Fixed bug that returned an object instead of an empty string when reading from an empty asar file with ‘utf8’ option #10160
                                            Prevented async tasks from crashing after the Node environment is destroyed #10099
                                            Linux
                                            Fixed issue where opening menu would cause high CPU usage on certain Linux distributions #10070
                                            • 12
                                            • 13
                                            • 6 / 13
