    Electron CPU usage
    247 Posts 46 Posters 647.1k Views 42 Watching
      djsunrise19 @TiemenMoesker
      @TiemenMoesker said in Electron CPU usage:
      @djsunrise19
      So the CPU usage doens’t spike with animations?
      Not so high like my first one (100% permanently), about 50-60%. Here is a picture from my ATB, that arrives today. Naked installations, standard config / css / modules. 75% peak. Bad.
      T Mykle1M 3 Replies Last reply Reply Quote 0
      • T Offline
        TiemenMoesker @djsunrise19
        @djsunrise19
        Sorry to hear that man. I can get mine replaced for free, but I think I get a Pi with the same hardware
          Mykle1 Project Sponsor Module Developer @djsunrise19
          @djsunrise19 said in Electron CPU usage:
          Both of them are the BCM2835 Hardware-Versions. First BCM2835 has the problem, the other BCM2835 hasn’t. Wow… :-D
          Well, there goes my theory, if the installations are exactly alike.
            Oh hell no. This issue gets more mysterious by the day!
              about 50-60%
              That is even high, in my opinion, based on my results
                bhepler Module Developer
                For what it’s worth:
                Hardware: BCM2835
                Revision: a02082
                And I do not have the problem.
                  Mykle1 Project Sponsor Module Developer @bhepler
                  @bhepler said in Electron CPU usage:
                  Hardware: BCM2835
                  Revision: a02082
                  It definitely helps. I think we can now eliminate the possibility that the difference in hardware has anything to do with this issue.
                  Thanks!
                    djsunrise19 @Mykle1
                    @Mykle1 Yes, you’re right. Yesterday I installed the new raspbian stretch and all MM tools manually, uninstalled electron and installed the @beta (1.8.). I wanted to give that a try. But still the same.
                    As you can see, the problem is there , less or more, over months (with that 50-70% cpu usage). With 2-3 animations at the same time my raspi struggles (raspi2 and raspi3). But a few days ago, there were an github update. Since that update my mirror is unusable. Why?
                    git pull && npm install
                    says, that there was a change in the readme file only. But it doesn’t seem so.
                    D Mykle1M 2 Replies Last reply Reply Quote 0
                      djsunrise19 @djsunrise19
                        Since you are addressing me directly, I will answer, directly and plainly. I don’t know why your mirror is now unusable. I joined this topic because I was/am interested in determining why some people have this problem and others don’t. We have eliminated some possibilities but not all. I can sympathize with you, having struggled with problems of my own. There only seems to be a handful of people experiencing this problem. I am not one of them but I am trying to determine the cause using what little knowledge I have.
                          djsunrise19 @Mykle1
                          @Mykle1 I’m sorry. There is nothing directly to you. I only try to write as much as I find out in that situation to know as much as we can. I’m very thankful that you’re trying to help (and didn’t have our transition problem).
                            No worries at all my friend. We’'ll just keep trying and maybe others will get involved and help us figure this out!
                            Peace!
                              mibafz00
                              I’m joing the discussion because I’ve exactly the same problem.
                              Complete new RPi3 + clean installation but CPU load up to 320%.
                              Hardware: BCM2835
                              Revision: a02082
                              Micro SD: SanDisk Ultra 16Gb
                              At the moment I can not bring any new hints but you’re not alone ;-)
                                Mykle1 Project Sponsor Module Developer @mibafz00
                                @mibafz00 said in Electron CPU usage:
                                The more people that share their information, the better able to diagnose the cause. So, thank you for your input.
                                Wait!
                                I have another idea. I will assume all risks.
                                I will buy one of the troubled Pi’s from someone in this topic. It has to be a:
                                • Pi 3 B
                                • Hardware: BCM2835
                                • Revision: a02082
                                • SD card, 8GB minimum
                                • Power supply
                                That’s right. I will pay you a fair price before you even ship it to me. I’m thinking PayPal. You’ll be paid with no risk to you at all.
                                So, if you are completely frustrated and you’ve had it with your current Pi (described above), sell it to me.
                                Does $25 US Dollars sound fair? I am buying something that has a problem, after all.
                                Who knows, I just might solve the CPU usage issue!
                                Why are you doing this, Mykle?
                                Because I like challenges and I like projects. I very well may wind up with a $25 brick, but the enjoyment I get from tinkering and troubleshooting is worth the cost to me, and you get something back. Just don’t send me an actual brick after I pay you. :^)
                                Anyone interested?
                                • Message me or post something here.
                                  pedroken
                                  Guys, same problem here.
                                  Hardware : BCM2835
                                  Revision : a22082
                                  I just realized something. I’ve installed the MM in a clean Jessie. Results were:
                                  I have an old backup from my first attempt with the MM, and the results (with same few modules) were:
                                  But after 3 hours, look what happened: 0_1504376123617_Screen Shot 2017-09-02 at 01.35.48.png
                                  A severe memory leakage. I tried with only the default modules, same thing happened. After sometime, the MM crashed. On screen log was showing free list.h:118 Memory corruption chromium.
                                  I`m sure that the version of MM is different from one and another. Someone can tell me how can I see this? Thanks!
                                  PS: Great initiative, @Mykle1 !
                                  Mykle1M R 2 Replies Last reply Reply Quote 1
                                    Mykle1 Project Sponsor Module Developer @pedroken
                                    @pedroken said in Electron CPU usage:
                                    I’m just trying to get to the root of this problem. I may never figure it out but I will certainly try.
                                    Nothing ventured, nothing gained.
                                      roramirez Core Contributors @pedroken
                                      @pedroken I think this can because the Electron version. Can you tell us what version is for two case.
                                      You can see into the file node_modules/electron/dist/version
                                      Mykle1M P 2 Replies Last reply Reply Quote 0
                                        Mykle1 Project Sponsor Module Developer @roramirez
                                        @roramirez said in Electron CPU usage:
                                        Thanks for getting involved here. Just for reference purposes, my Electron version on my Pi 3 B is v1.4.15
                                        • W Offline
                                          wtidwell @Mykle1
                                          @Mykle1
                                          Sorry for the radio silence, it’s been busy lately.
                                          I can see what electron version I’m running tomorrow night, and I’ll try and change it to the same version you seem to be getting good performance on and report back.
                                            Mykle1 Project Sponsor Module Developer @wtidwell
                                            @wtidwell said in Electron CPU usage:
                                            No worries, mate. Now that @roramirez is looking at this we may find the answer sooner than later.
                                            • 12
                                            • 13
                                            • 6 / 13
