    Electron CPU usage
    247 Posts 46 Posters 644.3k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @wtidwell
      @wtidwell said in Electron CPU usage:
      Sorry for the radio silence, it’s been busy lately.
      I can see what electron version I’m running tomorrow night, and I’ll try and change it to the same version you seem to be getting good performance on and report back.
      No worries, mate. Now that @roramirez is looking at this we may find the answer sooner than later.
        pedroken @roramirez
        @roramirez , the version in the high CPU scenario is v1.7.5. The animations are sluggish, even with only the default modules.
        The version of the lower CPU consumption but strange memory leak is v1.6.11.
        Thanks!
        I’ll try to use @Mykle1 's version of electron. I`ll google it (how to). Never did it.
        M R 2 Replies Last reply Reply Quote 0
          mibafz00 @pedroken
          @pedroken
          I also have v1.7.5 and I do have the problem.
          Didn’t find out how to downgrade so I’ll waiting for your results :-)
          • W Offline
            wtidwell @mibafz00
            @mibafz00
            Forgive me if this is dumb, but couldn’t you just delete the electron folder and reinstall a specific version with
            Npm install electron@version?
              Some mention here of high CPU usage. Maybe electron IS the culprit
              https://github.com/electron/electron/releases/
              electron v1.7.6 beta
              @electron-bot electron-bot released this 24 days ago · 233 commits to master since this release
              Bug Fixes
              Fixed query string parsing in PDF Viewer #10008
              Fixed crash that occurred when loading URL in detached WebContents #9819
              Fixed issues around update permissions and non-admin users #10071
              Fixed chrome storage access scope to be shared across domains #9951
              Fixed content scripts matches #10075
              Fixed bug that returned an object instead of an empty string when reading from an empty asar file with ‘utf8’ option #10160
              Prevented async tasks from crashing after the Node environment is destroyed #10099
              Linux
              Fixed issue where opening menu would cause high CPU usage on certain Linux distributions #10070
                djsunrise19
                Input from my side: I checked the issues with electron 1.8 beta. Same problems.
                  roramirez Core Contributors @pedroken
                  @pedroken said in Electron CPU usage:
                  Well, you let we know if with that version of Electron is fixed the CPU usage. You can modified by hand the package.json to say to npm what version to install of Electron.
                    djsunrise19
                    My two cents again ;): My electron pakackage.json version is v.1.6.10. I made a downgrade to v1.4.15. Code says “invalid”. But the installation seems to work? Do you guys know, where I can check the installed electron version?
                    No effect. 55% CPU and very sluggish (256MB GPU Memory):
                      Mykle1 Project Sponsor Module Developer @djsunrise19
                      @djsunrise19 said in Electron CPU usage:
                      You can see the installed version in this file MagicMirror/node_modules/electron/dist/version
                        djsunrise19 @Mykle1
                        @Mykle1 Thanks. Yes, v1.4.15.
                          I just had a thought (miracle). What version of MM is everyone using?
                          My Pi3 B mirror is running MM version 2.1.0. I’ve had no reason to update it. It’s rock solid
                            djsunrise19 @Mykle1
                            @Mykle1 said in Electron CPU usage:
                            I had this problems since the new MM2 Version. Very long so. But my version is the newest one. 2.1.2 I think.
                              uh oh! So you DIDN’T have this problem before the new version?
                                SashMare
                                Hi.
                                I made a downgrade Electron from v1.7.15 to v1.4.15.
                                CPU load up to 320% is gone.
                                Hardware: BCM2835
                                Revision: a22082
                                MagicMirror: 2.1.2
                                W 1 Reply Last reply Reply Quote 1
                                • W Offline
                                  wtidwell @SashMare
                                  @SashMare @Mykle1 my
                                  I also downgraded electron to 1.4.15 and I’m seeing dramatically improved performance!
                                  D Mykle1M 2 Replies Last reply Reply Quote 1
                                    djsunrise19 @wtidwell
                                    Do you have some CPU load Screenshots? As I read, around 55% is to high too.
                                    • W Offline
                                      wtidwell @djsunrise19
                                      @djsunrise19
                                      Not on hand but I’m seeing in the mid 20’s with newsfeed animations
                                        Well, that’s good news! :^)
                                          You guys are both running MM 2.1.2? There has been some mention that this problem arose after the upgrade. My Pi3 B mirror is still running MM 2.1.0. :-/
                                          Just a thought.
                                            mibafz00 @Mykle1
                                            @Mykle1
                                            Today, I tried the following:
                                            MM 2.1.2 + Electron 1.7.5 --> CPU 100% during transitions
                                            MM 2.1.2 + Electron 1.4.15 --> problem still there, CPU 100% during transitions
                                            MM 2.1.0 + Electron 1.7.5 --> problem still there, CPU 100% during transitions
                                            MM 2.1.0 + Electron 1.4.15 --> problem (probably) gone, CPU 40% during transitions
                                            So i guess you have to downgrade both, MM and electron…!?
                                            • 12
                                            • 13
                                            • 7 / 13
