    Motion Detection with RaspiCam, Non-Module version
    47 Posts 13 Posters 54.0k Views 17 Watching
    • L Offline
      lolobyte @bhepler
      @bhepler
      Hi, i do the same at first and restor my sw installation.
      But after the same procedure of sw installation this error was again on top.
      I resolve, by my sw, the reason for that was: motion must start after pm2 startin mm.
      My mm start’s automaticly after rebooting.
      My motion also. => collision of SW.
      By doing motion in an cron job with delay time al was fun an running as iwant.
      in my case i do following:
      don’t foget to install screen.
      sudo apt-get intsall screen
      My motion is running in a screen session.
      then the cronjob
      crontab -e
      and set motion with following parameters:
      @reboot sleep 150; screen -S motion -dmS sudo motion -c /home/pi/motion/motion-mmalcam.conf
      i hope this is helpfull for you and other persons here.
        bhepler Module Developer
        Update: Having PM2 monitor the motion process seems to work quite well. However, I have now discovered that there is a memory leak somewhere in all of this. Using the MMM-SystemStats module, I can watch free memory trickle down throughout the day.
        I’ve configured the Pi to reboot early each morning. That’s not an ideal situation, but it seems to have solved the problem. Good enough for me! And more importantly, good enough for the gift recipient.
        • L Offline
          lolobyte @bhepler
          @bhepler
          have u increase the swapfile?
            bhepler Module Developer @lolobyte
            @lolobyte Negative, I have not. What would you recommend?
            • L Offline
              lolobyte @bhepler
              @bhepler
              in general it’s not bad for a raspi3 to increase the swapfile from 100MB to a higher level.
              at first check your status:
              sudo service dphys-swapfile status
              U see something like this:
              ● dphys-swapfile.service - LSB: Autogenerate and use a swap file
              Loaded: loaded (/etc/init.d/dphys-swapfile)
              Active: active (exited) since Mi 2016-11-30 13:17:14 CET; 6h ago
              Process: 613 ExecStart=/etc/init.d/dphys-swapfile start (code=exited, status=0 /SUCCESS)
              Nov 30 13:17:13 raspi3 systemd[1]: Starting LSB: Autogenerate and use a swa…
              Nov 30 13:17:14 raspi3 dphys-swapfile[613]: Starting dphys-swapfile swapfile…
              Nov 30 13:17:14 raspi3 dphys-swapfile[613]: want /var/swap=1024MByte, checki…t
              Nov 30 13:17:14 raspi3 dphys-swapfile[613]: done.
              Nov 30 13:17:14 raspi3 systemd[1]: Started LSB: Autogenerate and use a swap…e.
              Hint: Some lines were ellipsized, use -l to show in full.
              Maybe u have 100MB instead of 1024 like in my case.
              If u want to change this value the edit your
              sudo nano /etc/dphys-swapfile
              change to this value and save your file
              CONF_SWAPSIZE=1024
              the do a
              sudo dphys-swapfile setup
              and activate your new swap level:
              sudo dphys-swapfile swapon
              thats all. Now your System can handle wit more than his physical RAM.
              In My case i do in raspi-config a new
              “Expand File system”
              to reorganize the file system an reboot after that my raspi.
              If you are a owner of a raspi 2 it’s more common to change the swap file to max 512MB.
              please inform me what’s your experience after this change
              you can also check very niche your tasks mem, swap and other things in a ssh session on your PC with htop
              sudo apt-get install htop
              have a nice try
                Binog @lolobyte
                @lolobyte
                Can U specify what this command does,. Am not sure if it isn’t doubling the motion command:
                (ignored the -c path part, cause renamed the config to motion.conf, so not needed)
                why is there two time motion - in it?
                By the way it isn’t working on my mirror
                • KimzerK Offline
                  Kimzer
                  I am completely unable to make this work.
                  The camera wont take any snapshots, maybe just a config error. But can someone confirm that this still works or show me something that works? Dont wanna go out and buy a pir sensor if i can make use of the raspicam. :)
                    bhepler Module Developer @Kimzer
                    @Kimzer - If the camera won’t even take a snapshot, then none of this is going to work. Have you tried the various tutorials about getting the PiCam to work? The ones that are at the basic level of “I enter this command and it takes a picture right then and there and I can download it”?
                    Start with the official Getting Started Guide. Once you can get images from the camera to your Pi, come back.
                    If you can get the camera to produce images but have trouble getting Motion to work, follow my tutorial and the part where it says “at this point you can test it but…”, stop there. Change the parameter in the motion.conf file named output_pictures to on and change on_event_start to echo Motion Detected!. That should put a bunch of snapshots on your memory card. Test Motion by entering ./motion -c motion.conf and you should see motion writing messages to the screen.
                    • KimzerK Offline
                      Kimzer
                      Ah my bad, poorly formulated on my end here.
                      I am able to take snapshots, and i have gotten the camera to work just fine itself. It is the motion part i am struggling with.
                      But i will have to test some more.
                      • F Offline
                        Freebond
                        • N Offline
                          Natacha3 @bhepler
                          @bhepler It works perfectly !
                          Thank you so much for sharing !
                            stangarrang
                            @bhepler I was hoping you could give me a hand. I’ve got your motion working but. Pm2 is not auto starting the motion. Everything is working fine if I manually “pm2 start motion” and " pm2 start mm" and I’ve tried adding @pm2 start motion to my auto start along side my “pm2 start mm” but that only breaks both processes. I’m trying to get both the magic mirror and the motion to auto start upon reboot.
                              bhepler Module Developer @stangarrang
                              @stangarrang Sure, no problem. Quick question: Did you enter pm2 save after you started both the motion and the Magic Mirror processes?
                                stangarrang
                                @bhepler yes that was one of the first things I did but after reboot nothing was saving. Actually just as you replied I went through a couple steps for pm2 startup plus the command that came after. After that I did a pm2 save and now things are working well :) thanks for your prompt reply!
                                  AnduriI
                                  is it possible to use Motion to activate the screen and MMM-Facial-Recignition simultaneously? Maybe also use the on_event_start to activate some lights in the front of the MM to increase image quality…
                                    bhepler Module Developer @AnduriI
                                    @AnduriI It should be. The motion system will operate independently of the mirror and only controls the signal running down the HDMI cable to the monitor. The Pi camera and the Magic Mirror process are still running.
                                    If you create a simple python script to control the pinouts on the Pi, you should be able to switch on some simple LED lights to illuminate the front of the mirror.
                                      dam4
                                      @bhepler
                                      Hello, I am a true n00b and I am having issues with your process for getting the Pi camera to work. I copied and pasted your first line exactly and I get the following.
                                      pi@raspberrypi:~ $ sudo apt-get install -y libjpeg-dev libavformat56 libavformat-dev libavcodec56 libavcodec-dev libavutil54 libavutil-dev libc6-dev zlib1g-dev libmysqlclient18 libmysqlclient-dev libpq5 libpq-dev
                                      Reading package lists... Done
                                      Building dependency tree
                                      Package libmysqlclient-dev is not available, but is referred to by another package.
                                      This may mean that the package is missing, has been obsoleted, or
                                      is only available from another source
                                      Package libmysqlclient18 is not available, but is referred to by another package.
                                      E: Unable to locate package libavformat56
                                      E: Unable to locate package libavcodec56
                                      E: Unable to locate package libavutil54
                                      E: Package 'libmysqlclient18' has no installation candidate
                                      E: Package 'libmysqlclient-dev' has no installation candidate
                                      pi@raspberrypi:~ $
                                      What did I do wrong? Please help and thank you in advance.
                                      • Y Offline
                                        yawns Moderator @dam4
                                        @dam4
                                        Are you running raspbian Jessie or Stretch?
                                        Looks like the names where changed
                                        Jessie: https://packages.debian.org/jessie/libmysqlclient-dev
                                        Stretch: https://packages.debian.org/stretch/default-libmysqlclient-dev
                                          dam4 @yawns
                                          @yawns I am pretty sure I am running Jessie. How do I know for sure?
                                          • Y Offline
                                            @dam4
                                            In the terminal run cat /etc/os-release
                                            Maybe you need to run sudo cat /etc/os-release
