    Motion Detection with RaspiCam, Non-Module version
    47 Posts 13 Posters 46.8k Views 17 Watching
    • bheplerB Offline
      bhepler Module Developer
      First, I want thank @alexyak for his motioncontrol module. Unfortunately for me, it doesn’t work on my Mirror due to new security controls put in place by the Node.js team. Apparently it’s not a wise move to let client-side Javascript access the webcam attached to your server. Who knew?
      In the end, I ended up seeking another solution. The Facial Recognition module didn’t work due to the reduction in light coming through the mirror itself. But I do get an image. I started browsing sites of people who have turned their Raspi into a security system. It turns out, someone ported the Motion framework to Raspberry Pi and called it MMAL-Motion.
      After a lot of reading, I found a Wiki for MMAL Motion. Following the steps for Jessie, I did the following:
      • Change to your home directory. cd ~
      • Install the library dependencies (just copy & paste into the terminal. I wouldn’t want to do this by hand)
        sudo apt-get install -y libjpeg-dev libavformat56 libavformat-dev libavcodec56 libavcodec-dev libavutil54 libavutil-dev libc6-dev zlib1g-dev libmysqlclient18 libmysqlclient-dev libpq5 libpq-dev
      • Download the precompiled binary archive file:
        wget https://www.dropbox.com/s/6ruqgv1h65zufr6/motion-mmal-lowflyerUK-20151114.tar.gz
      • Uncompress the archive file
        tar -zxvf motion-mmal-lowflyerUK-20151114.tar.gz
      This will put a configuration file called motion-mmalcam-both.conf and a folder called motion in your home folder. At this step you can test it if you like, but for my purposes I needed to make a few changes tot the config file. So, make a copy and edit the copy.
      cp motion-mmalcam-both.conf motion.conf
      nano motion.conf
      I played around with the configuration quite a bit until I found one I liked. But for our purposes (turning the display on when someone comes near) you only have to make a few changes.
      framerate 4 - run the detection video at 4 frames per second
      threshold 2500 - increase the # of pixels to trigger the screen. We want them to get close to the mirror
      minimum_motion_frames 2 - Motion must be detected in 2 consecutive frames (at 4 FPS)
      event_gap 60 - This is important. This is how long in seconds after no motion the screen will turn off.
      output_pictures off - Do not save images
      ffmpeg_output_movies off - Do not record video
      stream_port 0 - Turn off remote viewing
      webcontrol_port 0 - Turn off HTTP control of camera
      on_event_start vcgencmd display_power 1 - Important! This is the command to turn on the screen
      on_event_end vcgencmd display_power 0 - Important! This is the command to turn off the screen
      Save your motion.conf file and now you can test it out by entering ./motion -c motion.conf. If you stay very still for a minute, the screen should turn off. Move close to the mirror, and everything should come back after a couple seconds.
      B N 2 Replies Last reply Reply Quote 3
        bibi @bhepler
        hi @bhepler ! thx for sharing your findings!i will try this settings later this week. before to get into it, could you please let me know if it will also work without a RaspiCam?? usb camera is ok? where did you put/hide your own cam? thx :)
        • bheplerB Offline
          bhepler Module Developer @bibi
          @bibi I haven’t tried it with a USB cam, but it should work. In the config file, there is a switch to throw if you’re using a USB cam (and different switches to throw if you’re using a network cam - which raises interesting possibilities).
          My camera is mounted above the monitor & behind the one-way acrylic. My monitor is smaller than my acrylic by about 2" on a side. This is good in that it’s a very clean installation and you don’t see a camera when you look at the mirror. It’s bad in that it cuts down on the light reaching the camera, preventing the facial recognition from working.
          • bheplerB Offline
            Hrm. New problem: After a few hours, the screen goes white. This obviously will not do. Back to the drawing board.
            I found this in the motion log:
            [1] [NTC] [ALL] [Nov 15 20:25:02] motion_loop: End of event 74
            [1] [NTC] [ALL] [Nov 15 20:25:04] motion_loop: fps: 3.999920 idle 26.67% over 0.00%
            [1] [NTC] [ALL] [Nov 15 20:25:09] motion_loop: fps: 3.998465 idle 24.89% over 0.00%
            [1] [ERR] [ENC] [Nov 15 20:25:10] ffmpeg_put_frame: Error while writing video frame:
            [1] [NTC] [ALL] [Nov 15 20:25:10] motion_loop: Thread exiting
            [1] [INF] [ALL] [Nov 15 20:25:10] motion_cleanup: Calling vid_close() from motion_cleanup
            [1] [INF] [VID] [Nov 15 20:25:10] vid_close: calling video source cleanup
            [1] [ALR] [VID] [Nov 15 20:25:10] MMAL Camera cleanup
            [0] [NTC] [ALL] [Nov 15 20:25:11] main: Threads finished
            [0] [NTC] [ALL] [Nov 15 20:25:12] main: Motion terminating
            [0] [NTC] [ALL] [Nov 15 20:25:12] motion_remove_pid: Removed process id file (pid file).
            [0] [NTC] [ALL] [Nov 15 20:25:12] motion_remove_pid: Closing logfile (/tmp/motion.log).
            • bheplerB Offline
              I believe I have it cracked. The white screen was due to MMAL Motion crashing whilst writing a frame to disk. When Motion crashes, it apparently jacks up the video output.
              My current solution is to use PM2 to monitor the motion process and restart it when necessary. I’m testing now. If it works for a few more days I’ll report back.
              Adding motion to PM2: pm2 start motion. Be sure that the motion is not configured to run as a daemon (first option in config file).
              lolobyteL 1 Reply Last reply Reply Quote 1
              • lolobyteL Offline
                lolobyte @bhepler
                @bhepler
                Hi, i do the same at first and restor my sw installation.
                But after the same procedure of sw installation this error was again on top.
                I resolve, by my sw, the reason for that was: motion must start after pm2 startin mm.
                My mm start’s automaticly after rebooting.
                My motion also. => collision of SW.
                By doing motion in an cron job with delay time al was fun an running as iwant.
                in my case i do following:
                don’t foget to install screen.
                sudo apt-get intsall screen
                My motion is running in a screen session.
                then the cronjob
                crontab -e
                and set motion with following parameters:
                @reboot sleep 150; screen -S motion -dmS sudo motion -c /home/pi/motion/motion-mmalcam.conf
                i hope this is helpfull for you and other persons here.
                • bheplerB Offline
                  Update: Having PM2 monitor the motion process seems to work quite well. However, I have now discovered that there is a memory leak somewhere in all of this. Using the MMM-SystemStats module, I can watch free memory trickle down throughout the day.
                  I’ve configured the Pi to reboot early each morning. That’s not an ideal situation, but it seems to have solved the problem. Good enough for me! And more importantly, good enough for the gift recipient.
                  lolobyteL 1 Reply Last reply Reply Quote 0
                  • lolobyteL Offline
                    lolobyte @bhepler
                    @bhepler
                    have u increase the swapfile?
                    • bheplerB Offline
                      bhepler Module Developer @lolobyte
                      @lolobyte Negative, I have not. What would you recommend?
                      • lolobyteL Offline
                        lolobyte @bhepler
                        @bhepler
                        in general it’s not bad for a raspi3 to increase the swapfile from 100MB to a higher level.
                        at first check your status:
                        sudo service dphys-swapfile status
                        U see something like this:
                        ● dphys-swapfile.service - LSB: Autogenerate and use a swap file
                        Loaded: loaded (/etc/init.d/dphys-swapfile)
                        Active: active (exited) since Mi 2016-11-30 13:17:14 CET; 6h ago
                        Process: 613 ExecStart=/etc/init.d/dphys-swapfile start (code=exited, status=0 /SUCCESS)
                        Nov 30 13:17:13 raspi3 systemd[1]: Starting LSB: Autogenerate and use a swa…
                        Nov 30 13:17:14 raspi3 dphys-swapfile[613]: Starting dphys-swapfile swapfile…
                        Nov 30 13:17:14 raspi3 dphys-swapfile[613]: want /var/swap=1024MByte, checki…t
                        Nov 30 13:17:14 raspi3 dphys-swapfile[613]: done.
                        Nov 30 13:17:14 raspi3 systemd[1]: Started LSB: Autogenerate and use a swap…e.
                        Hint: Some lines were ellipsized, use -l to show in full.
                        Maybe u have 100MB instead of 1024 like in my case.
                        If u want to change this value the edit your
                        sudo nano /etc/dphys-swapfile
                        change to this value and save your file
                        CONF_SWAPSIZE=1024
                        the do a
                        sudo dphys-swapfile setup
                        and activate your new swap level:
                        sudo dphys-swapfile swapon
                        thats all. Now your System can handle wit more than his physical RAM.
                        In My case i do in raspi-config a new
                        “Expand File system”
                        to reorganize the file system an reboot after that my raspi.
                        If you are a owner of a raspi 2 it’s more common to change the swap file to max 512MB.
                        please inform me what’s your experience after this change
                        you can also check very niche your tasks mem, swap and other things in a ssh session on your PC with htop
                        sudo apt-get install htop
                        have a nice try
                        • 1 / 5
