    690 Posts 77 Posters 3.3m Views 70 Watching
      plybz18
      great, just got myself upgraded and looking awesome.
      How do i increase font size of temperature to look big?
      • cowboysdudeC
        cowboysdude Module Developer @plybz18
        @plybz18
        In your custom.css file you can add this:
        .MMM-NOAA .wfont {
        font-size: 1.6em;
        [Corrected the entry it was wrong… sorry about that!]
        • cowboysdudeC
          UPDATE V.2.1
          ALL weather conditions are no longer in the translation file and are automatic in the language that’s supported in the module!!
          See the README on Github
          Download:
          [card:cowboysdude/MMM-NOAA]
          Mykle1M SnilleS 2 Replies Last reply
          • Mykle1M
            @cowboysdude
            Dayam!
            Exquisite!
            • SnilleS
              Snille Module Developer @cowboysdude
              @cowboysdude Looking great! :) I have a suggestion… Change the “Humidity” text to an image of a droplet (https://thenounproject.com/term/raindrop/381297/) to save space. :) Or from font awesome: http://fontawesome.io/icon/tint/
              • cowboysdudeC
                cowboysdude Module Developer @Snille
                @Snille Well I’ll give it a shot… I don’t usually have good luck with images that’s why I use words LOL
                • Nystro0mN
                  Nystro0m
                  Hi!
                  Im stuck on the “Gather Wather Stuff” Message. Or “Samlar väderinformation” since im running a Swedish pi.
                  First of thanks for sharing the module, it looks badass.
                  Ive been diagnosing alot without any luck but this is what ive done to confirm my config:
                  Ive been checking my api-key and pws with another module from RedNax67 called MMM_Wunderground.
                  And i can get that one to work.
                  I also encounter this message on re-installing the module (can’t remember if it was there on the initial install).
                  npm WARN mmm-noaa@1.0.0 No repository field.
                  This is my module config:
                      disabled: false,
                      module: 'MMM-NOAA',
                      position: 'top_right',
                          apiKey: "Y507ba7785XXXXXXX",          // https://www.wunderground.com/weather/api  select the middle plan...
                      useAir: false,             //set to false if you do not want to use Air Quality Index
                      airKey: "Y507ba7785XXXXXXX",  //IF you want Air Quality Index
                  		pws: "IUHAMMAR4",       // go here to find your pws: https://www.wunderground.com/wundermap
                                  lat: "59.609900",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                  		lon: "16.544809",       // need this for sunrise/sunset  if left blank none will show
                  		showClock: true,            //Hides or shows clock
                  		dformat: false,             //for M/D/YYYY format, false for D/M/YYYY
                  		showClock: true,
                  		format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
                  		ampm: false,                 //to show AM and PM on Sunrise/Sunset time
                  		showGreet: false,          //deafult is false - to show greeting under clock and above date
                                      name: "",                  // Your name
                  		showWind: false,
                                      showDate: false,
                  Do you have any other ideas what i can try to get it running?
                    barnosch
                    uncomment the “air stuff” for the moment
                     /*    if (this.config.useAir != false || aquis != undefined) {
                                var aqius = this.air.aqius;
                                var aqi = document.createElement("div");
                                aqi.classList.add("xsmall", "bright");
                                if (aqius < 51) {
                                    aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + "";
                                } else if (aqius > 50 && aqius < 101) {
                                } else if (aqius > 100 && aqius < 151) {
                                } else if (aqius > 150 && aqius < 201) {
                                } else {
                                wrapper.appendChild(aqi);
                    @cowboysdude needs to check it, since the “aquis” variabel is undefined it quits. Had the same error and i needed some time to find the cause
                    edit: while i am reading i guess it is just a typo in the first line. should be “aqius” instead of “aquis” ;)
                    edit2: yes. thats it. just change
                    the line
                    to
                    if (this.config.useAir != false || aqius != undefined) {
                    and you are good to go again.
                    Sadly i have no idea how to push the fix to the git repository
                    Nystro0mN Mykle1M B 3 Replies Last reply
                    Reply Quote 2
                    • Nystro0mN
                      Nystro0m @barnosch
                      @barnosch
                      It did work like a charm, thanks alot dude!
                      Also thanks to @Mykle1 for chatting with me and updating me on the social status of @cowboysdude hehe.
                      For a first time post, i must say you guys have impressed me of how welcoming a Forum can be. It’s rare from my experience.
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @barnosch
                        @barnosch said in MMM-NOAA - Another Weather Module:
                        Nice catch you guys.
                        Nice remedy @barnosch
                        If you go to the modules repo https://github.com/cowboysdude/MMM-NOAA
                        and click on the file you want to fix, then click on the “pencil” icon to the right, github will fork the repo for you. There you can make the edit and submit a pull request which will go to cowboysdude
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Nystro0m
                          @Nystro0m said in MMM-NOAA - Another Weather Module:
                          I just finishing texting with @cowboysdude. I told him, “Don’t rush home from work. Someone else fixed your $h1t”.
                            barnosch @barnosch
                            cool. thats easy.
                            Thanks for the explanation. Fix added ;)
                            Reply Quote 2
                            • Mykle1M
                              cool. thats easy.
                              You’re welcome.
                              I’m sure @cowboysdude will appreciate it
                              • cowboysdudeC
                                Thank you @Mykle1 and @barnosch
                                Merged the pull request! :)
                                • Mykle1M
                                  @cowboysdude said in MMM-NOAA - Another Weather Module:
                                  He ran all the way home just to fix his module.
                                  Yeah, he’s that good! :^)
                                  And, well done @barnosch !
                                    barnosch
                                    thanks guys. Very nice to have some guys like you here. Like this it’s fun.
                                    • pjkoelemanP
                                      pjkoeleman @cowboysdude
                                      Please PM me if you’d be interested in making any other translation files for this
                                      Just send you the dutch translation by Github. Don’t now if I did it the right way, so here it is as well.
                                      "GATHERING WEATHER STUFF": "Ontvangen weerdata...",
                                      "Currently: ": "Actueel: ",
                                      "Current Temp: ": "Huidige temperatuur: ",
                                      "UV Index: ": "UV-Index: ",
                                      "Wind: ": "Wind: ",
                                      "From: ": "van: ",
                                      "Barometer: ": "Barometer: ",
                                      "Monday": "Maandag",
                                      "Tuesday": "Dinsdag",
                                      "Wednesday": "Woensdag",
                                      "Thursday": "Donderdag",
                                      "Friday": "Vrijdag",
                                      "Saturday": "Zaterdag",
                                      "Sunday": "Zondag",
                                      "High:  ": "Hoog: ",
                                      "Low:  ": "Laag: ",
                                      "Humidity: ": "Luchtvochtigheid: ",
                                      "Safe": "Veilig",
                                      "Moderate": "Gemiddeld",
                                      "Very High": "Zeer hoog",
                                      "Extreme": "Extreem",
                                      "Sunset": "Zonsondergang",
                                      "Sunrise": "Zonsopgang",
                                      " hours ": " Uren ",
                                      " minutes ": " Minuten ",
                                      "Amount of Daylight": "Aantal uren daglicht",
                                      "Good Morning ":"Goedemorgen ",
                                      "Good Afternoon ": "Goedenmiddag ",
                                      "Good Evening ": "Goedenavond ",
                                      "Air Quality Index: ":"Luchtkwaliteitsindex: "
                                      • cowboysdudeC
                                        cowboysdude Module Developer @pjkoeleman
                                        @pjkoeleman Huge Thanks!!
                                        NOW with Dutch Language :)
                                        Download:
                                        pjkoelemanP 1 Reply Last reply
                                        • pjkoelemanP
                                          @cowboysdude
                                          You’re welcome
                                          • Nystro0mN
                                            Nystro0m
                                            @cowboysdude
                                            I got a error after the update with following:
                                            /home/pi/MagicMirror/modules/MMM-NOAA/MMM-NOAA.js:399
                                            SyntaxError: Unexpected token ===
                                            I removed the ====== on line 399 with success to get the module working.
                                            Im not sure if this is just on my side, im still new to this. But i thought it could good to be shared.
                                            Edit: This could make a problem with updating the the module. I experience the clock getting stuck from time to time.
                                            • 34
                                            • 35
                                            • 3 / 35
