    • cowboysdudeC Offline
      cowboysdude Module Developer @barnosch
      @barnosch I like it!! Looks great!!
        UPDATE V.2
        Changed the format to show 3 days of weather instead of rotating. Quicker, easier and loads twice as fast!
        Added 2 new config options:
        1. Show or hide wind
        2. Show or hide Date
        See the README on Github
        Thank you to @barnosch for the help and ideas!!
        Download:
        [card:cowboysdude/MMM-NOAA]
          barnosch
          big like !
            plybz18
            great, just got myself upgraded and looking awesome.
            How do i increase font size of temperature to look big?
              cowboysdude Module Developer @plybz18
              @plybz18
              In your custom.css file you can add this:
              .MMM-NOAA .wfont {
              font-size: 1.6em;
              [Corrected the entry it was wrong… sorry about that!]
                UPDATE V.2.1
                ALL weather conditions are no longer in the translation file and are automatic in the language that’s supported in the module!!
                Download:
                Mykle1M SnilleS 2 Replies Last reply Reply Quote 1
                  @cowboysdude
                  Dayam!
                  Exquisite!
                  • SnilleS Offline
                    Snille Module Developer @cowboysdude
                    @cowboysdude Looking great! :) I have a suggestion… Change the “Humidity” text to an image of a droplet (https://thenounproject.com/term/raindrop/381297/) to save space. :) Or from font awesome: http://fontawesome.io/icon/tint/
                      cowboysdude Module Developer @Snille
                      @Snille Well I’ll give it a shot… I don’t usually have good luck with images that’s why I use words LOL
                      • Nystro0mN Offline
                        Nystro0m
                        Hi!
                        Im stuck on the “Gather Wather Stuff” Message. Or “Samlar väderinformation” since im running a Swedish pi.
                        First of thanks for sharing the module, it looks badass.
                        Ive been diagnosing alot without any luck but this is what ive done to confirm my config:
                        Ive been checking my api-key and pws with another module from RedNax67 called MMM_Wunderground.
                        And i can get that one to work.
                        I also encounter this message on re-installing the module (can’t remember if it was there on the initial install).
                        npm WARN mmm-noaa@1.0.0 No repository field.
                        This is my module config:
                            disabled: false,
                            module: 'MMM-NOAA',
                            position: 'top_right',
                                apiKey: "Y507ba7785XXXXXXX",          // https://www.wunderground.com/weather/api  select the middle plan...
                            useAir: false,             //set to false if you do not want to use Air Quality Index
                            airKey: "Y507ba7785XXXXXXX",  //IF you want Air Quality Index
                        		pws: "IUHAMMAR4",       // go here to find your pws: https://www.wunderground.com/wundermap
                                        lat: "59.609900",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                        		lon: "16.544809",       // need this for sunrise/sunset  if left blank none will show
                        		showClock: true,            //Hides or shows clock
                        		dformat: false,             //for M/D/YYYY format, false for D/M/YYYY
                        		showClock: true,
                        		format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
                        		ampm: false,                 //to show AM and PM on Sunrise/Sunset time
                        		showGreet: false,          //deafult is false - to show greeting under clock and above date
                                            name: "",                  // Your name
                        		showWind: false,
                                            showDate: false,
                        Do you have any other ideas what i can try to get it running?
                          barnosch
                          uncomment the “air stuff” for the moment
                           /*    if (this.config.useAir != false || aquis != undefined) {
                                      var aqius = this.air.aqius;
                                      var aqi = document.createElement("div");
                                      aqi.classList.add("xsmall", "bright");
                                      if (aqius < 51) {
                                          aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + "";
                                      } else if (aqius > 50 && aqius < 101) {
                                      } else if (aqius > 100 && aqius < 151) {
                                      } else if (aqius > 150 && aqius < 201) {
                                      } else {
                                      wrapper.appendChild(aqi);
                          @cowboysdude needs to check it, since the “aquis” variabel is undefined it quits. Had the same error and i needed some time to find the cause
                          edit: while i am reading i guess it is just a typo in the first line. should be “aqius” instead of “aquis” ;)
                          edit2: yes. thats it. just change
                          the line
                          to
                          if (this.config.useAir != false || aqius != undefined) {
                          and you are good to go again.
                          Sadly i have no idea how to push the fix to the git repository
                          Nystro0mN Mykle1M B 3 Replies Last reply Reply Quote 2
                          • Nystro0mN Offline
                            Nystro0m @barnosch
                            @barnosch
                            It did work like a charm, thanks alot dude!
                            Also thanks to @Mykle1 for chatting with me and updating me on the social status of @cowboysdude hehe.
                            For a first time post, i must say you guys have impressed me of how welcoming a Forum can be. It’s rare from my experience.
                              Mykle1 Project Sponsor Module Developer @barnosch
                              @barnosch said in MMM-NOAA - Another Weather Module:
                              Nice catch you guys.
                              Nice remedy @barnosch
                              If you go to the modules repo https://github.com/cowboysdude/MMM-NOAA
                              and click on the file you want to fix, then click on the “pencil” icon to the right, github will fork the repo for you. There you can make the edit and submit a pull request which will go to cowboysdude
                                Mykle1 Project Sponsor Module Developer @Nystro0m
                                @Nystro0m said in MMM-NOAA - Another Weather Module:
                                I just finishing texting with @cowboysdude. I told him, “Don’t rush home from work. Someone else fixed your $h1t”.
                                  barnosch @barnosch
                                  cool. thats easy.
                                  Thanks for the explanation. Fix added ;)
                                    cool. thats easy.
                                    You’re welcome.
                                    I’m sure @cowboysdude will appreciate it
                                      Thank you @Mykle1 and @barnosch
                                      Merged the pull request! :)
                                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                                        He ran all the way home just to fix his module.
                                        Yeah, he’s that good! :^)
                                        And, well done @barnosch !
                                          barnosch
                                          thanks guys. Very nice to have some guys like you here. Like this it’s fun.
                                            pjkoeleman @cowboysdude
                                            Please PM me if you’d be interested in making any other translation files for this
                                            Just send you the dutch translation by Github. Don’t now if I did it the right way, so here it is as well.
                                            "GATHERING WEATHER STUFF": "Ontvangen weerdata...",
                                            "Currently: ": "Actueel: ",
                                            "Current Temp: ": "Huidige temperatuur: ",
                                            "UV Index: ": "UV-Index: ",
                                            "Wind: ": "Wind: ",
                                            "From: ": "van: ",
                                            "Barometer: ": "Barometer: ",
                                            "Monday": "Maandag",
                                            "Tuesday": "Dinsdag",
                                            "Wednesday": "Woensdag",
                                            "Thursday": "Donderdag",
                                            "Friday": "Vrijdag",
                                            "Saturday": "Zaterdag",
                                            "Sunday": "Zondag",
                                            "High:  ": "Hoog: ",
                                            "Low:  ": "Laag: ",
                                            "Humidity: ": "Luchtvochtigheid: ",
                                            "Safe": "Veilig",
                                            "Moderate": "Gemiddeld",
                                            "Very High": "Zeer hoog",
                                            "Extreme": "Extreem",
                                            "Sunset": "Zonsondergang",
                                            "Sunrise": "Zonsopgang",
                                            " hours ": " Uren ",
                                            " minutes ": " Minuten ",
                                            "Amount of Daylight": "Aantal uren daglicht",
                                            "Good Morning ":"Goedemorgen ",
                                            "Good Afternoon ": "Goedenmiddag ",
                                            "Good Evening ": "Goedenavond ",
                                            "Air Quality Index: ":"Luchtkwaliteitsindex: "
                                            • 34
                                            • 35
                                            • 3 / 35
