@Snille Well I’ll give it a shot… I don’t usually have good luck with images that’s why I use words LOL
Hi!
Im stuck on the “Gather Wather Stuff” Message. Or “Samlar väderinformation” since im running a Swedish pi.
First of thanks for sharing the module, it looks badass.Ive been diagnosing alot without any luck but this is what ive done to confirm my config:
Ive been checking my api-key and pws with another module from RedNax67 called MMM_Wunderground.
And i can get that one to work.I also encounter this message on re-installing the module (can’t remember if it was there on the initial install).
npm WARN mmm-noaa@1.0.0 No repository field.This is my module config:
{ disabled: false, module: 'MMM-NOAA', position: 'top_right', config: { apiKey: "Y507ba7785XXXXXXX", // https://www.wunderground.com/weather/api select the middle plan... useAir: false, //set to false if you do not want to use Air Quality Index airKey: "Y507ba7785XXXXXXX", //IF you want Air Quality Index pws: "IUHAMMAR4", // go here to find your pws: https://www.wunderground.com/wundermap lat: "59.609900", // need this for sunrise/sunset if left blank none will show -- find them here: http://www.latlong.net/ lon: "16.544809", // need this for sunrise/sunset if left blank none will show showClock: true, //Hides or shows clock dformat: false, //for M/D/YYYY format, false for D/M/YYYY showClock: true, format: "24", // 12 or 24 hour format.. will default to 12 hour if none selected. ampm: false, //to show AM and PM on Sunrise/Sunset time showGreet: false, //deafult is false - to show greeting under clock and above date name: "", // Your name showWind: false, showDate: false, }Do you have any other ideas what i can try to get it running?
uncomment the “air stuff” for the moment
/* if (this.config.useAir != false || aquis != undefined) { var aqius = this.air.aqius; var aqi = document.createElement("div"); aqi.classList.add("xsmall", "bright"); if (aqius < 51) { aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + ""; } else if (aqius > 50 && aqius < 101) { aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + ""; } else if (aqius > 100 && aqius < 151) { aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + ""; } else if (aqius > 150 && aqius < 201) { aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + ""; } else { aqi.innerHTML = this.translate("Air Quality Index: ") + "" + aqius + ""; } wrapper.appendChild(aqi); } */@cowboysdude needs to check it, since the “aquis” variabel is undefined it quits. Had the same error and i needed some time to find the cause
edit: while i am reading i guess it is just a typo in the first line. should be “aqius” instead of “aquis” ;)
edit2: yes. thats it. just change
the lineif (this.config.useAir != false || aquis != undefined) {to
if (this.config.useAir != false || aqius != undefined) {and you are good to go again.
Sadly i have no idea how to push the fix to the git repository
It did work like a charm, thanks alot dude!
Also thanks to @Mykle1 for chatting with me and updating me on the social status of @cowboysdude hehe.
For a first time post, i must say you guys have impressed me of how welcoming a Forum can be. It’s rare from my experience. -
@barnosch said in MMM-NOAA - Another Weather Module:
Sadly i have no idea how to push the fix to the git repositoryNice catch you guys.
Nice remedy @barnosch
If you go to the modules repo https://github.com/cowboysdude/MMM-NOAA
and click on the file you want to fix, then click on the “pencil” icon to the right, github will fork the repo for you. There you can make the edit and submit a pull request which will go to cowboysdude -
@Nystro0m said in MMM-NOAA - Another Weather Module:
I just finishing texting with @cowboysdude. I told him, “Don’t rush home from work. Someone else fixed your $h1t”.
cool. thats easy.
Thanks for the explanation. Fix added ;) -
cool. thats easy.
Thanks for the explanation. Fix added ;)You’re welcome.
I’m sure @cowboysdude will appreciate it
@cowboysdude said in MMM-NOAA - Another Weather Module:
Merged the pull request! :)
He ran all the way home just to fix his module.
Yeah, he’s that good! :^)
And, well done @barnosch !
thanks guys. Very nice to have some guys like you here. Like this it’s fun.
Please PM me if you’d be interested in making any other translation files for this
Just send you the dutch translation by Github. Don’t now if I did it the right way, so here it is as well.
{ "GATHERING WEATHER STUFF": "Ontvangen weerdata...", "Currently: ": "Actueel: ", "Current Temp: ": "Huidige temperatuur: ", "UV Index: ": "UV-Index: ", "Wind: ": "Wind: ", "From: ": "van: ", "Barometer: ": "Barometer: ", "Monday": "Maandag", "Tuesday": "Dinsdag", "Wednesday": "Woensdag", "Thursday": "Donderdag", "Friday": "Vrijdag", "Saturday": "Zaterdag", "Sunday": "Zondag", "High: ": "Hoog: ", "Low: ": "Laag: ", "Humidity: ": "Luchtvochtigheid: ", "Safe": "Veilig", "Moderate": "Gemiddeld", "Very High": "Zeer hoog", "Extreme": "Extreem", "Sunset": "Zonsondergang", "Sunrise": "Zonsopgang", " hours ": " Uren ", " minutes ": " Minuten ", "Amount of Daylight": "Aantal uren daglicht", "Good Morning ":"Goedemorgen ", "Good Afternoon ": "Goedenmiddag ", "Good Evening ": "Goedenavond ", "Air Quality Index: ":"Luchtkwaliteitsindex: " } -
@cowboysdude
You’re welcome -
@cowboysdude
I got a error after the update with following:/home/pi/MagicMirror/modules/MMM-NOAA/MMM-NOAA.js:399 ======= ^^^ SyntaxError: Unexpected token ===I removed the ====== on line 399 with success to get the module working.
Im not sure if this is just on my side, im still new to this. But i thought it could good to be shared.
Edit: This could make a problem with updating the the module. I experience the clock getting stuck from time to time.
@Nystro0m
Looks to me that there is two times the same code in the js-file ecxept for the language settings. So @cowboysdude has to look into this. -
@pjkoeleman said in MMM-NOAA - Another Weather Module:
He’s doing a roofing job in 90° heat at the moment. On a Sunday! Who does that?
I’m sure he’ll fix it as soon as possible. That’s what he does.
@Nystro0m and @pjkoeleman
Thank you both!!! IT was doubled, not sure how that happened but all fixed!! :)
installed module last night, settings all according the help file, but nothing is displayed.
Switched back to the wunderground module, that’s working fine.
any idea. I suppose that when the API key is working with the Wunderground module it should work with yours too.what information do i need to provide for further investigation - also tell me how to get that. (I’m newbee - sorry for this - i’m in a learning process )
(language was set to “nl” and then changed again to “en”).
And I see module is loaded, but not displayed. -
@Johans check the console log and see what that tells you when it’s loading…
You need to start your mirror and hit the ‘ALT’ key there will be a menu at the top…you want ‘toggle developer…’
That’ll open up a side panel on the right and it will tell you what error there is…let me know so I can help you fix it :)
