    GETTING STARTED : HELP !!
    16 Posts 4 Posters 7.2k Views 3 Watching
      A Former User
      Hi everyone ive recently come across this site. I have ran the main installation to my pi via ssh i have manually gone onto the pi file manager and into the directory or MagicMirror and tried running index.html
      BUT
      I have a message come up saying about the config file?? I am currectly stuck and unsure on what to do.
      I would appreciate any help please.
      • MichMichM Offline
        MichMich
        Did you copy the config.js.sample file in the /config folder to config.js, as described in the documentation?
          A Former User
            A Former User
            This is a screen shot of the directory from github (left) and then what files are on the pi (right) is this correct?
              A Former User @MichMich
              @MichMich I have tried renaming the file that is in that folder to just say config.js and restarted the pi but still getting the same issue.
                Mykle1 Project Sponsor Module Developer @Guest
                @PCPAYN3
                So, you made a copy of the config.js.sample file and renamed it to config.js, and then you run the mirror and it says your config is missing or has errors?
                Can you post your terminal output here?
                  A Former User @Mykle1
                  @Mykle1 yes thats correct. What do you mean by post terminal output? Sorry im a newbie at this.
                    @PCPAYN3
                    Check that the config.js file is inside the MagicMirror/config/ folder. Unless you made changes to the sample file itself before copying and renaming, that should work.
                    Your terminal, where you run your commands to launch the mirror. You would copy and paste the information in that window here. It’s probably a good idea for you to copy and paste your config.js file here as well.
                    Please select the code block option when pasting </>
                      @Mykle1 hi yes it is in that folder as shown on my screen grab from winscp i will copy the code from the file tonight and paste it on here for you to see.
                        @Mykle1 is there a command i should be running when the pi boots? As i have been going into the folder and loading the index.html file from there.
                          @PCPAYN3
                          @PCPAYN3 said in GETTING STARTED : HELP !!:
                          I’m not really sure what you’re asking. The index.html file isn’t going to launch the mirror. Open a terminal, cd into the MagicMirror directory and run npm start. If you get the config error, we’ll take it from there once you post your terminal and config here
                            A Former User
                            Terminal:
                            pi@raspberrypi:~ $ npm start
                            npm ERR! Linux 4.9.35-v7+
                            npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
                            npm ERR! node v6.11.3
                            npm ERR! npm v3.10.10
                            npm ERR! code ENOENT
                            npm ERR! errno -2
                            npm ERR! syscall open
                            npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                            npm ERR! enoent This is most likely not a problem with npm itself
                            npm ERR! enoent and is related to npm not being able to find a file.
                            npm ERR! enoent
                            npm ERR! /home/pi/npm-debug.log
                            Config File:
                            /* Magic Mirror Config
                            • MIT Licensed.
                            • For more information how you can configurate this file
                            • See https://github.com/MichMich/MagicMirror#configuration
                            var config = {
                            // - “”, “0.0.0.0”, “::” to listen on any interface
                            // Default, when address config is left out, is “localhost”
                            port: 8080,
                            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                            // or add a specific IPv4 of 192.168.1.4 :
                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                            language: "en",
                            timeFormat: 12,
                            units: "metric",
                            		module: "alert",
                            		module: "updatenotification",
                            		position: "top_bar"
                            		module: "clock",
                            		position: "top_left"
                            		header: "US Holidays",
                            					symbol: "calendar-check-o ",
                            		module: "compliments",
                            		position: "lower_third"
                            		module: "currentweather",
                            			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                            		module: "weatherforecast",
                            		header: "Weather Forecast",
                            			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                            		module: "newsfeed",
                            		position: "bottom_bar",
                            			feeds: [
                            					title: "New York Times",
                            			showSourceTitle: true,
                            			showPublishDate: true
                            if (typeof module !== “undefined”) {module.exports = config;}
                              A Former User
                              I have tried reinstalling & I am now getting this from the terminal
                                A Former User
                                After reinstalling i now have it working thankyou. I just have a few more questions:
                                How do i edit it to show UK holidays etc?
                                Is there a html file to edit so i can add a google calender to it? And how to i get it to autoload on boot?
                                J Mykle1M 2 Replies Last reply Reply Quote 0
                                  j.e.f.f Project Sponsor Module Developer @Guest
                                  @PCPAYN3 Instructions for setting up autostart here: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                    In your config.js file, in the calendar module entry, you can either add this OR edit the existing entry for US-Holidays. If you do not want the US Holidays calendar then simply change the end of the url to UK-Holidays.ics.
                                    url: "webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics"
