Solved After update to Mirror to 2.1.3 - no working Whitlist
I change my config.js in:
/*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/ var config = { port: 8081, address:"0.0.0.0", electronOptions: { }, ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.20/24" ], language: "de",
and now it works again.
I have now access to MMM-Remote-Control from my HomePC again …
Sandy2503
@Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
Adding
address: “0.0.0.0”,
to the config.js also did the trick for me.
Thanks!
As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
var config = {
port: 8080,
address:“”,
language: “de”,
timeFormat: 24,
units: “metric”,Any ideas?
hi!
maybe wrong config.js ??
here is my working code:
var config =
address: “0.0.0.0”,
electronOptions: {}, ipWhitelist: [ "10.0.0.1/24", "::ffff:10.0.0.1/120", "127.0.0.1", "::ffff:127.0.0.1", "::1" ],
and so on…
greets
shotput2017 -
is this an acceptable configuration ?
address:"0.0.0.0",
or is it better specifying the actual server ip here ?
I put my config like this:
{ port: 1103, address: '0.0.0.0', electronOptions: { }, ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.113.60", "::ffff:192.168.113.22", "::ffff:192.168.113.97", "::ffff:192.168.113.29", "::ffff:192.168.113.103", "::ffff:192.168.113.66" ],
The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
i have the same problem
i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
but still i get no access.
Btw. its a raspberry pi zero with serveronly
@Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove
::ffff:
from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?@FreddeHamm Are you sure those CIDR numbers are correct?
When in doubt, check the output or logs (
pm2 logs MagicMirror
orpm2 logs mm
if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation. -
Same here, tried addres 0.0.0.0 and various things in the Whitelist.
A ping gives “destination unreachable”… SSH also doesn’t work.
Can someone please suggest ways to troubleshoot?
