    Mirror Not Working
    16 Posts 4 Posters 8.5k Views 3 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @aayush447
      @aayush447
      Can you post your terminal output?
      • A
        aayush447
        I Can’t It won’t let me do anything, just a black screen and mouse pointer. I can’t navigate to terminal or any other window
        • Mykle1M
          @aayush447
          When in black screen, press Alt, or Ctrl. You should get a menu bar at the top where you can quit MM. Then you can see your terminal
          • A
            aayush447
            Here’s the terminal output 0_1508845491480_Screen Shot 2017-10-24 at 5.14.06 PM.png
            • Mykle1M
              @aayush447
              Don’t know why you installed MM on your desktop.
              Also, did you install MM using sudo? That it not necessary or recommended.
              You can try running npm start in the MM directory, without sudo
              • Mykle1M
                I’m off to work. I will check back here later
                • A
                  aayush447
                  I installed the MM Directory on desktop then After navigating there I typed this “npm start” After that nothing happened
                  • axellejamousA
                    axellejamous
                    When you’re in the MagicMirror directory try going into the vendor file (cd vendor) and typing “npm install”. I had the same symptoms when I installed mine so it could be the same issue.
                    axellejamousA 1 Reply Last reply Reply Quote 0
                    • axellejamousA
                      axellejamous @axellejamous
                      @axellejamous said in Mirror Not Working:
                      Never mind. I realise I was running it with node serveronly and that works perfectly with 0 errors. However if I run it with npm start it’s still black.
                      • A
                        aayush447 @axellejamous
                        @axellejamous What Does ServerOnly Do?
                        • axellejamousA
                          axellejamous
                          • axellejamousA
                            axellejamous @aayush447
                            @aayush447
                            Severonly works perfectly, all modules come up like they should and no errors
                            • A
                              @axellejamous How to install that?
                              axellejamousA B 2 Replies Last reply Reply Quote 0
                              • axellejamousA
                                @aayush447
                                Ok. I seemed to have solved my issue, the MM works with npm start now.
                                Electron seemed to be causing the issue for me.
                                Try this:
                                and then:
                                Then just try running npm start in the MagicMirror directory.
                                I’m not sure why, but this solved it for me! Since you seem to have the same issue it might solve yours too.
                                  bhepler Module Developer @aayush447
                                  @aayush447 Serveronly is included with the MagicMirror framework. What it does is skip displaying the interface on the Raspberry Pi via Electron and the HDMI video output. You can still see the interface by pointing a web browser (especially the browser included with the Raspberry Pi operating system) at the Pi. But the Pi itself will still display the desktop and/or command prompt.
                                  This is especially useful for people who remote in to their Pi for development, multiple displays or remote access. For example, you could have one Pi run the MagicMirror framework and have a mirror in your bathroom, a display in your kitchen and a display in your man cave all showing the same output of the Pi.
                                  I use node serveronly during my development on my office PC. It lets me use a web browser to view the interface, which I can resize, move to a different monitor, etc. Otherwise, Electron would take over one entire monitor to display the output of the Magic Mirror framework.
