    690 Posts 77 Posters 3.1m Views 70 Watching
      @cowboysdude said in MMM-NOAA - Another Weather Module:
      Just a thought… I prefer the numbers… the icons don’t really tell me anything…
      Those are cool. The number makes it immediately apparent what the conditions are. Nice work! And thank you.
        Reotch2 @cowboysdude
        @cowboysdude Looks perfect. The biggest issue I had was the dark red not having contrast on the black screen. Thought the icons may be a viable fix, but this is honestly the better way to go.
        All this being said. If you are seeing be numbers and colors I was last week, you’re having a bad day. Maybe the best solution is just to color those readings the same as the orange tier. I don’t want to mess up your simple (and well-liked) format.
        As @Mykle1 stated below, Its easy to overlook how much time you put into this. I definitely appreciate and applaud your work.
        Thanks again.
        • cowboysdudeC Offline
          cowboysdude Module Developer @Reotch2
          @Reotch2 Thanks …
          I was thinking about putting the UV AQ as header in one line then the circles and numbers under each corresponding header…
            Description:
            Updated layout as it IS hard to see the color red on a black background :)
            Do a ‘git pull’ to update!
            Please follow Readme on Github!
            Screenshots:
            English
            Version 1.1.0
            Download:
            [card:cowboysdude/MMM-NOAA]
            Mykle1M R 2 Replies Last reply Reply Quote 1
              What’s that?
                @cowboysdude
                Since I’m the one that asked for it… I’ll be the first to say “I was wrong”. got a “yellow” reading this morning, and it was almost impossible to read on the white background.
                Cowboysdude… you’re awesome… and I’m sorry to waste your time, but think you had it right the first time…
                Anyone else want to chime in on their preference?
                cowboysdudeC 2 Replies Last reply Reply Quote 1
                • tbbearT Offline
                  tbbear Module Developer
                  Sorry i agree with @Reotch2 i also dont like this new version, the text was much better cause i use the module on the right side now it took too much space.
                  Robert the Bear
                    cowboysdude Module Developer @tbbear
                    @tbbear Yes that’s a css issue that I have to look at… dumb me only tested the left side :)
                      @Reotch2 said in MMM-NOAA - Another Weather Module:
                      @cowboysdude
                      Well we can always change the red to a shade off of red so it’s easier to read :)
                      And you’re not bothering me nor are you wasting my time… I was brought up this way… if someone needs your help 100 times you help them 100 times… :)
                      I want to try something and I"ll post it you guys let me know what you think… it’ll be a little bit later tonight [US EST Time]…
                        @Reotch2 How about this?
                        If the colors are an issue we can always use different shades to make it more readable :)
                        R 1 Reply Last reply Reply Quote 2
                        • tbbearT Offline
                          this looks good
                          Robert the Bear
                            @tbbear What do you also think about putting the Humidity and Barometer on the same line as well?
                            • tbbearT Offline
                              @cowboysdude thats ok as long as its not too big
                              Robert the Bear
                                @tbbear I’ll come up with a prototype you can check it out :)
                                • tbbearT Offline
                                  i will !!!
                                  Robert the Bear
                                    Think for now we’ll see how they like the change I just made above and let the other stuff stay as is :)
                                      @cowboysdude Looks solid… It’s definitely more streamlined. I’d say IF you decide to combine Humidity and BARO, you may need to use a “teardrop icon” for humidity and shorten Barometer to “BARO”, that should make the line length manageable.
                                      But again, that’s an IF you decide to make further changes. I’d wait on more feedback than just me. We saw where my last input got us… haha…
                                      Passing thought on RED AQI/UV. Maybe it’s another opportunity for the flash? just a thought.
                                      -Rich
                                        Keep changing it. I’ll let you know when to stop.
                                        • N Offline
                                          nobita @cowboysdude
                                          @cowboysdude I have question in MMM-NOAA.css
                                          i try to adjust many time but can’t do it, can u help me,please?
                                          1. how to increase space? (as photo)
                                          2. how to adjust font size and color?(as photo)
                                            This is what it will look like after I make the rest of the changes later tonight…right now I have to go to my real job ;)
                                            left:
                                            right:
                                            There may be some changes to the language files that I will ask each of you to do…as I just really don’t have time… :) BUT you are building a mirror so your active participation is required :)
                                            • 10
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
