    MMM-Events
    25 Posts 9 Posters 20.7k Views 9 Watching
      Mykle1 Project Sponsor Module Developer @nhl
      @nhl said in MMM-Events:
      Is there a way to keep the header from fading in and out when the event changes?
      I think I was asleep when you first asked this question.
      You can set the animationSpeed: in your config to 0
      That should eliminate the fade altogether (for the entire module), not just the header
        Mykle1 Project Sponsor Module Developer @poekel
        @poekel said in MMM-Events:
        Can that be done with the MMM-events module ?
        Can i take the event from a webserver or local file ?
        That probably depends on the data format. If it’s .ics then it would work in your calendar module. If it’s json, or maybe xml, then it might be usable, but even then much modification would have to be done to the module. As it is, you couldn’t just pop it in and have it display as you described it above
          stephenmelody
          I have an issue with this module on my mirror, it just shows “upcoming events…” on the screen but nothing else.
          Here’s my code, I’ve changed my API key so it’s not publicly shared.
          Am I doing something wrong?
              module: 'MMM-Events',
              position: 'bottom_left',
                  city: "Pittsburgh, PA",            // Your City
                  eventType: "music_country",
          //      eventType: "sports",
          //      eventType: "food",
          //      eventType: "comedy",               // Choose from Events List below
                  when: "This Week",                 // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
                  mode: "noFrame",                   // "Frame" or "noFrame" (around picture)
                  apikey: "QbpDjd6SXXXXXXXX",
                  rotateInterval: "6000",     // New Event Appears every 5 minutes
                  useHeader: "True",                 // Set to true if you want a header
                  header: "Upcoming Events",
                  animationSpeed: "3000",              // Event fades in and out
                  picture: "false"                     // true, false = no image
          0_1509371886264_bfcf6860-d3fe-4941-9278-36870ac3bd07-image.png ![alt text](image url)
            Mykle1 Project Sponsor Module Developer @stephenmelody
            @stephenmelody said in MMM-Events:
            useHeader: true, (no quotes, no capital T)
            rotateInterval: "6000", is only 6 seconds. You might want to raise this
            Otherwise, it works for me with my API key and corrections:
            			apikey: "YOUR API KEY",
            			rotateInterval: "20000",     // New Event Appears every 5 minutes
            			useHeader: true,                 // Set to true if you want a header
              stephenmelody @Mykle1
              @Mykle1 Thanks, I changed my code to yours but I’m still not getting anything… is there anything else I can do to debug?
                You can post any errors from your teminal or console (from Dev Tools) so we can see what is going on there. You can see that it works for me using your config that I corrected. Are you absolutely sure that your API key is correct and entered correctly within the config entry?
                  @Mykle1 100% sure the API key is correct… I’m not sure about how to access the dev tools, pardon my naivety.
                  I could give you access to the device if you’d have a couple of minutes to look?
                    stephenmelody
                    Scrap my messages… it started working after a reboot…
                    However, is it possible to have multiple categories?
                    does this:
                    eventType: "food",
                    or this:
                    eventType: ["music_country", "sports", "food", "comedy"]
                    work?
                      stephenmelody @stephenmelody
                      I just tried it, an array works well!!
                        That’s good news! I’m glad it’s working for you. It happens to be one of my favorite modules. I hope you enjoy it and find it useful, too.
                          albertlwj
                          is there anyway for it to show more than 1 event at a time?
                            Mykle1 Project Sponsor Module Developer @albertlwj
                            @albertlwj said in MMM-Events:
                            As it is, no. It was designed to loop through the events so as to minimize the space it occupies on the mirror. I don’t have any plans to modify it from it’s current state but feel free to modify it yourself. If you make that an option then you can send a PR to the repo and I’ll add it to the module.
                            In any case, thanks for your interest and I hope you enjoy the module.
                            Peace.
                              albertlwj
                              alright thanks! i’ll see if i manage to tweak it :D
                              it’s a great module thanks for all the work!
                                As per @E3V3A @thiagofneves
                                You can choose multiple eventTypes at the same time using this format:
                                "music_electronic,music_jazz,music_vocal,music_rap_hiphop"
                                I do believe that is posted somewhere above. :-)
                                README file updated on git.
                                Thanks for the heads up guys. :-)
                                  benderstwin
                                  I would love the ability to add a layout, like 2 events sidexside. Is this possible?
                                  I’d like to also create another profile that just shows a list of events for the next 30 days or so. Can this be done?
                                  Thank you,
                                    I’m sure those things can be achieved although I don’t envision the module that way. Please feel free to fork the module and make any changes you like and submit a PR. Have fun.
                                    • O Offline
                                      onetwankyfive
                                      Would it be possible to only display events for a particular venue?
                                        Mykle1 Project Sponsor Module Developer @onetwankyfive
                                        @onetwankyfive said in MMM-Events:
                                        Perhaps but I’m a bit busy with other things at the moment. Feel free to fork the module and make any changes you like. :thumbsup:
                                          RIKKO14
                                          Est ce que ce module fonctionne toujours ? car le lien pour obtenir l’the apykey ne fonctionne plus…
                                          https://api.eventful.com/keys/new
                                          • sifuhallS Offline
                                            sifuhall
                                            Since the Eventful API has been terminated has anyone considered making something similar for PredictHQ or something else?
