    MMM-xiaomi - Temperature and Humidity from your smarthome
    141 Posts 27 Posters 234.1k Views 27 Watching
    • cowboysdudeC Offline
      I’m in the US and I ordered from Gearbest and did not will not again… I put in my order and it I never got what I ordered so I put a claim in against them … they told me ‘well we now have the items in stock so if you drop your claim…’
      According to their site the stuff I ordered was already in stock… when I ordered them.
      I said uhhhhhh no. So they refunded me…and I ordered them from another company and hopefully they’ll be here next week :) They shipped them right out and gave me a tracking number… Gearbest… I don’t trust them.
        cowboysdude Module Developer @mirko3000
        @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
        window sensors
        What is the module your door/window sensors? I find two but not sure which ones to use here.
          Albert2002
          I have the Xiaomi. I don’t think there is a difference apart from the design:
          Xiaomi vs Aqara door/window sensors
            barnosch
            So.
            At least 4 Temperature sensors arrived today. Waiting for the gateway which comes another way.
            looks great @mirko3000
            Really looking forward for it.
            I hate waiting for stuff…
              mirko3000 @barnosch
              Ok, get ready to test the latest version! I kept the current table view for now, still planning to also support a grid view soon.
              New features:
              • Listens to update events of the sensors instead of refreshing the whole list all x seconds
              • Reorganized your smart home structure, introducing rooms with sensors
              • Shows ventilation recommendation, window open state and light on state per rooms
              Looking forward to get some feedback. As I do not have any lights at the moment this is untested.
              Not for the update: you will need to execute “npm install” again as I had to fork the miio library to support the events (maybe even delete the node_modules folder in your modules directory). Also you need to update your module configuration!
              K 1 Reply Last reply Reply Quote 1
                WOW this is really awesome! Thank you for your hard work. Looking forward to getting my sensors… should be here next week I hope
                  Albert2002
                  Its working for me. No errors in the logs or the brower debug. Well done & thank you for your work!
                  I can test it whit only one sensor so far. Waiting for the others.
                  • K Offline
                    kasperb @mirko3000
                    @mirko3000 This looks like a great module, and can’t wait to try it! Just ordered the gateway, and will be ordering some temperature sensors soon.
                    Will the Smart Air Pressure Temperature Humidity Environment Sensor work with this module as well? Like this one on: Aliexpress
                    Thanks!
                      Albert2002
                      Haven’t seen, that the Aqara sensor has pressure as well! They both has been on sale last week for less than 6€ on GB.
                      I have taken the Xiaomi…
                        mirko3000 @kasperb
                        @kasperb Yes I am pretty sure they work as well. Did not see those before, looks interesting though I am not sure what to use the air pressure values for!? :)
                        • K Offline
                          kasperb @mirko3000
                          @mirko3000 Thanks! And agreed, I’ve opted for the regular temperature sensor instead.
                          • T Offline
                            trividar
                            could someone help me? I installed it how described but it didn’t show any informations on the MM just temperature/humidity. At the beginning i see connecting to xiaomi getway and after that nothing. In the MM out i get this:
                            Found device with ID 158.... of type sensor
                            but no errors.
                            Once I saw this, but just once (but nothing on the mirror):
                              mirko3000 @trividar
                              So technically your gateway and sensors seem to be working properly. What exactly is the problem? Did you configure your rooms and devices as described? Do you see anything on the MM? “just temperature/humidity” - that is actually the main feature :)
                              • T Offline
                                trividar
                                Hi mirko,
                                the problem is, that i did’t see any values on the MM:
                                and also something strange, if i start this module my WunderGround module change the top of it:
                                if I disable this module it looks like usual, i changed in other positions but the same things.
                                Why is this happen?
                                What you mean with: “Did you configure your rooms and devices as described?” I did exactly what was on github.
                                THX a lot for your help
                                  mirko3000 @trividar
                                  Can you post the configuration for the Xiaomi module? You need to provide a list of rooms, each of one with the assigned device IDs:
                                  	            rooms:  [
                                  		            	sortOrder: 40,
                                  		            	devices : ['158d010171840d', '158d00016cddae']
                                  		            	sortOrder: 70,
                                  		            	devices : ['158d0001735ac2']
                                  Also please check that you use the latest version.
                                  About that WunderGround module: I need to test that myself, not sure why there are such kind of interferences.
                                  • T Offline
                                    trividar
                                    I have the latest version and thats my config:
                                    		module: 'MMM-xiaomi',
                                    		position: 'bottom_left',
                                    		header: 'Temperature / Humidity',  // This is optional
                                    			interval: 30,
                                    			gatewayIP: '192.168.1.128',
                                    			gatewayToken: '65764848557cccc2170d1fd8c06b32cb',
                                    			devices: [{
                                      mirko3000
                                      That is the config for the old version. Please check the README carefully:
                                      https://github.com/mirko3000/MMM-xiaomi#configuration-options
                                      			interval: 30,
                                      			rooms: [{
                                      			       name: 'Schlafzimmer temp' ,
        devices:[ '158d0001dfdb14'],
        sortOrder: 1
                                      • T Offline
                                        trividar
                                        oooo shit…my mistake! It works now… thank’s a lot for your help…your a hero.
                                        please chack this with WunderGround it would be really nice…
                                        THANKS A LOT!
                                          Albert2002
                                          I’ve pulled the latest update today. Since this i don’t see the temperature / humidity any more. I don’t have any errors in my logs depending MMM-xiaomi. The config.js is the same as well. Browser debug without errors. The only error which is new in my log is about the module nerwork scanner.
                                          By the way: Do I add the window sensors the same way as the Temperature sensor? Which lights are supported?
                                          empty
                                          mm error:
                                          TypeError: Cannot read property 'network' of undefined
                                              at Class.scanNetworkMAC (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                                              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                                              at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:103:11)
                                              at emitTwo (events.js:106:13)
                                              at Socket.emit (events.js:194:7)
                                              at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:514:12
                                              at _combinedTickCallback (internal/process/next_tick.js:73:7)
                                              at process._tickCallback (internal/process/next_tick.js:104:9)
                                          mm out:
                                          > magicmirror@2.1.3 start /home/pi/MagicMirror
                                          > sh run-start.sh
                                          Starting MagicMirror: v2.1.3
                                          Loading config ...
                                          Loading module helpers ...
                                          Module helper loaded: MMM-Remote-Control
                                          Module helper loaded: MMM-DWD-WarnWeather
                                          Module helper loaded: MMM-PNews
                                          Module helper loaded: internet-monitor
                                          Module helper loaded: MMM-MovieListings
                                          Module helper loaded: MMM-Fuel
                                          Module helper loaded: MMM-NetworkScanner
                                          Module helper loaded: MMM-nasaastropic
                                          Module helper loaded: MMM-SystemStats
                                          No helper found for module: MMM-Carousel.
                                          Module helper loaded: MMM-Events
                                          Module helper loaded: MMM-xiaomi
                                          All module helpers loaded.
                                          You're using a full whitelist configuration to allow for all IPs
                                          Server started ...
                                          Connecting socket for: MMM-Remote-Control
                                          Starting node helper for: MMM-Remote-Control
                                          Connecting socket for: MMM-DWD-WarnWeather
                                          MMM-DWD-WarnWeather helper started...
                                          Connecting socket for: MMM-PNews
                                          Starting module: MMM-PNews
                                          Starting module: newsfeed
                                          Connecting socket for: internet-monitor
                                          internet-monitor helper started ...
                                          Connecting socket for: MMM-MovieListings
                                          MMM-MovieListing helper started...
                                          Connecting socket for: MMM-Fuel
                                          Starting module helper: MMM-Fuel
                                          Connecting socket for: MMM-NetworkScanner
                                          Starting module: MMM-NetworkScanner
                                          Connecting socket for: MMM-nasaastropic
                                          Starting node helper: MMM-nasaastropic
                                          Connecting socket for: MMM-SystemStats
                                          Connecting socket for: MMM-Events
                                          Starting node_helper for: MMM-Events
                                          Connecting socket for: MMM-xiaomi
                                          Starting xiaomi helper
                                          Launching application.
                                          MMM-NetworkScanner received SCAN_NETWORK
                                          MMM-NetworkScanner is performing arp-scan
                                          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/basic.ics - Interval: 300000
                                          Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                                          Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                                          starting internet monitor node helper
                                          MMM-NetworkScanner received CONFIG
                                          astro helper: config received
                                          retrieveAndUpdate()
                                          Sat Nov 18 2017 10:10:53 GMT+0100 (CET): Triggering Xiaomi Gateway connect
                                          NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/20171117dawnTezel1200c.jpg
                                          Found device with ID 158d000119fcb2 of type magnet
                                          Found device with ID 158d00015aa973 of type controller
                                          Found device with ID 158d00015736a8 of type sensor
                                            mirko3000 @Albert2002
                                            Can you post your configuration for the module? You now need to define your rooms, it looks like the module simply does not find any room to show.
                                            And yes, you add all devices to your room configuration, the module can identify the type and handle it correspondingly.
                                            BTW: suggest tracking issues on the github issue tracker: https://github.com/mirko3000/MMM-xiaomi/issues
                                            • 3 / 8
