MMM-MyCommute
I have kind of a weird question, but I haven’t had a chance to poke around and try for myself yet and I’m coming up on when I promised I’d have things done…
Is it particularly possible to reverse the module? I’m assuming I’d need a second instance with the modified code, but I’d like travel times to various places in the morning, and then midday it would switch to the travel times back home from those same spots. In my mind it seems like it might be as simple as swapping the parameters in the getData (or equivalent) function for making the API call, but I’m not entirely sure.
Does that seem about right? If it entails major code restructuring then I may just abort mission, but if not, that’d be a really cool feature to have since people are in and out of my house all over the day.
@pyrosmiley you can do this with two instances of the module (i.e.: make two configurations for
MMM-MyCommutein yourconfigure.jsfile), and then use built-in scheduling parameters to have one show in the morning and hide in the afternoon, and the second to hide in the morning and show in the afternoon. The first module will have your drive from home to work configured, for example, and the second will have the reverse configuration.Does that make sense?
@j.e.f.f Yeah, that makes sense, although won’t that only let me do it with a single destination? I have four I’m trying to track, so for the second instance I need to essentially have four origins and a single destination.
@pyrosmiley yeah it’s a little kloodgy, but you can get it to work by making five instances.
Sorry for english.
I can’t display icon of differents mode (driving, …) in my module. I can see just label and times. But it’s working well. I add a color but same problem. Thanks for help.apikey: ‘API KEY’,
origin: ‘XXXX’,
startTime: ‘00:00’,
endTime: ‘23:59’,
hideDays: [],
showSummary: true,
colorCodeTravelTime: true,
moderateTimeThreshold: 1.1,
poorTimeThreshold: 1.3,
nextTransitVehicleDepartureFormat: “[next at] h:mm a”,
travelTimeFormat: “h [h] m [min]”,
travelTimeFormatTrim: “left”,
pollFrequency: 10 * 60 * 1000, //every ten minutes, in milliseconds
destinations: [
destination: ‘Avenue de la Tour Royale, 83000 Toulon’,
label: ‘Boulot’,
mode: ‘driving’,
waypoints: ‘83220 Le Pradet | Auberge Sainte Marguerite’
destination: ‘Gare de Toulon, 83000 Toulon’,
label: ‘Gare Toulon’,
mode: ‘driving’,
color: ‘#82E5AA’
destination: ‘Aéroport Marseille Provence’,
label: ‘Aéroport Marignane’,
mode: ‘driving’
destination: ‘31000 Toulouse’,
label: ‘Toulouse’,
mode: ‘driving’
destination: ‘33000 Bordeaux’,
label: ‘Bordeaux’,
mode: ‘driving’
@chassain-0 Your config works for me, but since you pasted code in the body of the message I needed to correct all of the quotes and such. Hard to tell if it was that kind of an error.
Try this config and let me know if it works for you (I picked a hotel that was nearby your destinations as the origin)
{ module: "MMM-MyCommute", position: "top_left", header: "Traffic", classes: "default everyone", disabled: false, config: { apikey: "...", origin: "La Villa Gallici - Hotel 5 étoiles - Aix en Pce", startTime: "00:00", endTime: "23:59", hideDays: [], showSummary: true, colorCodeTravelTime: true, moderateTimeThreshold: 1.1, poorTimeThreshold: 1.3, nextTransitVehicleDepartureFormat: "[next at] h:mm a", travelTimeFormat: "h [h] m [min]", travelTimeFormatTrim: "left", pollFrequency: 10 * 60 * 1000, //every ten minutes, in milliseconds destinations: [ { destination: "Avenue de la Tour Royale, 83000 Toulon", label: "Boulot", mode: "driving", waypoints: "83220 Le Pradet | Auberge Sainte Marguerite" }, { destination: "Gare de Toulon, 83000 Toulon", label: "Gare Toulon", mode: "transit", color: "#82E5AA" }, { destination: "Aéroport Marseille Provence", label: "Aéroport Marignane", mode: "driving" }, { destination: "31000 Toulouse", label: "Toulouse", mode: "driving" }, { destination: "33000 Bordeaux", label: "Bordeaux", mode: "driving" } ] } }, -
@j.e.f.f thank you. But same problem with no icon. Maybe an error with apikey ?
@chassain-0 Probably not… a bad api key would just limit the module’s functionality, but you should at least see an icon. Can you verify that you have the file
icon_sprite.svgin yourMMM-MyCommutedirectory? -
@j.e.f.f yes I have and check
@BanksyPaint @j.e.f.f
Hi there i am having the same exact issue with the MyCommute module.
It was working fine until i got the notification of the update than no more displaying of my commutes and i see a spike in cpu usage to almost 100% .
I have cheked my google API key and it is current … i did the git pull commant do update and it did not fix the issue … i npm unistalled it removed it completely went back and git clone again and npm install and still the same issue
Like i said it was working just fine before and nothing has changed on the MM config file other than adding a couple of new modules.
What do you think it is happening??
Any help will be greatly appreciated and it really is a great module -
LOL never mind i got it… I am retarted :) :)
i was testing it on Saturday and Sunday so it was just not displaying since i still had the 0 and 6 hide days LOL
thank you
Great work -
@richland007 ;)
Hey,
this is a great module. love it. but i got some issues by using the alternative routes.
the “avoid” feature works, but it would be nice if i could see all available routes in one destination. With “available routes” i mean the alternative routes that google maps shows you normally.i tried like this:
{ module: 'MMM-MyCommute', position: 'top_left', header: 'Verkehrslage', classes: 'default everyone', config: { apikey: 'xxx_hide_xxx', origin: 'xxx_hide_xxx', destinations: [ { destination: 'xxx_hide_xxx', label: 'Arbeit', mode: 'driving', alternatives: 'true', // < thats what i mean!!! time: null }, { destination: 'xxx_hide_xxx', label: 'Arbeit', mode: 'driving', avoid: 'highways', time: null }, { destination: 'xxx_hide_xxx', label: 'xxx_hide_xxx', mode: 'driving', time: null }, ] } },but it looks just like this:
any idea?
@cruunnerr the readme says, that
alternativeshas to be used withshowSummary: trueotherwise it will not have an effect -
i thought it is set to “true” by default.
i tried it like this, but still not working:
{ destination: 'xxx_hide_xxx', label: 'Arbeit', mode: 'driving', showSummary: 'true', alternatives: 'true', time: null },edit:
still checked the “MMM-MyCommute.js”showSummary is true
@cruunnerr make sure you’ve got your API key set correctly. Without it you’ll only get limited functionality. Make sure to set property name as
apikey. Some people have tried to useapi_keyorapiKey, neither of which will work. -
its correct.
intentionally i typed in a wrong apikey, what effects an error message when module loads up.
its this format and its correct:
apikey: 'ABCDabcd1234abcd5679',edit:
i used the “standard api key” from google. there was also a “premium api key”, but this one i don’t need, right?
to make sure that I express myself correctly… i want it to looks like this:
@cruunnerr standard API key is fine.
I’m currently in the process of moving my family overseas, so I don’t have a lot of time to help troubleshoot this at the moment. Send me a private message with your complete config and i’ll try and troubleshoot it on my side when I get a few minutes.
Might be a few days, please be patient :)
For sure this is no problem. Take as much time as u need for your family. thats much more important!
didn’t find a private message option, just a chat^^ sorry for that. I post my config right here.
just for info: I didn’t touch the MMM-MyCommute.js, so its just this one i need: https://github.com/jclarke0000/MMM-MyCommute/blob/master/MMM-MyCommute.js
So here is my full config:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "0.0.0.0", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["192.0.0.0/3", "::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "de", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: 'MMM-Remote-Control' // uncomment the following line to show the URL of the remote control on the mirror // , position: 'bottom_left' // you can hide this module afterwards from the remote control itself }, { module: 'MMM-SystemStats', position: 'top_center', // This can be any of the regions. classes: 'small dimmed', // Add your own styling. Optional. config: { updateInterval: 5000, animationSpeed: 0, align: 'right', // align labels //header: 'System Stats', // This is optional }, }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: 'calendar', header: 'Chris Kalender', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: '*private*' }, { symbol: 'calendar-check-o ', url: 'http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics' }, ] } }, { module: 'MMM-MyCommute', position: 'top_left', header: 'Verkehrslage', classes: 'default everyone', showSummary: 'true', config: { apikey: '*private*', origin: '*private*', destinations: [ { destination: '*private*', label: 'Arbeit', mode: 'driving', alternatives: 'true', time: null }, { destination: '*private*', label: '*private*', mode: 'driving', time: null }, ] } }, // { // module: "compliments", // position: "lower_third" // }, // { // module: "currentweather", // position: "top_right", // config: { // location: "New York", // locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt // appid: "YOUR_OPENWEATHER_API_KEY" // } // }, // { // module: "weatherforecast", // position: "top_right", // header: "Weather Forecast", // config: { // location: "New York", // locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt // appid: "YOUR_OPENWEATHER_API_KEY" // } // }, { disabled: false, module: 'MMM-NOAA', position: 'top_right', config: { apiKey: "*private*", // https://www.wunderground.com/weather/api select the middle plan... useAir: false, // set to false if you do not want to use Air Quality Index airKey: "*private*", // IF you want Air Quality Index pws: "*private*", // go here to find your pws: https://www.wunderground.com/wundermap showClock: false, // Hides or shows clock dformat: false, // for M/D/YYYY format, false for D/M/YYYY format: "24", // 12 or 24 hour format.. will default to 12 hour if none selected. ampm: false, // to show AM and PM on Sunrise/Sunset time showGreet: false, // deafult is false - to show greeting under clock and above date name: "", // Your name showWind: false, showDate: false, showForecast: true, //show bottom 3 day forecast flash: true, //Today in forecast flashes halo showUV: true, //show UV index showBar: true, // show Barometer showHum: true, //show Humidity level position: 'top_right', //whatever you have in above position must also be here alert: true //show weather alerts default is true } }, { module: 'MMM-Globe', position: 'top_right', config: { style: 'natColor', imageSize: 200, ownImagePath:'', updateInterval: 10*60*1000 } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Tagesschau Themen", url: "http://www.tagesschau.de/xml/rss2" } ], showSourceTitle: true, showPublishDate: true, showDescription: true, updateInterval: 25000, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}Thank u very much for helping :)
@cruunnerr sorry yes. Chat was what I meant. Send me your entire MMM-MyCommute config without hiding anything so I can test your exact config.
