    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 571.0k Views 43 Watching
      Southcity
      great work!
      I’m looking for a way to change the Team Name. For example “Red Bull Leipzig” is wrong, it must be Rasenballsport Leipzig. Is there a way to change the Team Name?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Southcity
        @Southcity the data is coming from an api endpoint, where you registered for the api key, so you could write them a mail if they can fix it :)
          Brandlin
          hi
          i am having trouble with the soccer module.
          I can get the current english premier league and i can show a reduced number of teams. But i cannot get the the focus to work. I have tried multiple teams but none work.
          my code is
                                  module: "MMM-soccer",
                                          api_key: "... censored ...",
                                          show: "ENGLAND",
                                          leagues: {"ENGLAND": 445},
                                          focus_on: {"ENGLAND": "Newcastle United FC"},
                                          max_teams: "5"
          Dont judge me on the team - its my father’s and this is a christmas present.
          what am i doing wrong?
          Also is there a way to update the league to the 18/19 season when the ext season starts or do i have to edit the config then?
            Brandlin
            sorry, i should have added that if when i run the code above the module clearly loads because it shows the headings but the table is blank. If i comment out the focus_on command the module works fine and shows the top 5 teams (as expected)
              Mykle1 Project Sponsor Module Developer @Brandlin
              @Brandlin
              This is a complete guess so forgive me if it does not correct your problem. I don’t use this module.
              try
              focus_on: "ENGLAND": "FC Newcastle United"},
              I’ve noticed from the other examples above that the FC comes before the team name. It’s worth a shot.
                Brandlin @Mykle1
                @Mykle1 hi, thanks for the suggestion, however in england the FC goes after the team name, in germany (which are most of the examples) the FC comes first. I am also assuming that the name i need to use is exactly as it is presented in the league table. Note, I have tried the focus_on command with every team name with no success.
                  @Brandlin
                  Again, I don’t use this module. However, it does matter to the API how you enter the team name, even if in England (or anywhere else) the proper way is Newcastle United FC. Have you tried focus on another team from another country? If it works then the problem lies with the API or the formatting of the name in the config.
                  Note: Newcastle is my favorite beer. :-)
                    Brandlin @Mykle1
                    @Mykle1 hi, thanks for the suggestion. I’ve just tried a few teams in the format focus_on: {"ENGLAND": "FC team name"}, and it makes no difference.
                    logically I would expect to use the team name exactly as displayed - which is “Newcastle United FC”. Otherwise how would anyone know what team name to use?
                    Newcastle United FC
                    Newcastle United
                    Newcastle Utd FC
                    Newcastle Utd
                    Newcastle
                    FC Newcastle United
                    FC Newcastle Utd
                    FC Newcastle
                    Magpies
                    are all different …
                      strawberry 3.141 Project Sponsor Module Developer @Brandlin
                      @Brandlin you are right, you should use Newcastle United FC as thats the value it gets compared to from the API. Can you try and set max_teams: 5
                      • L Offline
                        layman_smiles
                        Wondering if someone can help.
                        Having the same issue that a few people have add around the focus_on tool.
                        Here’s my code:
                            module: 'MMM-soccer',
                            position: 'bottom_right',
                                        colored: true,
                                        show: 'ENGLAND',
                                        max_teams: '5',
                                        focus_on: {"ENGLAND": "Arsenal FC"}
                        Is there something I am doing wrong?
                        I have tried a few of the suggestions made before around the position of the FC e.g. ‘FC Arsenal’ and changing the max_teams line to (max_teams: 5), and none of the above have worked.
                          strawberry 3.141 Project Sponsor Module Developer @layman_smiles
                          @layman_smiles the api returns Arsenal FC so that should be the correct value and max_teams should be definetely without quotes. I will try and debug after work.
                          • L Offline
                            layman_smiles @strawberry 3.141
                            @strawberry-3.141 cheers man. i will remove the quote from the max_teams section, and wait to see what you find.
                              @layman_smiles as soon as i removed the quotes, I got the expected table
                              • L Offline
                                @strawberry-3.141 cheers mate, working as it should now. Thanks for looking into this for me
                                • H Offline
                                  Henrik
                                  Hi @strawberry-3.141,
                                  Really nice module! I have a request, if I may: It would be really good if there were an option to automatically cycle between a few leagues, instead of having to do it through voice control (which I don’t have!). Would you mind adding this?
                                  Thanks in advance!
                                    strawberry 3.141 Project Sponsor Module Developer @Henrik
                                    @Henrik sorry I dont plan to add new feature to it, but feel free to send a pull request
                                    H 1 Reply Last reply Reply Quote 1
                                    • H Offline
                                      Henrik @strawberry 3.141
                                      @strawberry-3.141 Ok! I just might do that when time permits. :)
                                        Fixed icons for german bundesliga and italian serie a
                                        also updated league codes
                                        [card:fewieden/MMM-soccer]
                                        • F Offline
                                          fabbr
                                          No icons for the Campeonato Brasileiro da Série A ?
                                          How can I add those? I would be glad to contribute and upload the code/files to git.
                                            strawberry 3.141 Project Sponsor Module Developer @fabbr
                                            @fabbr if you can send me the exact name from the API and a link to a SVG version of the logo, then I can add it
                                            • 10
                                            • 11
                                            • 7 / 11
