    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Brandlin
      @Brandlin
      This is a complete guess so forgive me if it does not correct your problem. I don’t use this module.
      try
      focus_on: "ENGLAND": "FC Newcastle United"},
      I’ve noticed from the other examples above that the FC comes before the team name. It’s worth a shot.
      B 1 Reply Last reply
        Brandlin @Mykle1
        @Mykle1 hi, thanks for the suggestion, however in england the FC goes after the team name, in germany (which are most of the examples) the FC comes first. I am also assuming that the name i need to use is exactly as it is presented in the league table. Note, I have tried the focus_on command with every team name with no success.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Brandlin
          Again, I don’t use this module. However, it does matter to the API how you enter the team name, even if in England (or anywhere else) the proper way is Newcastle United FC. Have you tried focus on another team from another country? If it works then the problem lies with the API or the formatting of the name in the config.
          Note: Newcastle is my favorite beer. :-)
            Brandlin @Mykle1
            @Mykle1 hi, thanks for the suggestion. I’ve just tried a few teams in the format focus_on: {"ENGLAND": "FC team name"}, and it makes no difference.
            logically I would expect to use the team name exactly as displayed - which is “Newcastle United FC”. Otherwise how would anyone know what team name to use?
            Newcastle United FC
            Newcastle United
            Newcastle Utd FC
            Newcastle Utd
            Newcastle
            FC Newcastle United
            FC Newcastle Utd
            FC Newcastle
            Magpies
            are all different …
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Brandlin
              @Brandlin you are right, you should use Newcastle United FC as thats the value it gets compared to from the API. Can you try and set max_teams: 5
              • L
                layman_smiles
                Wondering if someone can help.
                Having the same issue that a few people have add around the focus_on tool.
                Here’s my code:
                    module: 'MMM-soccer',
                    position: 'bottom_right',
                                colored: true,
                                show: 'ENGLAND',
                                max_teams: '5',
                                leagues: {"ENGLAND": 445},
                                focus_on: {"ENGLAND": "Arsenal FC"}
                Is there something I am doing wrong?
                I have tried a few of the suggestions made before around the position of the FC e.g. ‘FC Arsenal’ and changing the max_teams line to (max_teams: 5), and none of the above have worked.
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @layman_smiles
                  @layman_smiles the api returns Arsenal FC so that should be the correct value and max_teams should be definetely without quotes. I will try and debug after work.
                  L 1 Reply Last reply
                  • L
                    layman_smiles @strawberry 3.141
                    @strawberry-3.141 cheers man. i will remove the quote from the max_teams section, and wait to see what you find.
                    • strawberry 3.141S
                      @layman_smiles as soon as i removed the quotes, I got the expected table
                      • L
                        @strawberry-3.141 cheers mate, working as it should now. Thanks for looking into this for me
                        • H
                          Henrik
                          Hi @strawberry-3.141,
                          Really nice module! I have a request, if I may: It would be really good if there were an option to automatically cycle between a few leagues, instead of having to do it through voice control (which I don’t have!). Would you mind adding this?
                          Thanks in advance!
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Henrik
                            @Henrik sorry I dont plan to add new feature to it, but feel free to send a pull request
                            H 1 Reply Last reply
                            • H
                              Henrik @strawberry 3.141
                              @strawberry-3.141 Ok! I just might do that when time permits. :)
                              • strawberry 3.141S
                                Fixed icons for german bundesliga and italian serie a
                                also updated league codes
                                [card:fewieden/MMM-soccer]
                                • F
                                  fabbr
                                  No icons for the Campeonato Brasileiro da Série A ?
                                  How can I add those? I would be glad to contribute and upload the code/files to git.
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @fabbr
                                    @fabbr if you can send me the exact name from the API and a link to a SVG version of the logo, then I can add it
                                    F 1 Reply Last reply
                                    • F
                                      fabbr @strawberry 3.141
                                      @strawberry-3.141 Here you can find the SVG, you’re looking for Serie-A: https://github.com/hugomiura/escudos-times-brasil-svg
                                      Here’s the API: [{“id”:444,“caption”:“Campeonato Brasileiro da Série A”,“league”:“BSA”,“year”:“2017”,“currentMatchday”:20,“numberOfMatchdays”:38,“numberOfTeams”:20,“numberOfGames”:380,“lastUpdated”:“2017-08-24T00:40:05Z”},
                                      The strong thing is that if I use:
                                      leagues: {“BRAZIL”: 444},
                                      for the configuration it doesn’t show up. but If I use:
                                      leagues: {“ENGLAND”: 444},
                                      What am I doing wrong?
                                      Thank you again, this is a great module!
                                      • strawberry 3.141S
                                        @fabbr When I go to that page it says svg files are invalid
                                        I need single svg files anyways (each team) with the api name of the team.
                                        Here are the current icon fixes per team https://github.com/fewieden/MMM-soccer/blob/master/MMM-soccer.js#L13-L18
                                        When you tried leagues: {'BRAZIL': 444} did you also set show: 'BRAZIL'
                                        • F
                                          @strawberry-3.141
                                          leagues: {'BRAZIL': 444} and show: 'BRAZIL' worked! I changed the icon fix to include all the teams for the 2017 and 2018 competition that is about to start! Thank you!
                                              icon_fixes: {
                                                  '1. FSV Mainz 05': 'https://upload.wikimedia.org/wikipedia/commons/d/d6/FSV_Mainz_05_Logo.png',
                                          		'FC Bayern München': 'https://upload.wikimedia.org/wikipedia/commons/1/1f/Logo_FC_Bayern_M%C3%BCnchen_%282002%E2%80%932017%29.svg',
                                          		'SPAL Ferrara': 'https://upload.wikimedia.org/wikipedia/de/e/e7/SPAL_Ferrara.svg',
                                          		'Benevento Calcio': 'https://upload.wikimedia.org/wikipedia/de/4/48/Benevento_Calcio_Logo.svg',
                                          		///Campeonato Brasileiro:
                                          		'Corinthians': 'https://upload.wikimedia.org/wikipedia/en/1/1f/Sport_Club_Corinthians_Paulista_Logo.png',
                                          		'Palmeiras': 'https://upload.wikimedia.org/wikipedia/commons/1/10/Palmeiras_logo.svg',
                                          		'Cruzeiro': 'https://upload.wikimedia.org/wikipedia/pt/3/36/EC_Noroeste.PNG',
                                          		'Santos FC': 'https://upload.wikimedia.org/wikipedia/commons/3/35/Santos_logo.svg',
                                          		'EC Flamengo': 'https://upload.wikimedia.org/wikipedia/en/c/c9/Flamengo_logo.svg',
                                          		'Vasco da Gama': 'https://upload.wikimedia.org/wikipedia/en/1/1a/ClubDeRegatasVascoDaGama.svg',
                                          		'Atlético Mineiro': 'https://upload.wikimedia.org/wikipedia/en/5/5f/Clube_Atlético_Mineiro_crest.svg',
                                          		'Chapecoense': 'https://upload.wikimedia.org/wikipedia/en/9/97/Associação_Chapecoense_de_Futebol_%282016%29.png',
                                          		'Grémio': 'https://upload.wikimedia.org/wikipedia/en/f/f1/Gremio.svg',
                                          		'Botafogo': 'https://upload.wikimedia.org/wikipedia/commons/5/52/Botafogo_de_Futebol_e_Regatas_logo.svg',
                                          		'Atlético PR': 'https://upload.wikimedia.org/wikipedia/commons/b/b3/CA_Paranaense.svg',
                                          		'Bahia': 'https://upload.wikimedia.org/wikipedia/en/b/b1/Esporte_Clube_Bahia_logo.png',
                                          		'Sao Paulo': 'https://upload.wikimedia.org/wikipedia/commons/6/6f/Brasao_do_Sao_Paulo_Futebol_Clube.svg',
                                          		'Fluminense FC': 'https://upload.wikimedia.org/wikipedia/en/9/9e/Fluminense_fc_logo.svg',
                                          		'Sport Recife': 'https://upload.wikimedia.org/wikipedia/en/4/45/Sport_Club_Recife.svg',
                                          		'EC Vitória': 'https://upload.wikimedia.org/wikipedia/en/4/49/Esporte_Clube_Vitória_logo.svg',
                                          		'Coritiba FC': 'https://upload.wikimedia.org/wikipedia/commons/3/38/Coritiba_FBC_%282011%29_-_PR.svg',
                                          		'Avaí SC': 'https://upload.wikimedia.org/wikipedia/commons/f/fe/Avai_FC_%2805-E%29_-_SC.svg',
                                          		'Ponte Preta': 'https://upload.wikimedia.org/wikipedia/commons/7/7e/Escudo_Oficial_Ponte_Preta.png',
                                          		'Atlético Goianiense': 'http://3.bp.blogspot.com/-Bm9JF0ZGdeQ/VR7uvQxyGLI/AAAAAAAAAj0/F-1Qss9wms0/s1600/atletico%2Bgo%2Bfirst.png',
                                          		//2018 New Teams:
                                          		'América': 'https://upload.wikimedia.org/wikipedia/commons/a/ac/Escudo_do_America_Futebol_Clube.svg',
                                          		'Ceará': 'https://upload.wikimedia.org/wikipedia/en/7/7d/Ceará_SC.png',
                                          		'Internacional': 'https://upload.wikimedia.org/wikipedia/commons/f/f1/Escudo_do_Sport_Club_Internacional.svg',
                                          		'Paraná': 'https://upload.wikimedia.org/wikipedia/en/d/df/Parana.png'
                                          alt text
                                          • F
                                            fabbr
                                            Is there an easy way to have multiple competitions showing at the same time? Like Having Champions League, EPL and MLS ?
                                            I tried to create another entry on config.js but it only takes the options of the first entry.
                                            • 10
                                            • 11
                                            • 7 / 11
