    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 571.5k Views 43 Watching
      Brandlin @Mykle1
      @Mykle1 hi, thanks for the suggestion, however in england the FC goes after the team name, in germany (which are most of the examples) the FC comes first. I am also assuming that the name i need to use is exactly as it is presented in the league table. Note, I have tried the focus_on command with every team name with no success.
        Mykle1 Project Sponsor Module Developer @Brandlin
        @Brandlin
        Again, I don’t use this module. However, it does matter to the API how you enter the team name, even if in England (or anywhere else) the proper way is Newcastle United FC. Have you tried focus on another team from another country? If it works then the problem lies with the API or the formatting of the name in the config.
        Note: Newcastle is my favorite beer. :-)
          Brandlin @Mykle1
          @Mykle1 hi, thanks for the suggestion. I’ve just tried a few teams in the format focus_on: {"ENGLAND": "FC team name"}, and it makes no difference.
          logically I would expect to use the team name exactly as displayed - which is “Newcastle United FC”. Otherwise how would anyone know what team name to use?
          Newcastle United FC
          Newcastle United
          Newcastle Utd FC
          Newcastle Utd
          Newcastle
          FC Newcastle United
          FC Newcastle Utd
          FC Newcastle
          Magpies
          are all different …
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Brandlin
            @Brandlin you are right, you should use Newcastle United FC as thats the value it gets compared to from the API. Can you try and set max_teams: 5
            • L Offline
              layman_smiles
              Wondering if someone can help.
              Having the same issue that a few people have add around the focus_on tool.
              Here’s my code:
                  module: 'MMM-soccer',
                  position: 'bottom_right',
                              colored: true,
                              show: 'ENGLAND',
                              max_teams: '5',
                              leagues: {"ENGLAND": 445},
                              focus_on: {"ENGLAND": "Arsenal FC"}
              Is there something I am doing wrong?
              I have tried a few of the suggestions made before around the position of the FC e.g. ‘FC Arsenal’ and changing the max_teams line to (max_teams: 5), and none of the above have worked.
                strawberry 3.141 Project Sponsor Module Developer @layman_smiles
                @layman_smiles the api returns Arsenal FC so that should be the correct value and max_teams should be definetely without quotes. I will try and debug after work.
                • L Offline
                  layman_smiles @strawberry 3.141
                  @strawberry-3.141 cheers man. i will remove the quote from the max_teams section, and wait to see what you find.
                    @layman_smiles as soon as i removed the quotes, I got the expected table
                    • L Offline
                      @strawberry-3.141 cheers mate, working as it should now. Thanks for looking into this for me
                      • H Offline
                        Henrik
                        Hi @strawberry-3.141,
                        Really nice module! I have a request, if I may: It would be really good if there were an option to automatically cycle between a few leagues, instead of having to do it through voice control (which I don’t have!). Would you mind adding this?
                        Thanks in advance!
                          strawberry 3.141 Project Sponsor Module Developer @Henrik
                          @Henrik sorry I dont plan to add new feature to it, but feel free to send a pull request
                          H 1 Reply Last reply Reply Quote 1
                          • H Offline
                            Henrik @strawberry 3.141
                            @strawberry-3.141 Ok! I just might do that when time permits. :)
                              Fixed icons for german bundesliga and italian serie a
                              also updated league codes
                              [card:fewieden/MMM-soccer]
                              • F Offline
                                fabbr
                                No icons for the Campeonato Brasileiro da Série A ?
                                How can I add those? I would be glad to contribute and upload the code/files to git.
                                  strawberry 3.141 Project Sponsor Module Developer @fabbr
                                  @fabbr if you can send me the exact name from the API and a link to a SVG version of the logo, then I can add it
                                  • F Offline
                                    fabbr @strawberry 3.141
                                    @strawberry-3.141 Here you can find the SVG, you’re looking for Serie-A: https://github.com/hugomiura/escudos-times-brasil-svg
                                    Here’s the API: [{“id”:444,“caption”:“Campeonato Brasileiro da Série A”,“league”:“BSA”,“year”:“2017”,“currentMatchday”:20,“numberOfMatchdays”:38,“numberOfTeams”:20,“numberOfGames”:380,“lastUpdated”:“2017-08-24T00:40:05Z”},
                                    The strong thing is that if I use:
                                    leagues: {“BRAZIL”: 444},
                                    for the configuration it doesn’t show up. but If I use:
                                    leagues: {“ENGLAND”: 444},
                                    What am I doing wrong?
                                    Thank you again, this is a great module!
                                      @fabbr When I go to that page it says svg files are invalid
                                      I need single svg files anyways (each team) with the api name of the team.
                                      Here are the current icon fixes per team https://github.com/fewieden/MMM-soccer/blob/master/MMM-soccer.js#L13-L18
                                      When you tried leagues: {'BRAZIL': 444} did you also set show: 'BRAZIL'
                                      • F Offline
                                        @strawberry-3.141
                                        leagues: {'BRAZIL': 444} and show: 'BRAZIL' worked! I changed the icon fix to include all the teams for the 2017 and 2018 competition that is about to start! Thank you!
                                            icon_fixes: {
                                                '1. FSV Mainz 05': 'https://upload.wikimedia.org/wikipedia/commons/d/d6/FSV_Mainz_05_Logo.png',
                                        		'FC Bayern München': 'https://upload.wikimedia.org/wikipedia/commons/1/1f/Logo_FC_Bayern_M%C3%BCnchen_%282002%E2%80%932017%29.svg',
                                        		'SPAL Ferrara': 'https://upload.wikimedia.org/wikipedia/de/e/e7/SPAL_Ferrara.svg',
                                        		'Benevento Calcio': 'https://upload.wikimedia.org/wikipedia/de/4/48/Benevento_Calcio_Logo.svg',
                                        		///Campeonato Brasileiro:
                                        		'Corinthians': 'https://upload.wikimedia.org/wikipedia/en/1/1f/Sport_Club_Corinthians_Paulista_Logo.png',
                                        		'Palmeiras': 'https://upload.wikimedia.org/wikipedia/commons/1/10/Palmeiras_logo.svg',
                                        		'Cruzeiro': 'https://upload.wikimedia.org/wikipedia/pt/3/36/EC_Noroeste.PNG',
                                        		'Santos FC': 'https://upload.wikimedia.org/wikipedia/commons/3/35/Santos_logo.svg',
                                        		'EC Flamengo': 'https://upload.wikimedia.org/wikipedia/en/c/c9/Flamengo_logo.svg',
                                        		'Vasco da Gama': 'https://upload.wikimedia.org/wikipedia/en/1/1a/ClubDeRegatasVascoDaGama.svg',
                                        		'Atlético Mineiro': 'https://upload.wikimedia.org/wikipedia/en/5/5f/Clube_Atlético_Mineiro_crest.svg',
                                        		'Chapecoense': 'https://upload.wikimedia.org/wikipedia/en/9/97/Associação_Chapecoense_de_Futebol_%282016%29.png',
                                        		'Grémio': 'https://upload.wikimedia.org/wikipedia/en/f/f1/Gremio.svg',
                                        		'Botafogo': 'https://upload.wikimedia.org/wikipedia/commons/5/52/Botafogo_de_Futebol_e_Regatas_logo.svg',
                                        		'Atlético PR': 'https://upload.wikimedia.org/wikipedia/commons/b/b3/CA_Paranaense.svg',
                                        		'Bahia': 'https://upload.wikimedia.org/wikipedia/en/b/b1/Esporte_Clube_Bahia_logo.png',
                                        		'Sao Paulo': 'https://upload.wikimedia.org/wikipedia/commons/6/6f/Brasao_do_Sao_Paulo_Futebol_Clube.svg',
                                        		'Fluminense FC': 'https://upload.wikimedia.org/wikipedia/en/9/9e/Fluminense_fc_logo.svg',
                                        		'Sport Recife': 'https://upload.wikimedia.org/wikipedia/en/4/45/Sport_Club_Recife.svg',
                                        		'EC Vitória': 'https://upload.wikimedia.org/wikipedia/en/4/49/Esporte_Clube_Vitória_logo.svg',
                                        		'Coritiba FC': 'https://upload.wikimedia.org/wikipedia/commons/3/38/Coritiba_FBC_%282011%29_-_PR.svg',
                                        		'Avaí SC': 'https://upload.wikimedia.org/wikipedia/commons/f/fe/Avai_FC_%2805-E%29_-_SC.svg',
                                        		'Ponte Preta': 'https://upload.wikimedia.org/wikipedia/commons/7/7e/Escudo_Oficial_Ponte_Preta.png',
                                        		'Atlético Goianiense': 'http://3.bp.blogspot.com/-Bm9JF0ZGdeQ/VR7uvQxyGLI/AAAAAAAAAj0/F-1Qss9wms0/s1600/atletico%2Bgo%2Bfirst.png',
                                        		//2018 New Teams:
                                        		'América': 'https://upload.wikimedia.org/wikipedia/commons/a/ac/Escudo_do_America_Futebol_Clube.svg',
                                        		'Ceará': 'https://upload.wikimedia.org/wikipedia/en/7/7d/Ceará_SC.png',
                                        		'Internacional': 'https://upload.wikimedia.org/wikipedia/commons/f/f1/Escudo_do_Sport_Club_Internacional.svg',
                                        		'Paraná': 'https://upload.wikimedia.org/wikipedia/en/d/df/Parana.png'
                                        alt text
                                        • F Offline
                                          fabbr
                                          Is there an easy way to have multiple competitions showing at the same time? Like Having Champions League, EPL and MLS ?
                                          I tried to create another entry on config.js but it only takes the options of the first entry.
                                            @fabbr it doesn’t work out of the box, what you could do however is a workaround described in here https://forum.magicmirror.builders/post/19432
                                            • 10
                                            • 11
                                            • 7 / 11
