    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
      Babene1 Project Sponsor
      ok it is crazy.
      on my test/development mirror with windows 10 don’t work. No result with focus_on: {'GERMANY': 'FC Bayern München'},
      but on my main mirror on the raspberry it works perfect.
      so no further investigation.
      thank you for your help / time
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Babene1
        @Babene1
        I’m not suggesting that you use it, but Windows 7 and MagicMirror work flawlessly together. Just a thought.
        • lavolp3L
          lavolp3 Module Developer
          @strawberry-3-141 this is a great and very good looking addon.
          I’m using Bundesliga standings but apparently they are not updating for the new season. I still have season 16/17 standings. Do you know why?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          lavolp3L strawberry 3.141S 2 Replies Last reply
          • lavolp3L
            lavolp3 Module Developer @lavolp3
            @lavolp3 I should have thought a bit longer.
            The reason is that the number for the league is deprecated. If you use the actual number, it works.
            curl -H 'X-Response-Control: minified' -X GET http://api.football-data.org/v1/competitions/?season=2017
            [{"id":444,"caption":"Campeonato Brasileiro da Série A","league":"BSA","year":"2017","currentMatchday":20,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T00:40:05Z"},
            {"id":445,"caption":"Premier League 2017/18","league":"PL","year":"2017","currentMatchday":3,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T10:00:01Z"},
            {"id":446,"caption":"Championship 2017/18","league":"ELC","year":"2017","currentMatchday":5,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T07:00:02Z"},
            {"id":447,"caption":"League One 2017/18","league":"EL1","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
            {"id":448,"caption":"League Two 2017/18","league":"EL2","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
            {"id":449,"caption":"Eredivisie 2017/18","league":"DED","year":"2017","currentMatchday":3,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T04:00:08Z"},
            {"id":450,"caption":"Ligue 1 2017/18","league":"FL1","year":"2017","currentMatchday":4,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-23T10:00:06Z"},
            {"id":451,"caption":"Ligue 2 2017/18","league":"FL2","year":"2017","currentMatchday":5,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T07:00:10Z"},
            {"id":452,"caption":"1. Bundesliga 2017/18","league":"BL1","year":"2017","currentMatchday":2,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T07:00:10Z"},
            {"id":453,"caption":"2. Bundesliga 2017/18","league":"BL2","year":"2017","currentMatchday":4,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-24T07:00:15Z"},
            For 1. Bundesliga 2017/2018 it’s 452
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @lavolp3
              @lavolp3 you can update the lague codes via config ;)
                Southcity
                great work!
                I’m looking for a way to change the Team Name. For example “Red Bull Leipzig” is wrong, it must be Rasenballsport Leipzig. Is there a way to change the Team Name?
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Southcity
                  @Southcity the data is coming from an api endpoint, where you registered for the api key, so you could write them a mail if they can fix it :)
                    Brandlin
                    hi
                    i am having trouble with the soccer module.
                    I can get the current english premier league and i can show a reduced number of teams. But i cannot get the the focus to work. I have tried multiple teams but none work.
                    my code is
                                            module: "MMM-soccer",
                                                    api_key: "... censored ...",
                                                    show: "ENGLAND",
                                                    leagues: {"ENGLAND": 445},
                                                    focus_on: {"ENGLAND": "Newcastle United FC"},
                                                    max_teams: "5"
                    Dont judge me on the team - its my father’s and this is a christmas present.
                    what am i doing wrong?
                    Also is there a way to update the league to the 18/19 season when the ext season starts or do i have to edit the config then?
                      Brandlin
                      sorry, i should have added that if when i run the code above the module clearly loads because it shows the headings but the table is blank. If i comment out the focus_on command the module works fine and shows the top 5 teams (as expected)
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Brandlin
                        @Brandlin
                        This is a complete guess so forgive me if it does not correct your problem. I don’t use this module.
                        try
                        focus_on: "ENGLAND": "FC Newcastle United"},
                        I’ve noticed from the other examples above that the FC comes before the team name. It’s worth a shot.
                        B 1 Reply Last reply
                          Brandlin @Mykle1
                          @Mykle1 hi, thanks for the suggestion, however in england the FC goes after the team name, in germany (which are most of the examples) the FC comes first. I am also assuming that the name i need to use is exactly as it is presented in the league table. Note, I have tried the focus_on command with every team name with no success.
                          • Mykle1M
                            @Brandlin
                            Again, I don’t use this module. However, it does matter to the API how you enter the team name, even if in England (or anywhere else) the proper way is Newcastle United FC. Have you tried focus on another team from another country? If it works then the problem lies with the API or the formatting of the name in the config.
                            Note: Newcastle is my favorite beer. :-)
                              Brandlin @Mykle1
                              @Mykle1 hi, thanks for the suggestion. I’ve just tried a few teams in the format focus_on: {"ENGLAND": "FC team name"}, and it makes no difference.
                              logically I would expect to use the team name exactly as displayed - which is “Newcastle United FC”. Otherwise how would anyone know what team name to use?
                              Newcastle United FC
                              Newcastle United
                              Newcastle Utd FC
                              Newcastle Utd
                              Newcastle
                              FC Newcastle United
                              FC Newcastle Utd
                              FC Newcastle
                              Magpies
                              are all different …
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @Brandlin
                                @Brandlin you are right, you should use Newcastle United FC as thats the value it gets compared to from the API. Can you try and set max_teams: 5
                                • L
                                  layman_smiles
                                  Wondering if someone can help.
                                  Having the same issue that a few people have add around the focus_on tool.
                                  Here’s my code:
                                      module: 'MMM-soccer',
                                      position: 'bottom_right',
                                                  colored: true,
                                                  show: 'ENGLAND',
                                                  max_teams: '5',
                                                  focus_on: {"ENGLAND": "Arsenal FC"}
                                  Is there something I am doing wrong?
                                  I have tried a few of the suggestions made before around the position of the FC e.g. ‘FC Arsenal’ and changing the max_teams line to (max_teams: 5), and none of the above have worked.
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @layman_smiles
                                    @layman_smiles the api returns Arsenal FC so that should be the correct value and max_teams should be definetely without quotes. I will try and debug after work.
                                    L 1 Reply Last reply
                                    • L
                                      layman_smiles @strawberry 3.141
                                      @strawberry-3.141 cheers man. i will remove the quote from the max_teams section, and wait to see what you find.
                                      • strawberry 3.141S
                                        @layman_smiles as soon as i removed the quotes, I got the expected table
                                        • L
                                          @strawberry-3.141 cheers mate, working as it should now. Thanks for looking into this for me
                                          • H
                                            Henrik
                                            Hi @strawberry-3.141,
                                            Really nice module! I have a request, if I may: It would be really good if there were an option to automatically cycle between a few leagues, instead of having to do it through voice control (which I don’t have!). Would you mind adding this?
                                            Thanks in advance!
                                            • 10
                                            • 11
                                            • 6 / 11
