    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 570.9k Views 43 Watching
      McSorley
      I know its the off season now but any developments on cup support, i.e. Champions League?
        Babene1 Project Sponsor
        The module is really great, thanks again.
        But I have currently also the problem with “focus_on” and an team with “ö / ä / ü”
        Any solution available?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Babene1
          @Babene1 can you pls provide the config so i can investigate?
            here is the config of the modul:
            			module: 'MMM-soccer',
            			position: 'top_right',
            				colored: true,
            				focus_on: {'GERMANY': 'FC Bayern München'},
            				max_teams:6,
              @Babene1 By using your config, the team FC Bayern München is highlighted. For me everything works as expected.
              Can you describe what happens exactly on your side?
                ok it is crazy.
                on my test/development mirror with windows 10 don’t work. No result with focus_on: {'GERMANY': 'FC Bayern München'},
                but on my main mirror on the raspberry it works perfect.
                so no further investigation.
                thank you for your help / time
                  Mykle1 Project Sponsor Module Developer @Babene1
                  @Babene1
                  I’m not suggesting that you use it, but Windows 7 and MagicMirror work flawlessly together. Just a thought.
                  • lavolp3L Offline
                    lavolp3 Module Developer
                    @strawberry-3-141 this is a great and very good looking addon.
                    I’m using Bundesliga standings but apparently they are not updating for the new season. I still have season 16/17 standings. Do you know why?
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    lavolp3L strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    • lavolp3L Offline
                      lavolp3 Module Developer @lavolp3
                      @lavolp3 I should have thought a bit longer.
                      The reason is that the number for the league is deprecated. If you use the actual number, it works.
                      curl -H 'X-Response-Control: minified' -X GET http://api.football-data.org/v1/competitions/?season=2017
                      [{"id":444,"caption":"Campeonato Brasileiro da Série A","league":"BSA","year":"2017","currentMatchday":20,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T00:40:05Z"},
                      {"id":445,"caption":"Premier League 2017/18","league":"PL","year":"2017","currentMatchday":3,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T10:00:01Z"},
                      {"id":446,"caption":"Championship 2017/18","league":"ELC","year":"2017","currentMatchday":5,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T07:00:02Z"},
                      {"id":447,"caption":"League One 2017/18","league":"EL1","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
                      {"id":448,"caption":"League Two 2017/18","league":"EL2","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
                      {"id":449,"caption":"Eredivisie 2017/18","league":"DED","year":"2017","currentMatchday":3,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T04:00:08Z"},
                      {"id":450,"caption":"Ligue 1 2017/18","league":"FL1","year":"2017","currentMatchday":4,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-23T10:00:06Z"},
                      {"id":451,"caption":"Ligue 2 2017/18","league":"FL2","year":"2017","currentMatchday":5,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T07:00:10Z"},
                      {"id":452,"caption":"1. Bundesliga 2017/18","league":"BL1","year":"2017","currentMatchday":2,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T07:00:10Z"},
                      {"id":453,"caption":"2. Bundesliga 2017/18","league":"BL2","year":"2017","currentMatchday":4,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-24T07:00:15Z"},
                      For 1. Bundesliga 2017/2018 it’s 452
                        strawberry 3.141 Project Sponsor Module Developer @lavolp3
                        @lavolp3 you can update the lague codes via config ;)
                          Southcity
                          great work!
                          I’m looking for a way to change the Team Name. For example “Red Bull Leipzig” is wrong, it must be Rasenballsport Leipzig. Is there a way to change the Team Name?
                            strawberry 3.141 Project Sponsor Module Developer @Southcity
                            @Southcity the data is coming from an api endpoint, where you registered for the api key, so you could write them a mail if they can fix it :)
                              Brandlin
                              hi
                              i am having trouble with the soccer module.
                              I can get the current english premier league and i can show a reduced number of teams. But i cannot get the the focus to work. I have tried multiple teams but none work.
                              my code is
                                                      module: "MMM-soccer",
                                                              api_key: "... censored ...",
                                                              show: "ENGLAND",
                                                              leagues: {"ENGLAND": 445},
                                                              focus_on: {"ENGLAND": "Newcastle United FC"},
                                                              max_teams: "5"
                              Dont judge me on the team - its my father’s and this is a christmas present.
                              what am i doing wrong?
                              Also is there a way to update the league to the 18/19 season when the ext season starts or do i have to edit the config then?
                                Brandlin
                                sorry, i should have added that if when i run the code above the module clearly loads because it shows the headings but the table is blank. If i comment out the focus_on command the module works fine and shows the top 5 teams (as expected)
                                  Mykle1 Project Sponsor Module Developer @Brandlin
                                  @Brandlin
                                  This is a complete guess so forgive me if it does not correct your problem. I don’t use this module.
                                  try
                                  focus_on: "ENGLAND": "FC Newcastle United"},
                                  I’ve noticed from the other examples above that the FC comes before the team name. It’s worth a shot.
                                    Brandlin @Mykle1
                                    @Mykle1 hi, thanks for the suggestion, however in england the FC goes after the team name, in germany (which are most of the examples) the FC comes first. I am also assuming that the name i need to use is exactly as it is presented in the league table. Note, I have tried the focus_on command with every team name with no success.
                                      @Brandlin
                                      Again, I don’t use this module. However, it does matter to the API how you enter the team name, even if in England (or anywhere else) the proper way is Newcastle United FC. Have you tried focus on another team from another country? If it works then the problem lies with the API or the formatting of the name in the config.
                                      Note: Newcastle is my favorite beer. :-)
                                        Brandlin @Mykle1
                                        @Mykle1 hi, thanks for the suggestion. I’ve just tried a few teams in the format focus_on: {"ENGLAND": "FC team name"}, and it makes no difference.
                                        logically I would expect to use the team name exactly as displayed - which is “Newcastle United FC”. Otherwise how would anyone know what team name to use?
                                        Newcastle United FC
                                        Newcastle United
                                        Newcastle Utd FC
                                        Newcastle Utd
                                        Newcastle
                                        FC Newcastle United
                                        FC Newcastle Utd
                                        FC Newcastle
                                        Magpies
                                        are all different …
                                          strawberry 3.141 Project Sponsor Module Developer @Brandlin
                                          @Brandlin you are right, you should use Newcastle United FC as thats the value it gets compared to from the API. Can you try and set max_teams: 5
                                          • L Offline
                                            layman_smiles
                                            Wondering if someone can help.
                                            Having the same issue that a few people have add around the focus_on tool.
                                            Here’s my code:
                                                position: 'bottom_right',
                                                            colored: true,
                                                            show: 'ENGLAND',
                                                            max_teams: '5',
                                                            focus_on: {"ENGLAND": "Arsenal FC"}
                                            Is there something I am doing wrong?
                                            I have tried a few of the suggestions made before around the position of the FC e.g. ‘FC Arsenal’ and changing the max_teams line to (max_teams: 5), and none of the above have worked.
                                            • 10
                                            • 11
                                            • 6 / 11
