    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @davidrq7
      @davidrq7 sry for the late reply must have missed this post.
      Do you use the newest version? Did you set some old league codes in the config?
      D 1 Reply Last reply
        davidrq7 @strawberry 3.141
        @strawberry-3.141 i guess i have latest version. League code is “ENGLAND”: 426. Is that wrong ?
        • strawberry 3.141S
          @davidrq7 I installed the module and inserted the following config in my config.js file, which gives me the expected result of the current season.
            module: 'MMM-soccer',
            position: 'bottom_right',
              show: 'ENGLAND',
              max_teams: 5
            @strawberry-3.141 I checkd and i got old league code ;) now works fine ;) Thx for your time!
              jules
              Hi all,
              has anyone found a possibility to show just two teams of the same league?
              I want to show just two teams of the german first division.
              I tryed:
              	api_key: "XXXX",
              	focus_on: {"GERMANY": "1. FC Köln","GERMANY": "FC Schalke 04"},
              	max_teams: 2
              but then the focus is only on the second team.
              With
              	api_key: "XXXXX",
              	focus_on: {"GERMANY": "1. FC Köln","FC Schalke 04"},
              	max_teams: 2
              I get an config error.
              It would be great if anyone knows a solution.
              thanks and best regards,
              jules
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @jules
                @jules With the current code base this is not possible
                J 1 Reply Last reply
                  jules @strawberry 3.141
                  @strawberry-3.141 thanks for your fast reply. Do you think its a possibility to copy the whole MMM-soccer module, and build a version that just shows the team without the league and gameday information, than npm rebuild. and use this module directly under the original module, to just show the second team.
                  Hope you get what i mean :laughing:
                  • strawberry 3.141S
                    @jules because the teams are in the same league, you can just copy your config entry and place in the other team in focus_on. Then you have to create some css rules in custom.css to hide the header and so on
                      @strawberry-3.141 sounds good, i will try this by time.
                      thank you very much
                        McSorley
                        I know its the off season now but any developments on cup support, i.e. Champions League?
                          Babene1 Project Sponsor
                          The module is really great, thanks again.
                          But I have currently also the problem with “focus_on” and an team with “ö / ä / ü”
                          Any solution available?
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Babene1
                            @Babene1 can you pls provide the config so i can investigate?
                              here is the config of the modul:
                              			position: 'top_right',
                              				colored: true,
                              				focus_on: {'GERMANY': 'FC Bayern München'},
                              				max_teams:6,
                              • strawberry 3.141S
                                @Babene1 By using your config, the team FC Bayern München is highlighted. For me everything works as expected.
                                Can you describe what happens exactly on your side?
                                  ok it is crazy.
                                  on my test/development mirror with windows 10 don’t work. No result with focus_on: {'GERMANY': 'FC Bayern München'},
                                  but on my main mirror on the raspberry it works perfect.
                                  so no further investigation.
                                  thank you for your help / time
                                  Mykle1M 1 Reply Last reply
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @Babene1
                                    @Babene1
                                    I’m not suggesting that you use it, but Windows 7 and MagicMirror work flawlessly together. Just a thought.
                                    • lavolp3L
                                      lavolp3 Module Developer
                                      @strawberry-3-141 this is a great and very good looking addon.
                                      I’m using Bundesliga standings but apparently they are not updating for the new season. I still have season 16/17 standings. Do you know why?
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      lavolp3L strawberry 3.141S 2 Replies Last reply
                                      • lavolp3L
                                        lavolp3 Module Developer @lavolp3
                                        @lavolp3 I should have thought a bit longer.
                                        The reason is that the number for the league is deprecated. If you use the actual number, it works.
                                        curl -H 'X-Response-Control: minified' -X GET http://api.football-data.org/v1/competitions/?season=2017
                                        [{"id":444,"caption":"Campeonato Brasileiro da Série A","league":"BSA","year":"2017","currentMatchday":20,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T00:40:05Z"},
                                        {"id":445,"caption":"Premier League 2017/18","league":"PL","year":"2017","currentMatchday":3,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T10:00:01Z"},
                                        {"id":446,"caption":"Championship 2017/18","league":"ELC","year":"2017","currentMatchday":5,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T07:00:02Z"},
                                        {"id":447,"caption":"League One 2017/18","league":"EL1","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
                                        {"id":448,"caption":"League Two 2017/18","league":"EL2","year":"2017","currentMatchday":4,"numberOfMatchdays":46,"numberOfTeams":24,"numberOfGames":552,"lastUpdated":"2017-08-22T04:00:06Z"},
                                        {"id":449,"caption":"Eredivisie 2017/18","league":"DED","year":"2017","currentMatchday":3,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T04:00:08Z"},
                                        {"id":450,"caption":"Ligue 1 2017/18","league":"FL1","year":"2017","currentMatchday":4,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-23T10:00:06Z"},
                                        {"id":451,"caption":"Ligue 2 2017/18","league":"FL2","year":"2017","currentMatchday":5,"numberOfMatchdays":38,"numberOfTeams":20,"numberOfGames":380,"lastUpdated":"2017-08-24T07:00:10Z"},
                                        {"id":452,"caption":"1. Bundesliga 2017/18","league":"BL1","year":"2017","currentMatchday":2,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-23T07:00:10Z"},
                                        {"id":453,"caption":"2. Bundesliga 2017/18","league":"BL2","year":"2017","currentMatchday":4,"numberOfMatchdays":34,"numberOfTeams":18,"numberOfGames":306,"lastUpdated":"2017-08-24T07:00:15Z"},
                                        For 1. Bundesliga 2017/2018 it’s 452
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @lavolp3
                                          @lavolp3 you can update the lague codes via config ;)
                                            Southcity
                                            great work!
                                            I’m looking for a way to change the Team Name. For example “Red Bull Leipzig” is wrong, it must be Rasenballsport Leipzig. Is there a way to change the Team Name?
                                            • 10
                                            • 11
                                            • 6 / 11
