    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @STEFF92
      @STEFF92 then you did something wrong. Because you said you manually downloaded the files etc. I suggest to delete it again and start from scratch, this will help you to update more easily in future.
      type in the terminal
      cd ~/MagicMirror/modules
      git clone https://github.com/fewieden/MMM-soccer.git
      cd MMM-soccer
      npm install
      S 2 Replies Last reply
        STEFF92 @strawberry 3.141
        @strawberry-3.141 ok now i did it how you said. when its finished i only have to add the module in my config.js file right? and then thats it?
          @strawberry-3.141 Thank you verry much. It works perfectly
          • T
            TheSwissGuy
            Hi @strawberry-3-141
            I am using and loving your module! Unfortunately I’ve found a bug with your module running together with the MMM-Carousel. I have three MMM-Soccer module configs, one for Germany, one for England and one for Spain. My idea was to show every table for 3 seconds and then move on to the next one.
            But I encountered this problem: It always shows me the same league. Now a played with it and set the max_team value for these leagues to different values and it perfectly changes the amount of teams to the correct value, but always with the same teams for the same leagues.
            So I guess the problem could be that when the show method gets called it does not reload the league (or get it out of a cache).
            I tried to fix it but I am not a javasript guru so I didn’t find the problem code. Do you have an idea how to make the module reload the league data?
            I hopoe you can help me!
            Best regards,
            Stephan
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @TheSwissGuy
              @TheSwissGuy Grüezi Stephan,
              I guess nearly all modules have this kind of issue, as there is only one node_helper for those 3 modules which is uesed by all 3 module instances. the node_helper sends back the data and all 3 listen on it which ends in the same league for every instance. I will see if i can find time to handle this issue.
              D 1 Reply Last reply
                davidrq7 @strawberry 3.141
                @strawberry-3.141 hi. can you tell me why i have so old league table and it’s not updating?
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @davidrq7
                  @davidrq7 sry for the late reply must have missed this post.
                  Do you use the newest version? Did you set some old league codes in the config?
                    @strawberry-3.141 i guess i have latest version. League code is “ENGLAND”: 426. Is that wrong ?
                    • strawberry 3.141S
                      @davidrq7 I installed the module and inserted the following config in my config.js file, which gives me the expected result of the current season.
                        module: 'MMM-soccer',
                        position: 'bottom_right',
                          show: 'ENGLAND',
                          max_teams: 5
                        @strawberry-3.141 I checkd and i got old league code ;) now works fine ;) Thx for your time!
                          jules
                          Hi all,
                          has anyone found a possibility to show just two teams of the same league?
                          I want to show just two teams of the german first division.
                          I tryed:
                          	api_key: "XXXX",
                          	focus_on: {"GERMANY": "1. FC Köln","GERMANY": "FC Schalke 04"},
                          	max_teams: 2
                          but then the focus is only on the second team.
                          With
                          	api_key: "XXXXX",
                          	focus_on: {"GERMANY": "1. FC Köln","FC Schalke 04"},
                          	max_teams: 2
                          I get an config error.
                          It would be great if anyone knows a solution.
                          thanks and best regards,
                          jules
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @jules
                            @jules With the current code base this is not possible
                            J 1 Reply Last reply
                              jules @strawberry 3.141
                              @strawberry-3.141 thanks for your fast reply. Do you think its a possibility to copy the whole MMM-soccer module, and build a version that just shows the team without the league and gameday information, than npm rebuild. and use this module directly under the original module, to just show the second team.
                              Hope you get what i mean :laughing:
                              • strawberry 3.141S
                                @jules because the teams are in the same league, you can just copy your config entry and place in the other team in focus_on. Then you have to create some css rules in custom.css to hide the header and so on
                                  @strawberry-3.141 sounds good, i will try this by time.
                                  thank you very much
                                    McSorley
                                    I know its the off season now but any developments on cup support, i.e. Champions League?
                                      Babene1 Project Sponsor
                                      The module is really great, thanks again.
                                      But I have currently also the problem with “focus_on” and an team with “ö / ä / ü”
                                      Any solution available?
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @Babene1
                                        @Babene1 can you pls provide the config so i can investigate?
                                          here is the config of the modul:
                                          			position: 'top_right',
                                          				colored: true,
                                          				focus_on: {'GERMANY': 'FC Bayern München'},
                                          				max_teams:6,
                                          • strawberry 3.141S
                                            @Babene1 By using your config, the team FC Bayern München is highlighted. For me everything works as expected.
                                            Can you describe what happens exactly on your side?
                                            • 10
                                            • 11
                                            • 5 / 11
