    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 578.1k Views 43 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
      @ostfilinchen should be fixed now, was my fault
      • O
        ostfilinchen @strawberry 3.141
        @strawberry-3.141 must i do npm install?
        • strawberry 3.141S
          @ostfilinchen no the dependencies havent changed
          • O
            @strawberry-3.141 great! Works now.
              STEFF92
              at first, sorry for my bad english. I’m a totally beginner and MMM-Soccer is the first module i want to install by myself. At first i downloaded the Zip file, unpacked it and copied it into /home/pi/MagicMirror/modules. Then i opened the config.js file and added:
              module: ‘MMM-soccer’,
              position: ‘bottom_right’,
              api_key: ‘7cgd8…’,
              colored: ‘false’,
              show: ‘GERMANY’,
              leagues: {“GERMANY”:430},
              Then i opened the LXTerminal on the raspberry pi and typed in :
              pi@raspberrypi:~/MagicMirror $ npm install ~/MagicMirror/modules/MMM-soccer
              Then there came:
              npm ERR! addLocal Could not install /home/pi/MagicMirror…
              npm ERR! Linux …
              What did i wrong? Can anyone help me please?
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @STEFF92
                @STEFF92 in the terminal you have to do cd ~/MagicMirror/modules/MMM-soccer then npm install
                and in your config you have to remove the quotes here colored: false,
                  STEFF92 @strawberry 3.141
                  @strawberry-3.141 but then there is :
                  bash: cd: /home/pi/MagicMirror/modules/MMM-soccer: file or directory not found
                  • strawberry 3.141S
                    @STEFF92 then you did something wrong. Because you said you manually downloaded the files etc. I suggest to delete it again and start from scratch, this will help you to update more easily in future.
                    type in the terminal
                    git clone https://github.com/fewieden/MMM-soccer.git
                    cd MMM-soccer
                    npm install
                      @strawberry-3.141 ok now i did it how you said. when its finished i only have to add the module in my config.js file right? and then thats it?
                        @strawberry-3.141 Thank you verry much. It works perfectly
                        • T
                          TheSwissGuy
                          Hi @strawberry-3-141
                          I am using and loving your module! Unfortunately I’ve found a bug with your module running together with the MMM-Carousel. I have three MMM-Soccer module configs, one for Germany, one for England and one for Spain. My idea was to show every table for 3 seconds and then move on to the next one.
                          But I encountered this problem: It always shows me the same league. Now a played with it and set the max_team value for these leagues to different values and it perfectly changes the amount of teams to the correct value, but always with the same teams for the same leagues.
                          So I guess the problem could be that when the show method gets called it does not reload the league (or get it out of a cache).
                          I tried to fix it but I am not a javasript guru so I didn’t find the problem code. Do you have an idea how to make the module reload the league data?
                          I hopoe you can help me!
                          Best regards,
                          Stephan
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @TheSwissGuy
                            @TheSwissGuy Grüezi Stephan,
                            I guess nearly all modules have this kind of issue, as there is only one node_helper for those 3 modules which is uesed by all 3 module instances. the node_helper sends back the data and all 3 listen on it which ends in the same league for every instance. I will see if i can find time to handle this issue.
                              davidrq7 @strawberry 3.141
                              @strawberry-3.141 hi. can you tell me why i have so old league table and it’s not updating?
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @davidrq7
                                @davidrq7 sry for the late reply must have missed this post.
                                Do you use the newest version? Did you set some old league codes in the config?
                                  @strawberry-3.141 i guess i have latest version. League code is “ENGLAND”: 426. Is that wrong ?
                                  • strawberry 3.141S
                                    @davidrq7 I installed the module and inserted the following config in my config.js file, which gives me the expected result of the current season.
                                      module: 'MMM-soccer',
                                      position: 'bottom_right',
                                        show: 'ENGLAND',
                                        max_teams: 5
                                      @strawberry-3.141 I checkd and i got old league code ;) now works fine ;) Thx for your time!
                                        jules
                                        Hi all,
                                        has anyone found a possibility to show just two teams of the same league?
                                        I want to show just two teams of the german first division.
                                        I tryed:
                                        	api_key: "XXXX",
                                        	focus_on: {"GERMANY": "1. FC Köln","GERMANY": "FC Schalke 04"},
                                        	max_teams: 2
                                        but then the focus is only on the second team.
                                        With
                                        	api_key: "XXXXX",
                                        	focus_on: {"GERMANY": "1. FC Köln","FC Schalke 04"},
                                        	max_teams: 2
                                        I get an config error.
                                        It would be great if anyone knows a solution.
                                        thanks and best regards,
                                        jules
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @jules
                                          @jules With the current code base this is not possible
                                            jules @strawberry 3.141
                                            @strawberry-3.141 thanks for your fast reply. Do you think its a possibility to copy the whole MMM-soccer module, and build a version that just shows the team without the league and gameday information, than npm rebuild. and use this module directly under the original module, to just show the second team.
                                            Hope you get what i mean :laughing:
                                            • 10
                                            • 11
                                            • 5 / 11
