    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
      @ostfilinchen should be fixed, but i found just the old logo.
      seems to get worse with the icons, probably worth to implement an icon downloader
      O 1 Reply Last reply
      • O
        ostfilinchen @strawberry 3.141
        @strawberry-3.141 thanks. Yes i think this would be a great idea :-)
        • SteffS
          Steff
          @strawberry-3-141 Now I do have the similar problem for 1. FSV Mainz 05.
          Adding this line in the .js file solved it:
          “1. FSV Mainz 05”: “https://upload.wikimedia.org/wikipedia/commons/thumb/d/d6/FSV_Mainz_05_Logo.png/100px-FSV_Mainz_05_Logo.png”
          Do you think it might make sense to include it as well on github ? Thanks
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Steff
            @Steff done thank you
            • O
              @strawberry-3.141 i found a zip file (http://www.vmlogic.net/Downloads/Files/public/dfs_media_2016-09-07.zip) with logos for the soccerclubs. do u think you can implement a downloader and use these logos for the module?
              • strawberry 3.141S
                @ostfilinchen i will check it in 2-3 weeks after im done with my bachelor stuff. Thank you
                • O
                  @strawberry-3.141 the Module wouldn’t start. It only display loading…
                  I have update it and Do npm install
                  • strawberry 3.141S
                    @ostfilinchen should be fixed now, was my fault
                    • O
                      @strawberry-3.141 must i do npm install?
                      • strawberry 3.141S
                        @ostfilinchen no the dependencies havent changed
                        • O
                          @strawberry-3.141 great! Works now.
                            STEFF92
                            at first, sorry for my bad english. I’m a totally beginner and MMM-Soccer is the first module i want to install by myself. At first i downloaded the Zip file, unpacked it and copied it into /home/pi/MagicMirror/modules. Then i opened the config.js file and added:
                            module: ‘MMM-soccer’,
                            position: ‘bottom_right’,
                            api_key: ‘7cgd8…’,
                            colored: ‘false’,
                            show: ‘GERMANY’,
                            leagues: {“GERMANY”:430},
                            Then i opened the LXTerminal on the raspberry pi and typed in :
                            pi@raspberrypi:~/MagicMirror $ npm install ~/MagicMirror/modules/MMM-soccer
                            Then there came:
                            npm ERR! addLocal Could not install /home/pi/MagicMirror…
                            npm ERR! Linux …
                            What did i wrong? Can anyone help me please?
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @STEFF92
                              @STEFF92 in the terminal you have to do cd ~/MagicMirror/modules/MMM-soccer then npm install
                              and in your config you have to remove the quotes here colored: false,
                                STEFF92 @strawberry 3.141
                                @strawberry-3.141 but then there is :
                                bash: cd: /home/pi/MagicMirror/modules/MMM-soccer: file or directory not found
                                • strawberry 3.141S
                                  @STEFF92 then you did something wrong. Because you said you manually downloaded the files etc. I suggest to delete it again and start from scratch, this will help you to update more easily in future.
                                  type in the terminal
                                  git clone https://github.com/fewieden/MMM-soccer.git
                                  cd MMM-soccer
                                  npm install
                                  S 2 Replies Last reply
                                    @strawberry-3.141 ok now i did it how you said. when its finished i only have to add the module in my config.js file right? and then thats it?
                                      @strawberry-3.141 Thank you verry much. It works perfectly
                                      • T
                                        TheSwissGuy
                                        Hi @strawberry-3-141
                                        I am using and loving your module! Unfortunately I’ve found a bug with your module running together with the MMM-Carousel. I have three MMM-Soccer module configs, one for Germany, one for England and one for Spain. My idea was to show every table for 3 seconds and then move on to the next one.
                                        But I encountered this problem: It always shows me the same league. Now a played with it and set the max_team value for these leagues to different values and it perfectly changes the amount of teams to the correct value, but always with the same teams for the same leagues.
                                        So I guess the problem could be that when the show method gets called it does not reload the league (or get it out of a cache).
                                        I tried to fix it but I am not a javasript guru so I didn’t find the problem code. Do you have an idea how to make the module reload the league data?
                                        I hopoe you can help me!
                                        Best regards,
                                        Stephan
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @TheSwissGuy
                                          @TheSwissGuy Grüezi Stephan,
                                          I guess nearly all modules have this kind of issue, as there is only one node_helper for those 3 modules which is uesed by all 3 module instances. the node_helper sends back the data and all 3 listen on it which ends in the same league for every instance. I will see if i can find time to handle this issue.
                                          D 1 Reply Last reply
                                            davidrq7 @strawberry 3.141
                                            @strawberry-3.141 hi. can you tell me why i have so old league table and it’s not updating?
                                            • 10
                                            • 11
                                            • 5 / 11
