    Black screen after install update v2.2
    11 Posts 7 Posters 7.9k Views 6 Watching
      Blackmirror
      after install the new update. I get a black screen at my MagicMirror.
      I get many warnings after npm install.
      //pi@Mirror:~/MagicMirror $ npm install
      > magicmirror@2.2.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      > magicmirror@2.2.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.2.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      magicmirror@2.2.0 /home/pi/MagicMirror
      ├─┬ mocha-logger@1.0.5
      │ └─┬ mocha@3.5.3
      │   ├─┬ commander@2.9.0
      │   │ └── graceful-readlink@1.0.1
      │   ├─┬ debug@2.6.8
      │   │ └── ms@2.0.0
      │   ├── diff@3.2.0
      │   ├── growl@1.9.2
      │   ├── json3@3.3.2
      │   ├─┬ lodash.create@3.1.1
      │   │ ├─┬ lodash._baseassign@3.2.0
      │   │ │ ├── lodash._basecopy@3.0.1
      │   │ │ └─┬ lodash.keys@3.1.2
      │   │ │   ├── lodash._getnative@3.9.1
      │   │ │   ├── lodash.isarguments@3.1.0
      │   │ │   └── lodash.isarray@3.0.4
      │   │ ├── lodash._basecreate@3.0.3
      │   │ └── lodash._isiterateecall@3.0.9
      │   ├─┬ mkdirp@0.5.1
      │   │ └── minimist@0.0.8
      │   └── supports-color@3.1.2
      └─┬ UNMET PEER DEPENDENCY stylelint@8.4.0
        ├── UNMET PEER DEPENDENCY postcss-less@1.1.3
        ├── UNMET PEER DEPENDENCY postcss-scss@1.0.2
        └── UNMET PEER DEPENDENCY sugarss@1.0.1
      npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none was installed.
      npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none was installed.
      npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was installed.
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Blackmirror
        @Blackmirror can you run your mirror with npm start dev and check for errors in the console?
          Blackmirror
          Okay. here:
          //Starting MagicMirror: v2.2.0
          Loading config ...
          Loading module helpers ...
          No helper found for module: MMM-Carousel.
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 53.
          App threw an error during load
              at Error (native)
              at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
              at Object.Module._extensions..node (module.js:583:18)
              at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
              at Module.load (module.js:473:32)
              at tryModuleLoad (module.js:432:12)
              at Function.Module._load (module.js:424:3)
              at Module.require (module.js:483:17)
              at require (internal/module.js:20:19)
              at bindings (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings/bindings.js:76:44)
              at Error (native)
          Launching application.
            @Blackmirror try to got to cd /home/pi/MagicMirror/modules/MMM-Buttons and run npm rebuild
              Blackmirror
              Okay. after npm rebuild the Mirror is still black.
                Peter
                I updated to V2.2.1 on my RPI2: no problem.
                Calendar entries work better now.
                Thanks for the work!
                Peter
                • cowboysdudeC Offline
                  My suggestion would be to back your modules and your working config.js and delete MM and install the new version… That’s the quickest and easiest way
                    carltonb
                    I had to do a complete reinstall. Used a backed up sd card and the same error kept appearing in the logs. Backed up all my configs and mods. Did a fresh install and all works fine. Could have been one of the modules that gave it an error, I do not know but the calendar works great now.
                    carltonb
                      cowboysdude Module Developer @carltonb
                      @carltonb Well sometimes things get ‘lost’ or don’t install properly…so at times things can go wrong and cannot be fixed so that was the best answer. Glad you got it working!!
                        ryck Module Developer
                        A quick way to fix this:
                        cd modules/MMM-Buttons
                        npm install electron-rebuild
                        ./node_modules/.bin/electron-rebuild
                        It always worked for me…
                        H 1 Reply Last reply Reply Quote 1
