    Black screen after install update v2.2
    11 Posts 7 Posters 8.0k Views 6 Watching
      Blackmirror
      Okay. here:
      //Starting MagicMirror: v2.2.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-Carousel.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 53.
      App threw an error during load
          at Error (native)
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
          at Object.Module._extensions..node (module.js:583:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          at Function.Module._load (module.js:424:3)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at bindings (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings/bindings.js:76:44)
          at Error (native)
      Launching application.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Blackmirror
        @Blackmirror try to got to cd /home/pi/MagicMirror/modules/MMM-Buttons and run npm rebuild
          Blackmirror
          Okay. after npm rebuild the Mirror is still black.
            Peter
            I updated to V2.2.1 on my RPI2: no problem.
            Calendar entries work better now.
            Thanks for the work!
            Peter
            • cowboysdudeC Offline
              My suggestion would be to back your modules and your working config.js and delete MM and install the new version… That’s the quickest and easiest way
                carltonb
                I had to do a complete reinstall. Used a backed up sd card and the same error kept appearing in the logs. Backed up all my configs and mods. Did a fresh install and all works fine. Could have been one of the modules that gave it an error, I do not know but the calendar works great now.
                carltonb
                  cowboysdude Module Developer @carltonb
                  @carltonb Well sometimes things get ‘lost’ or don’t install properly…so at times things can go wrong and cannot be fixed so that was the best answer. Glad you got it working!!
                    ryck Module Developer
                    A quick way to fix this:
                    cd modules/MMM-Buttons
                    npm install electron-rebuild
                    ./node_modules/.bin/electron-rebuild
                    It always worked for me…
                    H 1 Reply Last reply Reply Quote 1
                    • H Offline
                      hoddog @ryck
                      @ryck said in Black screen after install update v2.2:
                      You are my hero… :)
