    ipWhitelist HowTo
    83 Posts 36 Posters 164.1k Views 34 Watching
    • mochmanM
      mochman Module Developer
      @open_book Just looking at your pi’s IP. It looks like it’s using 192.168.0.X and you’re whitelisting the 192.168.1.X IPs. Can you try adding
      "::ffff:192.168.0.1/120", "192.168.0.1/24"
      to your whitelist and see if that fixes it up?
      O Mykle1M 2 Replies Last reply
      Reply Quote 3
      • O
        open_book @mochman
        @mochman sorry for the slow reply. I’ve been on holiday.
        Wanted to let you know that your suggestion fixed my problem. I added your suggested IPs and now I can both access through SSH and through a mobile device/browser.
        Thanks for your replies!
        sudo insert motivational.quote
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @mochman
          @mochman said in ipWhitelist HowTo:
          I don’t have a problem with my Whitelist but a couple of people have lately. I wonder if they bother searching the forum and/or read topics such as this.
          Anyway, nice work @mochman :-)
            pingywon
            LOL. Not sure if you mean me, but yes I have read this thread from beginning to end and it doesnt resolve my white list issues. This for whole forum is not that big. I’d be willing to bet I have read most of it
            • K
              krisalexroberts @mochman
              The reason why “/24” works
              A couple different threads state to add /24 to the end of the IP address. (I’ve put a couple of those up before doing some research too). While this will indeed allow your network devices access to your magic mirror, it will also allow any device with an IPv4 based address access to your mirror (obviously your router would need to be configured to allow this).
              This “/24” in IPv6 CIDR allows 20,282,409,603,651,670,423,947,251,286,016 different IP addresses access. (IPv4’s total addresses are 4,294,967,296).
              More information
              If you’d like to learn more or have different sub-netting needs, I found this page useful.
              I don’t ageee with that. 192.167.1.0/24 is everything in the 192.168.1.x range, nothing more nothing less. If it allows more than this is a massive flaw/security risk.
              If you want to allow your own subnet then just look at your subnet mask and use google to get the CIDR
                pingywon
                I agree that /24 is 255.255.255.0 or 192.268.x.0 to 192.168.x.255
                That’s why these issues are making me crazy aka can’t figure them out.
                  pingywon
                  FOUND A WAY TO RESOLVE THIS!
                  Add
                  cat /etc/modprobe.d/ipv6.conf
                  # Don't load ipv6 by default
                  alias net-pf-10 off
                  # uncommented
                  alias ipv6 off
                  # added
                  options ipv6 disable_ipv6=1
                  # this is needed for not loading ipv6 driver
                  blacklist ipv6
                  to turn off all IPv6 on the Raspi.
                  Than edit all the IPv6 out of your config file.
                          ipWhitelist: [
                                  "192.168.0.92",
                                  "192.168.0.1/24",
                                  "127.0.0.1"
                  I still have the .92 in there from testing. It is not needed.
                  did a sudo reboot just for safe measure and now it all seems to be working as intended. No real idea what the actual issue was…but it is resolved. FINALLY! :)
                  • lavolp3L
                    lavolp3 Module Developer
                    Maybe I have missed this from someone else, but one important thing about the whitelisting message:
                    “This device is not allowed to access your mirror.
                    Please check your config.js or config.js.sample to change this.”
                    The EXACT SAME message appears (in my case) if the config.js has syntax errors. Locally your mirror will tell you that there is no config file or just give you a black screen, but if you try to reach it from outside through a browser (Firefox and Chrome in my case) with a broken config.js, you will get the whitelisting message above.
                    So, before trying to get your ipWhitelist in the right shape, make sure you have no other syntax errors with the mirror, e.g. using
                    npm run config:check
                    If you had some and had them corrected, be safe and restart the mirror.
                    Below you can see the example in my case.
                    pi@magicmirror2:~ $ tail ~/.pm2/logs/mm-out-0.log
                    No helper found for module: helloworld.
                    All module helpers loaded.
                    Server started ...
                    Launching application.
                    Access denied to IP address: 66.249.93.64
                    Access denied to IP address: 80.157.5.50
                    pi@magicmirror2:~ $ cd MagicMirror/
                    pi@magicmirror2:~/MagicMirror $ npm run config:check
                    > magicmirror@2.1.2 config:check /home/pi/MagicMirror
                    > node tests/configs/check_config.js
                    Checking file...  /home/pi/MagicMirror/config/config.js
                    Line 260 col 9 Expected ']' to match '[' from line 26 and instead saw '{'.
                    Line 261 col 16 Expected '}' to match '{' from line 11 and instead saw 'module'.
                    Line 261 col 22 Missing semicolon.
                    Line 261 col 16 Unrecoverable syntax error. (95% scanned).
                    pi@magicmirror2:~/MagicMirror $ sudo nano config/config.js
                    Your configuration file don't containt syntax error :)
                    pi@magicmirror2:~/MagicMirror $ pm2 restart mm
                    [PM2] Applying action restartProcessId on app [mm](ids: 0)
                    [PM2] [mm](0) ✓
                    │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                    │ mm       │ 0  │ fork │ 901 │ online │ 6       │ 0s     │ 18% │ 2.3 MB   │ pi   │ disabled │
                     Use `pm2 show ` to get more details about an app
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    ToddKlindtT 1 Reply Last reply
                    • G
                      Gxnfr Ali @mochman
                      tail -f ~/.pm2/logs/mm-out-0.log
                      Use pm2 show to get more details about an app
                      pi@raspberry:~ $ tail -f ~/.pm2/logs/mm-out-0.log
                      Module helper loaded: MMM-OnScreenMenu
                      No helper found for module: MMM-PrayerTime.
                      No helper found for module: MMM-Advent.
                      Module helper loaded: MMM-FRITZ-Box-Callmonitor
                      No helper found for module: MMM-Callmonitor-Current-Call.
                      no find out ipWhiteList
                      • O
                        Oss
                        I just updated to the latest version of MM and am having White-list issues once again. I am using my exact same config.js file that was allowing any incoming connection. prior to the upgrade. I have attempted to debug but am not seeing any connection refusals in the mm-out-0.log. I have tried various fixes from posts on this forum, including disabling IPv6. I have confirmed my CIDR criteria using https://www.ipaddressguide.com/cidr#range attempting different variations to get anything to pass through with no luck.
                        I use MMM-syslog as a notification system from various sources and am basically in the dark now. Is there anyone having similar issues with the latest version, any luck on how to fix?
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Oss
                          @Oss
                          Have you tried this at the beginning of your config?:
                          var config = {
                          	address: "0.0.0.0",
                          	port: 8080,
                          	ipWhitelist: [],
                          O 1 Reply Last reply
                          Reply Quote 5
                          • O
                            Oss @Mykle1
                            @Mykle1
                            My hats off to you Mykle1, made that change to my config file and its working perfectly!! Thank you so much for your quick reply!!
                            Reply Quote 2
                            • Mykle1M
                              @Oss
                              'Welcome, mate.
                              Peace!
                              • I
                                illskool
                                Hello All. I recently upgraded my magic mirror and no matter what changes I make I can’t get ipwhitelist to work. I have searched the forums and every suggestion I have come across hasn’t rectified my issue. I had it working just fine prior to the upgrade. Any suggestions would be greatly appreciated.
                                Thanks,
                                Illskool
                                lavolp3L 1 Reply Last reply
                                • lavolp3L
                                  lavolp3 Module Developer @illskool
                                  @illskool
                                  How long ago was your last update?
                                  Just to be sure, have you tried @Mykle1’s solution, which seems to help in most of the cases this has happened in recent months?
                                  var config = {
                                      address: "0.0.0.0",
                                      port: 8080,
                                      ipWhitelist: [],
                                  adding the “address” part on the top of the config? This seems to be mandatory for the newer versions of MM.
                                  Also, be sure to have no syntax error in your config.
                                  Run
                                  from your MM directory and see of there are no errors.
                                  Done all that?
                                  • I
                                    illskool
                                    @lavolp3
                                    Thanks for the quick response. I’m not sure if I just overlooked it or if I’m just exhausted from trying to figure this issue out for the past several hours, but either way your tip solved my problem. I thank you very much.
                                    I’ve been working on a new project to stream a camera I have setup on another raspberry pi on my local network to the magic mirror. My oil tank is under my house in a crawl space and I’m tired of making the crawl every couple of weeks to see how much oil I have left. I was able to use an infrared camera to stream the video and display it on the mirror using Iframe. I didn’t want it to be visible on the mirror unless I wanted to do a quick check and thats when I realized that the remote module would solve my issue but I couldn’t access it. You have helped finish my project. I can now go to sleep:)
                                    Cheers
                                      svenr
                                      I tried everything wich is written in this post but i cant make it all the time it says:
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @svenr
                                        @svenr said in ipWhitelist HowTo:
                                        Are you saying that this is in your config.js file and you still cannot connect?
                                        var config = {
                                            address: "0.0.0.0",
                                            port: 8080,
                                            ipWhitelist: [],
                                          svenr @Mykle1
                                          @Mykle1 alt text
                                          Yes right but maybe i have another mistake i am a beginner and i have not really a idea about it
                                          link text
                                          • Mykle1M
                                            @svenr
                                            Looking at the picture you provided shows your ipWhitelist: [], is populated. Can you try it just like this? ipWhitelist: [],
                                            • 3 / 5
