    ipWhitelist HowTo
    83 Posts 36 Posters 162.7k Views 34 Watching
    • G
      Gxnfr Ali @mochman
      @mochman said in ipWhitelist HowTo:
      tail -f ~/.pm2/logs/mm-out-0.log
      Use pm2 show to get more details about an app
      pi@raspberry:~ $ tail -f ~/.pm2/logs/mm-out-0.log
      Module helper loaded: MMM-OnScreenMenu
      No helper found for module: MMM-PrayerTime.
      No helper found for module: MMM-Advent.
      Module helper loaded: MMM-FRITZ-Box-Callmonitor
      No helper found for module: MMM-Callmonitor-Current-Call.
      no find out ipWhiteList
      • O
        Oss
        I just updated to the latest version of MM and am having White-list issues once again. I am using my exact same config.js file that was allowing any incoming connection. prior to the upgrade. I have attempted to debug but am not seeing any connection refusals in the mm-out-0.log. I have tried various fixes from posts on this forum, including disabling IPv6. I have confirmed my CIDR criteria using https://www.ipaddressguide.com/cidr#range attempting different variations to get anything to pass through with no luck.
        I use MMM-syslog as a notification system from various sources and am basically in the dark now. Is there anyone having similar issues with the latest version, any luck on how to fix?
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Oss
          @Oss
          Have you tried this at the beginning of your config?:
          var config = {
          	address: "0.0.0.0",
          	port: 8080,
          	ipWhitelist: [],
          O 1 Reply Last reply Reply Quote 5
          • O
            Oss @Mykle1
            @Mykle1
            My hats off to you Mykle1, made that change to my config file and its working perfectly!! Thank you so much for your quick reply!!
            • Mykle1M
              @Oss
              'Welcome, mate.
              Peace!
              • I
                illskool
                Hello All. I recently upgraded my magic mirror and no matter what changes I make I can’t get ipwhitelist to work. I have searched the forums and every suggestion I have come across hasn’t rectified my issue. I had it working just fine prior to the upgrade. Any suggestions would be greatly appreciated.
                Thanks,
                Illskool
                • lavolp3L
                  lavolp3 Module Developer @illskool
                  @illskool
                  How long ago was your last update?
                  Just to be sure, have you tried @Mykle1’s solution, which seems to help in most of the cases this has happened in recent months?
                  var config = {
                      address: "0.0.0.0",
                      port: 8080,
                      ipWhitelist: [],
                  adding the “address” part on the top of the config? This seems to be mandatory for the newer versions of MM.
                  Also, be sure to have no syntax error in your config.
                  Run
                  npm run config:check
                  from your MM directory and see of there are no errors.
                  Done all that?
                  • I
                    illskool
                    @lavolp3
                    Thanks for the quick response. I’m not sure if I just overlooked it or if I’m just exhausted from trying to figure this issue out for the past several hours, but either way your tip solved my problem. I thank you very much.
                    I’ve been working on a new project to stream a camera I have setup on another raspberry pi on my local network to the magic mirror. My oil tank is under my house in a crawl space and I’m tired of making the crawl every couple of weeks to see how much oil I have left. I was able to use an infrared camera to stream the video and display it on the mirror using Iframe. I didn’t want it to be visible on the mirror unless I wanted to do a quick check and thats when I realized that the remote module would solve my issue but I couldn’t access it. You have helped finish my project. I can now go to sleep:)
                    Cheers
                      svenr
                      I tried everything wich is written in this post but i cant make it all the time it says:
                      This device is not allowed to access your mirror.
                      Please check your config.js or config.js.sample to change this.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @svenr
                        @svenr said in ipWhitelist HowTo:
                        Are you saying that this is in your config.js file and you still cannot connect?
                        var config = {
                            address: "0.0.0.0",
                            port: 8080,
                            ipWhitelist: [],
                          svenr @Mykle1
                          @Mykle1 alt text
                          Yes right but maybe i have another mistake i am a beginner and i have not really a idea about it
                          link text
                          • Mykle1M
                            @svenr
                            Looking at the picture you provided shows your ipWhitelist: [], is populated. Can you try it just like this? ipWhitelist: [],
                              svenr @Mykle1
                              @Mykle1 like this it works. Thank you for your help!
                              • Mykle1M
                                @svenr
                                Good. Now all the devices on your network have access. If you want to limit access to specific devices then you should search this forum for ipWhitelist info. This topic has been discussed at length
                                • ToddKlindtT
                                  ToddKlindt @lavolp3
                                  @lavolp3 said in ipWhitelist HowTo:
                                  Maybe I have missed this from someone else, but one important thing about the whitelisting message:
                                  “This device is not allowed to access your mirror.
                                  Please check your config.js or config.js.sample to change this.”
                                  The EXACT SAME message appears (in my case) if the config.js has syntax errors. Locally your mirror will tell you that there is no config file or just give you a black screen, but if you try to reach it from outside through a browser (Firefox and Chrome in my case) with a broken config.js, you will get the whitelisting message above.
                                  So, before trying to get your ipWhitelist in the right shape, make sure you have no other syntax errors with the mirror, e.g. using
                                  If you had some and had them corrected, be safe and restart the mirror.
                                  Below you can see the example in my case.
                                  pi@magicmirror2:~ $ tail ~/.pm2/logs/mm-out-0.log
                                  No helper found for module: helloworld.
                                  All module helpers loaded.
                                  Server started ...
                                  Launching application.
                                  Access denied to IP address: 66.249.93.64
                                  Access denied to IP address: 80.157.5.50
                                  pi@magicmirror2:~ $ cd MagicMirror/
                                  pi@magicmirror2:~/MagicMirror $ npm run config:check
                                  > magicmirror@2.1.2 config:check /home/pi/MagicMirror
                                  > node tests/configs/check_config.js
                                  Checking file...  /home/pi/MagicMirror/config/config.js
                                  Line 260 col 9 Expected ']' to match '[' from line 26 and instead saw '{'.
                                  Line 261 col 16 Expected '}' to match '{' from line 11 and instead saw 'module'.
                                  Line 261 col 22 Missing semicolon.
                                  Line 261 col 16 Unrecoverable syntax error. (95% scanned).
                                  pi@magicmirror2:~/MagicMirror $ sudo nano config/config.js
                                  Your configuration file don't containt syntax error :)
                                  pi@magicmirror2:~/MagicMirror $ pm2 restart mm
                                  [PM2] Applying action restartProcessId on app [mm](ids: 0)
                                  [PM2] [mm](0) ✓
                                  │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                                  │ mm       │ 0  │ fork │ 901 │ online │ 6       │ 0s     │ 18% │ 2.3 MB   │ pi   │ disabled │
                                   Use `pm2 show ` to get more details about an app
                                  I wanted to quote this as it just happened to me. MM was working fine remotely. I made some edits to config.js and got the dreaded “This device is not allowed to access your mirror…" message. I hadn’t edited the whitelist, so I started doing all of the network troubleshooting. Seeing this post reminded me I had done some edits and sure enough, I missed a comma somewhere and the screwed it all up. Fixing that unrelated entry in the config.js made this error go away.
                                  • lavolp3L
                                    lavolp3 Module Developer @ToddKlindt
                                    • A
                                      AndrewVircks
                                      I have tried all of the suggestions to get MMM-Remote-Control to work and I cannot figure anything out. Any help would be appreciated. I keep getting Cannot GET /remote.html and I’m not sure what to do from here.
                                        mochman Module Developer
                                        That doesn’t sound like an ipWhitelist problem. Did you install MMM-Remote-Control per the instructions? If so, what exactly are you getting your error message on and what are the IPs of your magicmirror and device?
                                        • A
                                          AndrewVircks @mochman
                                            payal09
                                            Please help me out, i do all the things whatever consulted in forum to access the remote control, but it is not working from my phone, or any other devices.
                                            It just working on the pc from where raspberry pi is operated through vnc.
                                            Please, help me. My project submission date is too close, please help.
                                            • 3 / 5
