    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 65.3k Views 10 Watching
      j.e.f.f Project Sponsor Module Developer @cowboysdude
      @cowboysdude is the idea that the mini atx sits beside the mirror as opposed to being built? Say on a console table with just an HDMI cable running to the screen?
      • cowboysdudeC
        cowboysdude Module Developer @j.e.f.f
        @j.e.f.f No it will be underneath as I’m building into a type of desk/cabinet
        • SnilleS
          Snille Module Developer
          All, I have got the Libre Computer now. Trying my best to get the mirror up. Ran in to a small hitch. There is no chromedriver for arm64 yet. They are working on it and there is a PR but it has not yet gone completely through it seems. I’ll see if I can figure it out some how anyway. :)
          I’ll come back to this thread as soon as I gotten MM up and running.
            stacywebb @Snille
            @Snille
            I’ve gotten it working a Pine Rock64 (arm64 also).
            Downloaded electron-v1.7.5-linux-arm64.zip listed under electron’s PR
            One thing to note: when downloading from the link, the site’s cert has expired.
            From terminal:
            // Since the cert for the site has expired (but is safe)
            wget --no-check-certificate https://www.hamidx9.ir/dl/electron_arm64/electron-v1.7.5-linux-arm64.zip
            // Important make sure to unzip to your electron path
            unzip electron-v1.7.5-linux-arm64.zip ~/MagicMirror/node_modules/electron/dist/
            Once done just started as usual (npm start).
            SnilleS 1 Reply Last reply
            Reply Quote 3
            • SnilleS
              Snille Module Developer @stacywebb
              @stacywebb Thank you! I’ll try it out as soon as I got some time. Have you compared with a Pi3?
                stacywebb @Snille
                @Snille
                I haven’t done any benchmarking as of yet. Once I do, I’ll post the results.
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @stacywebb
                  @stacywebb said in stronger Raspberry Pi 3 Alternatives:
                  If you could do some comparisons using nmon between a Pi3 and the Rock64 I’d really be interested in the results, as they pertain to this topic.
                  https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
                  Otherwise, I’m looking forward to your results on the Rock64.
                  • cruunnerrC
                    cruunnerr
                    @Mykle1
                    https://youtu.be/FjbzKfeHB_8?t=8m10s
                    As i understood, u were able to use GPIO commands the same way u do on a raspberry. Seems to be a nice option
                    Benchmarks at 08:10
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @cruunnerr
                      @cruunnerr
                      No WiFi? NFW!
                      N 1 Reply Last reply
                      • N
                        ninjabreadman @Mykle1
                        @Mykle1 The b/g/n adapter is a further $7, and will also give you an antenna for better connectivity. The more robust (and likely excessive) b/g/n/ac dual-antenna is $22.
                        Has anyone tried running MM on an Intel Compute Stick? I’m not normally a fan, but it seems it would suit the form factor and be easily placed behind a mirror, and has more fulsome specs to accommodate advanced modules, media streaming, etc.
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @ninjabreadman
                          @ninjabreadman
                          No, but I’ve used, and am using, old laptop boards (and one netbook) with ubuntu. They can be gotten on the cheap and come with everything you need. :-)
                          • cruunnerrC
                            cruunnerr
                            Well, i need to say that especially for me, the ability to use GPIOs is important. Unfortunately the power of the raspi’s & co is not as good as x86 systems.
                            Does anyone know if it would be possible to use MagicMirror on a x86 system and uses external GPIOs? I installed an MM instance on a virtual machine running Linux. When i add a module which uses GPIOs i get errors. Is there a possibility (maybe with server-client)
                            • emloweE
                              emlowe Module Developer
                              You mean something like this:
                              https://www.adafruit.com/product/2264
                              I just did a google for “USB GPIO breakout board”
                              -Earle
                              • cruunnerrC
                                cruunnerr
                                @emlowe said in stronger Raspberry Pi 3 Alternatives:
                                do you think its just that simple? that would be great.
                                The question is, if the program code or the configuration will be the same as on a RPi. Or are u need to do some complicated hacks to use the board with MM?
                                edit:
                                okay… i searched now, too.
                                Found this:
                                https://www.raspberrypi.org/blog/gpio-expander/
                                what do u guys think about that?
                                • emloweE
                                  Well, adafruit has python sample code. You likely need the node FT232H module to use it from JS.
                                  https://www.npmjs.com/package/FT232H
                                  Does it actually work - I have no idea - that board is also apparently out of stock :-)
                                  Sample python code below
                                  # Import standard Python time library.
                                  import time
                                  # Import GPIO and FT232H modules.
                                  import Adafruit_GPIO as GPIO
                                  import Adafruit_GPIO.FT232H as FT232H
                                  # Temporarily disable the built-in FTDI serial driver on Mac & Linux platforms.
                                  FT232H.use_FT232H()
                                  # Create an FT232H object that grabs the first available FT232H device found.
                                  ft232h = FT232H.FT232H()
                                  # Configure digital inputs and outputs using the setup function.
                                  # Note that pin numbers 0 to 15 map to pins D0 to D7 then C0 to C7 on the board.
                                  ft232h.setup(7, GPIO.IN)   # Make pin D7 a digital input.
                                  ft232h.setup(8, GPIO.OUT)  # Make pin C0 a digital output.
                                  # Loop turning the LED on and off and reading the input state.
                                  print 'Press Ctrl-C to quit.'
                                  while True:
                                  	# Set pin C0 to a high level so the LED turns on.
                                  	ft232h.output(8, GPIO.HIGH)
                                  	# Sleep for 1 second.
                                  	time.sleep(1)
                                  	# Set pin C0 to a low level so the LED turns off.
                                  	ft232h.output(8, GPIO.LOW)
                                  	time.sleep(1)
                                  	# Read the input on pin D7 and print out if it's high or low.
                                  	level = ft232h.input(7)
                                  	if level == GPIO.LOW:
                                  		print 'Pin D7 is LOW!'
                                  	else:
                                  		print 'Pin D7 is HIGH!'
                                  • Mykle1M
                                    @cruunnerr said in stronger Raspberry Pi 3 Alternatives:
                                    Well, it’s certainly possible to run MM on a x86 system. I haven’t a clue about external GPIO usage but it looks promising. For now, I use my mirror for some things and my Alexa for everything else.
                                    • 3 / 3
