    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 63.7k Views 10 Watching
      stacywebb @Snille
      @Snille
      I’ve gotten it working a Pine Rock64 (arm64 also).
      Downloaded electron-v1.7.5-linux-arm64.zip listed under electron’s PR
      One thing to note: when downloading from the link, the site’s cert has expired.
      From terminal:
      // Since the cert for the site has expired (but is safe)
      wget --no-check-certificate https://www.hamidx9.ir/dl/electron_arm64/electron-v1.7.5-linux-arm64.zip
      // Important make sure to unzip to your electron path
      unzip electron-v1.7.5-linux-arm64.zip ~/MagicMirror/node_modules/electron/dist/
      Once done just started as usual (npm start).
      SnilleS 1 Reply Last reply Reply Quote 3
      • SnilleS Offline
        Snille Module Developer @stacywebb
        @stacywebb Thank you! I’ll try it out as soon as I got some time. Have you compared with a Pi3?
          stacywebb @Snille
          @Snille
          I haven’t done any benchmarking as of yet. Once I do, I’ll post the results.
            Mykle1 Project Sponsor Module Developer @stacywebb
            @stacywebb said in stronger Raspberry Pi 3 Alternatives:
            If you could do some comparisons using nmon between a Pi3 and the Rock64 I’d really be interested in the results, as they pertain to this topic.
            https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
            Otherwise, I’m looking forward to your results on the Rock64.
            • cruunnerrC Offline
              cruunnerr
              @Mykle1
              https://youtu.be/FjbzKfeHB_8?t=8m10s
              As i understood, u were able to use GPIO commands the same way u do on a raspberry. Seems to be a nice option
              Benchmarks at 08:10
                Mykle1 Project Sponsor Module Developer @cruunnerr
                @cruunnerr
                No WiFi? NFW!
                N 1 Reply Last reply Reply Quote 1
                • N Offline
                  ninjabreadman @Mykle1
                  @Mykle1 The b/g/n adapter is a further $7, and will also give you an antenna for better connectivity. The more robust (and likely excessive) b/g/n/ac dual-antenna is $22.
                  Has anyone tried running MM on an Intel Compute Stick? I’m not normally a fan, but it seems it would suit the form factor and be easily placed behind a mirror, and has more fulsome specs to accommodate advanced modules, media streaming, etc.
                    Mykle1 Project Sponsor Module Developer @ninjabreadman
                    @ninjabreadman
                    No, but I’ve used, and am using, old laptop boards (and one netbook) with ubuntu. They can be gotten on the cheap and come with everything you need. :-)
                      cruunnerr
                      Well, i need to say that especially for me, the ability to use GPIOs is important. Unfortunately the power of the raspi’s & co is not as good as x86 systems.
                      Does anyone know if it would be possible to use MagicMirror on a x86 system and uses external GPIOs? I installed an MM instance on a virtual machine running Linux. When i add a module which uses GPIOs i get errors. Is there a possibility (maybe with server-client)
                      • emloweE Offline
                        emlowe Module Developer
                        You mean something like this:
                        https://www.adafruit.com/product/2264
                        I just did a google for “USB GPIO breakout board”
                        -Earle
                          cruunnerr
                          @emlowe said in stronger Raspberry Pi 3 Alternatives:
                          do you think its just that simple? that would be great.
                          The question is, if the program code or the configuration will be the same as on a RPi. Or are u need to do some complicated hacks to use the board with MM?
                          edit:
                          okay… i searched now, too.
                          Found this:
                          https://www.raspberrypi.org/blog/gpio-expander/
                          what do u guys think about that?
                          • emloweE Offline
                            Well, adafruit has python sample code. You likely need the node FT232H module to use it from JS.
                            https://www.npmjs.com/package/FT232H
                            Does it actually work - I have no idea - that board is also apparently out of stock :-)
                            Sample python code below
                            # Import standard Python time library.
                            import time
                            # Import GPIO and FT232H modules.
                            import Adafruit_GPIO as GPIO
                            import Adafruit_GPIO.FT232H as FT232H
                            # Temporarily disable the built-in FTDI serial driver on Mac & Linux platforms.
                            FT232H.use_FT232H()
                            # Create an FT232H object that grabs the first available FT232H device found.
                            ft232h = FT232H.FT232H()
                            # Configure digital inputs and outputs using the setup function.
                            # Note that pin numbers 0 to 15 map to pins D0 to D7 then C0 to C7 on the board.
                            ft232h.setup(7, GPIO.IN)   # Make pin D7 a digital input.
                            ft232h.setup(8, GPIO.OUT)  # Make pin C0 a digital output.
                            # Loop turning the LED on and off and reading the input state.
                            print 'Press Ctrl-C to quit.'
                            while True:
                            	# Set pin C0 to a high level so the LED turns on.
                            	ft232h.output(8, GPIO.HIGH)
                            	# Sleep for 1 second.
                            	time.sleep(1)
                            	# Set pin C0 to a low level so the LED turns off.
                            	ft232h.output(8, GPIO.LOW)
                            	time.sleep(1)
                            	# Read the input on pin D7 and print out if it's high or low.
                            	level = ft232h.input(7)
                            	if level == GPIO.LOW:
                            		print 'Pin D7 is LOW!'
                            	else:
                            		print 'Pin D7 is HIGH!'
                              @cruunnerr said in stronger Raspberry Pi 3 Alternatives:
                              Well, it’s certainly possible to run MM on a x86 system. I haven’t a clue about external GPIO usage but it looks promising. For now, I use my mirror for some things and my Alexa for everything else.
                              • 3 / 3
