    Slim, Frameless Bathroom Mirror with a 27" Display
    42 Posts 15 Posters 61.7k Views 24 Watching
      MyMirror
      Very good - thanks for sharing!
        schlachtkreuzer6
        Thank you for all your informations! So last question ^^ how is the sound with the exciters? Maybe we need here a YouTube video 😁😁
          MyMirror
          … and a few more from my site :-)
          • Can you show us, how do you dismantled the foot
            and how do you attach the power cable on the screen?
          • What about the temperature of the monitor? Will not be too hot in the tight construction?
          • Do you apply black foil on the back side of the mirror to improve the mirror effect?
          Thanks for all your tips and pictures!
            MyMirror
            and did you get that:
            –> recall off PDS241/271
            R 1 Reply Last reply
              reaper81
              @schlachtkreuzer6
              “…how is the sound with the exciters?”
              Let me put it this way, the exciter sound better than the sound from the phone.
              But you should not promise too much. The bass is quite good but high frequencies, as for the voices go under.
              I can only speculate if stronger exciters in conjunction with a stronger amp would help here. The main reason for
              the use of the exciter was the ease of installation and the small depth. If the mirror was not as flat as possible
              I should have used real speakers with their own acoustic cabinet.
              S B 2 Replies Last reply
                reaper81
                @MyMirror
                “…Can you show us, how do you dismantled the foot…”
                Sorry but i have no pictures from the dismantling the foot. But is realy easy. All you have to do is remove the back of the palstik from the monitor, which is held with plastic noses. It is best to use a slightly wider spatula or car interior tool. Then you can already see the three screws with which the foot on the monitor screwed. In the end, only the monitor foot has to be screwed on to get the cable out of it.
                “…What about the temperature…”
                I do not know if the monitor temperature will be a problem in the future. If so, ventilation holes could still be drilled in the upper part of the frame.
                “…apply black foil on the back side…”
                No, the black film is there to reflect incident light just as the black monitor does. If I did not do that, I would have a darker reflection in the area of the monitor than in the areas without a monitor.
                  reaper81 @MyMirror
                  @MyMirror
                  damm shit. Without the monitor foot I will probably not be able to complain the monitor.
                  M 1 Reply Last reply
                    schlachtkreuzer6 @reaper81
                    @reaper81
                    Thanks! I found some nice speakers with 10W/20W and about 40mm depth so my mirror will be something about 50-60mm depth overall. And I was thinking about exciters as well. But I am afraid of a lot distortion in the mirror itself when you play music at higher levels and standing in front of it. What do you say about that? Is it hard to see or is it like in some cheap cars that you can’t read numberplates in the backmirror because the whole car is shaking and also the glass and mirrors…
                    My speakers: https://www.neuhold-elektronik.at/catshop/product_info.php?cPath=242_253&products_id=6537
                    I am using an amp HAT and four of those speakers. But I’m missing some deeper frequencies (110…20.000 Hz) you hear that there is a lot missing in playing music. So I thought I will get an exciter with low frequencies ~20-200Hz to get a fuller sound. There are basically TV speakers so they are quite good at higher frequencies.
                    I really should post my project here ^^
                      MyMirror @reaper81
                      @reaper81
                      You should ask the service …
                      I think, that the will deliver the power adapter and you should give them the old one.
                        MyMirror @schlachtkreuzer6
                        @schlachtkreuzer6
                        Yes, of course you should!
                          reaper81
                          @schlachtkreuzer6
                          there are no visible distortions on the mirrorglas with my exciters. I think if you want a really good audiosound, buy separate ceiling speakers.
                          …and yes, you should post yout project. We are all excited.
                            @reaper81 nah… :( no space for ceiling speakers. I will try it with extra exciters 😊 I also thinking of an audio crossover :)
                            thanks for your thoughts and info again
                              JamieH1986
                              Looking brilliant 👍 how is the mirror now? Just curious as I have just got my mirror made, it has a aluminium Spray to make it 2-way.
                              I have asked the question to them regarding what glue to use to stick a frame down they have advised me not to use glue as the chemicals could bubble and look like it’s melting? I really want the frameless look but cautious
                                reaper81
                                @JamieH1986
                                Thanks a lot. I don’t know how the mirror is right now, because the mirror hangs in the bathroom of my brother. Maybe i don’t understand your questions. In the answer to Relic i have linked the glue i used. (soudal fix all high track). The glue is not direct on glas of the mirror. The glas is covered with a black window foil. So it is impossible to see bubbles in the mirror. Before i used the glue i made several gluetests with some smalle peaces of wood, foil and mirrorglas. The glue don’t melt the foil and the connect between wood, foil and glas is very strong.
                                  bucci @reaper81
                                  @reaper81 I’ve built speakers with exciters before, and the only way I found to really get nice treble was to use a tweeter in addition to the exciter. You need a crossover so the tweeters don’t blow if you crank the volume. I would say if you got tweeters you could point them up and hide them behind the mirror? This mirror build is very nicely done!
                                  Here is a link to my exciter speaker build for the curious. https://www.youtube.com/watch?v=D6hGmyNImaI
                                  Mykle1M S R 3 Replies Last reply
                                  Reply Quote 4
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @bucci
                                    @bucci said in Slim, Frameless Bathroom Mirror with a 27" Display:
                                    I was curious. Now, I’m amazed. I didn’t even know something like this was possible. Good stuff! :-)
                                      schlachtkreuzer6 @bucci
                                      @bucci
                                      Cool!
                                      • E
                                        EduardZ
                                        Hi @reaper81,
                                        great job. Your mirror looks very nice. Could you explain how do you attach the display behind the mirror?
                                        I read something about a black window foil some posts before. Do you affix the whole back side of the mirror with the black window foil and attach the display with the glue you mentioned? Do you have a link for the window foil? Do you cut out the area for the display? Is the frame of the display visible if you are standing in front of the mirror?
                                        I hope you could give me some hints. I do not find any instructions how to preferably attach the display behind the mirror.
                                        Many thanks an best regards
                                        Eduard
                                          reaper81 @EduardZ
                                          @EduardZ
                                          The display lies flush between the middle and upper cedar wood and is held only by angles screwed behind it, as can be seen in the picture below.
                                          alt text
                                          alt text
                                          It is important that the foil is only removed in the area on the mirror, where later also the display should be visible. It is not bad either if a little too much foil was removed, it happened to me too. Then you just stick something on the glass or even better directly on the annoying place on the display, such as on the silver strip on my display.
                                          O 1 Reply Last reply
                                            reaper81 @bucci
                                            @bucci
                                            You really should not have shown me the link. Now I am dissatisfied with my solution. But your are rigth, small tweeters at the non visible top of the frame in connection with the exciters would produce a better sound. Well maybe the next mirror …
                                            • 2 / 3
