    what mic?
    5 Posts 4 Posters 3.4k Views 3 Watching
    • N Offline
      navyvette87
      I bought this, it said effective above 1 meter, well it only works out to 1 meter, anyone have one that will work across the room? Say 15-20ft.
      https://www.amazon.com/gp/product/B014MASID4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
      • N Offline
        ninjabreadman
        I don’t have one, but this Hufear USB mic at Amazon claims a range of 10 ft, and the MXL AC-404 claims 25 feet.
        There are different types of mics, but I imagine you’re looking for an omnidirectional, boundary (sits on a flat surface) mic. You may also want to consider esthetics/appearance, depending on where you decide to place your mic.
        You might also consider mic placement; there’s nothing that says the mic must be placed with your mirror. It will depend on your mirror, walls, and furniture, but you could run a wire to a more equidistant point for better audio (even having it recessed in a frame could create a too-narrow aperture for the mic).
        • cruunnerrC Offline
          cruunnerr
          I am looking for a far field mic, too.
          I just googled a little bit and this one should be very good: https://www.seeedstudio.com/ReSpeaker-Mic-Array-Far-field-w%2F-7-PDM-Microphones-p-2719.html
          It detects your voice from 360° and the review are good as well. Maybe its also possible to install it on top or under your mirror so it will be hidden. Unfortunately its a little bit expensive.
          I also heard, that the PS3 eye camera got a far field mic build in and it works out of the box on a raspberry: https://www.amazon.de/Sony-9600459-PLAYSTATION-Eye/dp/B000W3YQ1Y
          In some cases it could be, that USB mic’s got a little more latency…
          Anyhow, i would appreciate to hear what mic u buy and maybe u can give a little review ^^
          • N Offline
            navyvette87
            I took the end off the one I have and removed the cloth on the end of the element. Now it will detect about 14ft. across the room. But I have to raise my voice a bit. There is 7 holes in the end cap. Im going to see if I can drill out and replace and see what that does.
            I have everything sitting next to my entertainment center right now, it picks up words from the tv, sometimes it knows what it is saying and other it doesnt. I plan to move it across the room when its all done, and that will end up about the same distance on the other side of the room.
            I will add to this if I end up purchasing another.
              Mykle1 Project Sponsor Module Developer @cruunnerr
              @cruunnerr said in what mic?:
              I can confirm this. I’ve been doing a lot of voice work recently and there is a noticeable lag when using a USB microphone. If you’re using a Pi then you don’t have any choice but to use USB. :-/
