    Magic Mirror with AI
    64 Posts 14 Posters 83.4k Views 18 Watching
    • T
      thommy86
      @akshaybahadur21 Any timeframe on when you will release the code. I am starting a new project, where I will use an old laptop. So this seems very interesting!
      akshaybahadur21A 1 Reply Last reply
      • akshaybahadur21A
        akshaybahadur21 @cowboysdude
        @cowboysdude https://github.com/raghavpatnecha/smartmirror
        • akshaybahadur21A
          akshaybahadur21 @hayman
          @hayman https://github.com/raghavpatnecha/smartmirror
          • akshaybahadur21A
            akshaybahadur21 @thommy86
            @thommy86 https://github.com/raghavpatnecha/smartmirror
            T 1 Reply Last reply
            • akshaybahadur21A
              akshaybahadur21 @cyberphox
              @cyberphox https://github.com/raghavpatnecha/smartmirror
              • akshaybahadur21A
                akshaybahadur21 @shep99
                @shep99 https://github.com/raghavpatnecha/smartmirror
                • akshaybahadur21A
                  akshaybahadur21 @cruunnerr
                  @cruunnerr https://github.com/raghavpatnecha/smartmirror
                  • T
                    thommy86 @akshaybahadur21
                    @akshaybahadur21 Thanks for the update. What OS are you running MM on? Or what is the best OS to build a MM. I only used a rpi 3 and now going to use an old i7 laptop.
                    • ChrisC
                      Chris
                      I tried to install it on a pc running windows seven pro.
                      It did not work and I must admit that I did not understand everything in the installation procedure.
                      Can anyone help me ?
                      Thank you in advance,
                      Regards,
                      akshaybahadur21A B 2 Replies Last reply
                      • akshaybahadur21A
                        akshaybahadur21 @Chris
                        @Chris not for windows. It requires homebrew and several other packages which are not available on windows.
                        • ChrisC
                          Chris
                          under which operating system is it possible to install it since a raspberry is not powerful enough?
                          A pc running a Linux operating system? if so, which one is the most suitable?
                          Regards,
                            bhepler Module Developer @Chris
                            @Chris You might be able to run a virtual machine host on Windows 7 Pro and then run this mirror instance as a VM. Most likely you’ll want to run Ubuntu 16.04 desktop or possibly a version of Debian. @akshaybahadur21 will have the details as to which one.
                            At work, we use a Debian 9.1.0 installation for slimmed down testing. It doesn’t take up much memory or resources at all.
                            • cowboysdudeC
                              Error while trying to run… notice the error at the bottom which says I need version 2.11 when I update it says I already have 2.11 yet this continues to say I don’t…
                              HTTPConnectionPool(host='localhost', port=8080): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused',))
                              Found face
                                File "bot.py", line 679, in
                                  bot.start()
                                File "bot.py", line 53, in start
                                  recognizer, audio = self.speech.listen_for_audio()
                                File "/home/cowboysdude/Smart_Mirror/speech.py", line 33, in listen_for_audio
                                  m = sr.Microphone()
                                File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 79, in __init__
                                  self.pyaudio_module = self.get_pyaudio()
                                File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 113, in get_pyaudio
                                  raise AttributeError("PyAudio 0.2.11 or later is required (found version {})".format(pyaudio.__version__))
                              AttributeError: PyAudio 0.2.11 or later is required (found version 0.2.8)
                              • cowboysdudeC
                                Has ANYONE got this to work yet?
                                • akshaybahadur21A
                                  akshaybahadur21 @bhepler
                                  @bhepler @Chris I used Ubuntu VM. You guys can also do the same
                                  • akshaybahadur21A
                                    @cowboysdude I believe you have another application running on 8080. Try killing that app and restarting magic mirror. I never faced the issue
                                    • cowboysdudeC
                                      I told you I do indeed have an apache server running on 80 so that’s not an option. I changed the bot.py file to 8091 so that shouldn’t be an issue. If it doesn’t work it’s just not going to work. I need my other server so taking it down is not an option. I have no issue running the mirror on 8090 and the server at the same time…it’s been running for months like that…
                                      HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9850>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                        File "bot.py", line 679, in <module>
                                          bot.start()
                                        File "bot.py", line 49, in start
                                          requests.get("http://localhost:8090/clear")
                                        File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
                                          return request('get', url, params=params, **kwargs)
                                        File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
                                          return session.request(method=method, url=url, **kwargs)
                                        File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
                                          resp = self.send(prep, **send_kwargs)
                                        File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
                                          r = adapter.send(request, **kwargs)
                                        File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 508, in send
                                          raise ConnectionError(e, request=request)
                                      requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /clear (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9890>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                      • cowboysdudeC
                                        I’m pretty sure no one else has gotten this to work either… It as what I thought a month ago… a no go… I deleted it.
                                        • Mykle1M
                                          Oy! 12345
                                          Edit: The forum insisted I have an 8 character post. :-/
                                          • H
                                            hayman
                                            @cowboysdude said in Magic Mirror with AI:
                                            is there any better how to install…?and what is the best os to use for …?
                                            i olso got fout i’ve probleem with python bot.py…
                                            • 3 / 4
