    Magic Mirror with AI
    64 Posts 14 Posters 83.4k Views 18 Watching
    • akshaybahadur21A
      akshaybahadur21 @cowboysdude
      @cowboysdude https://github.com/raghavpatnecha/smartmirror
      • akshaybahadur21A
        akshaybahadur21 @hayman
        @hayman https://github.com/raghavpatnecha/smartmirror
        • akshaybahadur21A
          akshaybahadur21 @thommy86
          @thommy86 https://github.com/raghavpatnecha/smartmirror
          T 1 Reply Last reply
          • akshaybahadur21A
            akshaybahadur21 @cyberphox
            @cyberphox https://github.com/raghavpatnecha/smartmirror
            • akshaybahadur21A
              akshaybahadur21 @shep99
              @shep99 https://github.com/raghavpatnecha/smartmirror
              • akshaybahadur21A
                akshaybahadur21 @cruunnerr
                @cruunnerr https://github.com/raghavpatnecha/smartmirror
                • T
                  thommy86 @akshaybahadur21
                  @akshaybahadur21 Thanks for the update. What OS are you running MM on? Or what is the best OS to build a MM. I only used a rpi 3 and now going to use an old i7 laptop.
                  • ChrisC
                    Chris
                    I tried to install it on a pc running windows seven pro.
                    It did not work and I must admit that I did not understand everything in the installation procedure.
                    Can anyone help me ?
                    Thank you in advance,
                    Regards,
                    akshaybahadur21A B 2 Replies Last reply
                    • akshaybahadur21A
                      akshaybahadur21 @Chris
                      @Chris not for windows. It requires homebrew and several other packages which are not available on windows.
                      • ChrisC
                        Chris
                        under which operating system is it possible to install it since a raspberry is not powerful enough?
                        A pc running a Linux operating system? if so, which one is the most suitable?
                        Regards,
                          bhepler Module Developer @Chris
                          @Chris You might be able to run a virtual machine host on Windows 7 Pro and then run this mirror instance as a VM. Most likely you’ll want to run Ubuntu 16.04 desktop or possibly a version of Debian. @akshaybahadur21 will have the details as to which one.
                          At work, we use a Debian 9.1.0 installation for slimmed down testing. It doesn’t take up much memory or resources at all.
                          akshaybahadur21A 1 Reply Last reply
                          • cowboysdudeC
                            Error while trying to run… notice the error at the bottom which says I need version 2.11 when I update it says I already have 2.11 yet this continues to say I don’t…
                            HTTPConnectionPool(host='localhost', port=8080): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused',))
                            Found face
                              File "bot.py", line 679, in
                                bot.start()
                              File "bot.py", line 53, in start
                                recognizer, audio = self.speech.listen_for_audio()
                              File "/home/cowboysdude/Smart_Mirror/speech.py", line 33, in listen_for_audio
                                m = sr.Microphone()
                              File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 79, in __init__
                                self.pyaudio_module = self.get_pyaudio()
                              File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 113, in get_pyaudio
                                raise AttributeError("PyAudio 0.2.11 or later is required (found version {})".format(pyaudio.__version__))
                            AttributeError: PyAudio 0.2.11 or later is required (found version 0.2.8)
                            • cowboysdudeC
                              Has ANYONE got this to work yet?
                              • akshaybahadur21A
                                akshaybahadur21 @bhepler
                                @bhepler @Chris I used Ubuntu VM. You guys can also do the same
                                • akshaybahadur21A
                                  @cowboysdude I believe you have another application running on 8080. Try killing that app and restarting magic mirror. I never faced the issue
                                  • cowboysdudeC
                                    I told you I do indeed have an apache server running on 80 so that’s not an option. I changed the bot.py file to 8091 so that shouldn’t be an issue. If it doesn’t work it’s just not going to work. I need my other server so taking it down is not an option. I have no issue running the mirror on 8090 and the server at the same time…it’s been running for months like that…
                                    HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9850>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                      File "bot.py", line 679, in <module>
                                        bot.start()
                                      File "bot.py", line 49, in start
                                        requests.get("http://localhost:8090/clear")
                                      File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
                                        return request('get', url, params=params, **kwargs)
                                      File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
                                        return session.request(method=method, url=url, **kwargs)
                                      File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
                                        resp = self.send(prep, **send_kwargs)
                                      File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
                                        r = adapter.send(request, **kwargs)
                                      File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 508, in send
                                        raise ConnectionError(e, request=request)
                                    requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /clear (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9890>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                    • cowboysdudeC
                                      I’m pretty sure no one else has gotten this to work either… It as what I thought a month ago… a no go… I deleted it.
                                      • Mykle1M
                                        Oy! 12345
                                        Edit: The forum insisted I have an 8 character post. :-/
                                        • H
                                          hayman
                                          @cowboysdude said in Magic Mirror with AI:
                                          is there any better how to install…?and what is the best os to use for …?
                                          i olso got fout i’ve probleem with python bot.py…
                                          • cowboysdudeC
                                            cowboysdude Module Developer @hayman
                                            @hayman I deleted it. It’s just not going to work. Trust me I’ve tried several different things… went online to find out how to fix the errors and found next to nothing so as far as I’m concerned this is a dead issue …
                                            • 3 / 4
