    Magic Mirror with AI
    64 Posts 14 Posters 83.4k Views 18 Watching
    • F
      fischi87 @akshaybahadur21
      @akshaybahadur21
      very nice!!! how it works with the voice? i mean i need also a mic? is there a doc, how can i build this ai with hardware and so on?
      akshaybahadur21A 1 Reply Last reply
      • akshaybahadur21A
        akshaybahadur21 @fischi87
        @fischi87 yeah… you need to have a microphone… For detailed documentation see : https://github.com/akshaybahadur21/Smart_Mirror
        • T
          thommy86
          @akshaybahadur21 Any timeframe on when you will release the code. I am starting a new project, where I will use an old laptop. So this seems very interesting!
          • akshaybahadur21A
            akshaybahadur21 @cowboysdude
            @cowboysdude https://github.com/raghavpatnecha/smartmirror
            • akshaybahadur21A
              akshaybahadur21 @hayman
              @hayman https://github.com/raghavpatnecha/smartmirror
              • akshaybahadur21A
                akshaybahadur21 @thommy86
                @thommy86 https://github.com/raghavpatnecha/smartmirror
                T 1 Reply Last reply
                • akshaybahadur21A
                  akshaybahadur21 @cyberphox
                  @cyberphox https://github.com/raghavpatnecha/smartmirror
                  • akshaybahadur21A
                    akshaybahadur21 @shep99
                    @shep99 https://github.com/raghavpatnecha/smartmirror
                    • akshaybahadur21A
                      akshaybahadur21 @cruunnerr
                      @cruunnerr https://github.com/raghavpatnecha/smartmirror
                      • T
                        thommy86 @akshaybahadur21
                        @akshaybahadur21 Thanks for the update. What OS are you running MM on? Or what is the best OS to build a MM. I only used a rpi 3 and now going to use an old i7 laptop.
                        • ChrisC
                          Chris
                          I tried to install it on a pc running windows seven pro.
                          It did not work and I must admit that I did not understand everything in the installation procedure.
                          Can anyone help me ?
                          Thank you in advance,
                          Regards,
                          akshaybahadur21A B 2 Replies Last reply
                          • akshaybahadur21A
                            akshaybahadur21 @Chris
                            @Chris not for windows. It requires homebrew and several other packages which are not available on windows.
                            • ChrisC
                              Chris
                              under which operating system is it possible to install it since a raspberry is not powerful enough?
                              A pc running a Linux operating system? if so, which one is the most suitable?
                              Regards,
                                bhepler Module Developer @Chris
                                @Chris You might be able to run a virtual machine host on Windows 7 Pro and then run this mirror instance as a VM. Most likely you’ll want to run Ubuntu 16.04 desktop or possibly a version of Debian. @akshaybahadur21 will have the details as to which one.
                                At work, we use a Debian 9.1.0 installation for slimmed down testing. It doesn’t take up much memory or resources at all.
                                • cowboysdudeC
                                  Error while trying to run… notice the error at the bottom which says I need version 2.11 when I update it says I already have 2.11 yet this continues to say I don’t…
                                  HTTPConnectionPool(host='localhost', port=8080): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused',))
                                  Found face
                                    File "bot.py", line 679, in
                                      bot.start()
                                    File "bot.py", line 53, in start
                                      recognizer, audio = self.speech.listen_for_audio()
                                    File "/home/cowboysdude/Smart_Mirror/speech.py", line 33, in listen_for_audio
                                      m = sr.Microphone()
                                    File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 79, in __init__
                                      self.pyaudio_module = self.get_pyaudio()
                                    File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 113, in get_pyaudio
                                      raise AttributeError("PyAudio 0.2.11 or later is required (found version {})".format(pyaudio.__version__))
                                  AttributeError: PyAudio 0.2.11 or later is required (found version 0.2.8)
                                  • cowboysdudeC
                                    Has ANYONE got this to work yet?
                                    • akshaybahadur21A
                                      akshaybahadur21 @bhepler
                                      @bhepler @Chris I used Ubuntu VM. You guys can also do the same
                                      • akshaybahadur21A
                                        @cowboysdude I believe you have another application running on 8080. Try killing that app and restarting magic mirror. I never faced the issue
                                        • cowboysdudeC
                                          I told you I do indeed have an apache server running on 80 so that’s not an option. I changed the bot.py file to 8091 so that shouldn’t be an issue. If it doesn’t work it’s just not going to work. I need my other server so taking it down is not an option. I have no issue running the mirror on 8090 and the server at the same time…it’s been running for months like that…
                                          HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9850>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                            File "bot.py", line 679, in <module>
                                              bot.start()
                                            File "bot.py", line 49, in start
                                              requests.get("http://localhost:8090/clear")
                                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
                                              return request('get', url, params=params, **kwargs)
                                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
                                              return session.request(method=method, url=url, **kwargs)
                                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
                                              resp = self.send(prep, **send_kwargs)
                                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
                                              r = adapter.send(request, **kwargs)
                                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 508, in send
                                              raise ConnectionError(e, request=request)
                                          requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /clear (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9890>: Failed to establish a new connection: [Errno 111] Connection refused',))
                                          • cowboysdudeC
                                            I’m pretty sure no one else has gotten this to work either… It as what I thought a month ago… a no go… I deleted it.
                                            • 3 / 4
