    Magic Mirror with AI
    64 Posts 14 Posters 82.2k Views 18 Watching
    • akshaybahadur21A
      akshaybahadur21 @cruunnerr
      @cruunnerr https://github.com/raghavpatnecha/smartmirror
      • T
        thommy86 @akshaybahadur21
        @akshaybahadur21 Thanks for the update. What OS are you running MM on? Or what is the best OS to build a MM. I only used a rpi 3 and now going to use an old i7 laptop.
        • ChrisC
          Chris
          I tried to install it on a pc running windows seven pro.
          It did not work and I must admit that I did not understand everything in the installation procedure.
          Can anyone help me ?
          Thank you in advance,
          Regards,
          akshaybahadur21A B 2 Replies Last reply Reply Quote 0
          • akshaybahadur21A
            akshaybahadur21 @Chris
            @Chris not for windows. It requires homebrew and several other packages which are not available on windows.
            • ChrisC
              Chris
              under which operating system is it possible to install it since a raspberry is not powerful enough?
              A pc running a Linux operating system? if so, which one is the most suitable?
              Regards,
                bhepler Module Developer @Chris
                @Chris You might be able to run a virtual machine host on Windows 7 Pro and then run this mirror instance as a VM. Most likely you’ll want to run Ubuntu 16.04 desktop or possibly a version of Debian. @akshaybahadur21 will have the details as to which one.
                At work, we use a Debian 9.1.0 installation for slimmed down testing. It doesn’t take up much memory or resources at all.
                akshaybahadur21A 1 Reply Last reply Reply Quote 0
                • cowboysdudeC
                  Error while trying to run… notice the error at the bottom which says I need version 2.11 when I update it says I already have 2.11 yet this continues to say I don’t…
                  HTTPConnectionPool(host='localhost', port=8080): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused',))
                  Found face
                    File "bot.py", line 679, in
                      bot.start()
                    File "bot.py", line 53, in start
                      recognizer, audio = self.speech.listen_for_audio()
                    File "/home/cowboysdude/Smart_Mirror/speech.py", line 33, in listen_for_audio
                      m = sr.Microphone()
                    File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 79, in __init__
                      self.pyaudio_module = self.get_pyaudio()
                    File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 113, in get_pyaudio
                      raise AttributeError("PyAudio 0.2.11 or later is required (found version {})".format(pyaudio.__version__))
                  AttributeError: PyAudio 0.2.11 or later is required (found version 0.2.8)
                  • cowboysdudeC
                    Has ANYONE got this to work yet?
                    • akshaybahadur21A
                      akshaybahadur21 @bhepler
                      @bhepler @Chris I used Ubuntu VM. You guys can also do the same
                      • akshaybahadur21A
                        akshaybahadur21 @cowboysdude
                        @cowboysdude I believe you have another application running on 8080. Try killing that app and restarting magic mirror. I never faced the issue
                        • cowboysdudeC
                          I told you I do indeed have an apache server running on 80 so that’s not an option. I changed the bot.py file to 8091 so that shouldn’t be an issue. If it doesn’t work it’s just not going to work. I need my other server so taking it down is not an option. I have no issue running the mirror on 8090 and the server at the same time…it’s been running for months like that…
                          HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9850>: Failed to establish a new connection: [Errno 111] Connection refused',))
                            File "bot.py", line 679, in <module>
                              bot.start()
                            File "bot.py", line 49, in start
                              requests.get("http://localhost:8090/clear")
                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
                              return request('get', url, params=params, **kwargs)
                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
                              return session.request(method=method, url=url, **kwargs)
                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
                              resp = self.send(prep, **send_kwargs)
                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
                              r = adapter.send(request, **kwargs)
                            File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 508, in send
                              raise ConnectionError(e, request=request)
                          requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /clear (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9890>: Failed to establish a new connection: [Errno 111] Connection refused',))
                          • cowboysdudeC
                            I’m pretty sure no one else has gotten this to work either… It as what I thought a month ago… a no go… I deleted it.
                            • Mykle1M
                              Oy! 12345
                              Edit: The forum insisted I have an 8 character post. :-/
                              • H
                                hayman
                                @cowboysdude said in Magic Mirror with AI:
                                is there any better how to install…?and what is the best os to use for …?
                                i olso got fout i’ve probleem with python bot.py…
                                • cowboysdudeC
                                  cowboysdude Module Developer @hayman
                                  @hayman I deleted it. It’s just not going to work. Trust me I’ve tried several different things… went online to find out how to fix the errors and found next to nothing so as far as I’m concerned this is a dead issue …
                                    cyberphox @cowboysdude
                                    @cowboysdude darn…this looked promising…and cool too!
                                    • cowboysdudeC
                                      cowboysdude Module Developer @cyberphox
                                      @cyberphox said in Magic Mirror with AI:
                                      I agree with you but HackerHouse originally made this and it is suffering from the same problems this one is and they aren’t answering questions very well… so I took a 1/2 a day on this… that’s enough.
                                      • Mykle1M
                                        Oh hell no. If you can’t get it then that leaves me out. :-/
                                        cruunnerrC 1 Reply Last reply Reply Quote 2
                                        • cruunnerrC
                                          cruunnerr @Mykle1
                                          @Mykle1 said in Magic Mirror with AI:
                                          me, too ^^
                                            sispheor
                                            Hi Guys,
                                            I’m a member of Kalliope project team.
                                            We’ve made a module to bind both project.
                                            Here is a demo: https://youtu.be/QHwctPbJ2ZY
                                            J 1 Reply Last reply Reply Quote 2
                                            • 3 / 4
