    Magic Mirror with AI
    64 Posts 14 Posters 83.4k Views 18 Watching
    • cowboysdudeC
      Has ANYONE got this to work yet?
      • akshaybahadur21A
        akshaybahadur21 @bhepler
        @bhepler @Chris I used Ubuntu VM. You guys can also do the same
        • akshaybahadur21A
          akshaybahadur21 @cowboysdude
          @cowboysdude I believe you have another application running on 8080. Try killing that app and restarting magic mirror. I never faced the issue
          • cowboysdudeC
            I told you I do indeed have an apache server running on 80 so that’s not an option. I changed the bot.py file to 8091 so that shouldn’t be an issue. If it doesn’t work it’s just not going to work. I need my other server so taking it down is not an option. I have no issue running the mirror on 8090 and the server at the same time…it’s been running for months like that…
            HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /microphone?enabled=False (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9850>: Failed to establish a new connection: [Errno 111] Connection refused',))
              File "bot.py", line 679, in <module>
                bot.start()
              File "bot.py", line 49, in start
                requests.get("http://localhost:8090/clear")
              File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
                return request('get', url, params=params, **kwargs)
              File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
                return session.request(method=method, url=url, **kwargs)
              File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
                resp = self.send(prep, **send_kwargs)
              File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
                r = adapter.send(request, **kwargs)
              File "/usr/local/lib/python2.7/dist-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 508, in send
                raise ConnectionError(e, request=request)
            requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=8090): Max retries exceeded with url: /clear (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fa61a0b9890>: Failed to establish a new connection: [Errno 111] Connection refused',))
            • cowboysdudeC
              I’m pretty sure no one else has gotten this to work either… It as what I thought a month ago… a no go… I deleted it.
              • Mykle1M
                Oy! 12345
                Edit: The forum insisted I have an 8 character post. :-/
                • H
                  hayman
                  @cowboysdude said in Magic Mirror with AI:
                  is there any better how to install…?and what is the best os to use for …?
                  i olso got fout i’ve probleem with python bot.py…
                  • cowboysdudeC
                    cowboysdude Module Developer @hayman
                    @hayman I deleted it. It’s just not going to work. Trust me I’ve tried several different things… went online to find out how to fix the errors and found next to nothing so as far as I’m concerned this is a dead issue …
                      cyberphox @cowboysdude
                      @cowboysdude darn…this looked promising…and cool too!
                      • cowboysdudeC
                        cowboysdude Module Developer @cyberphox
                        @cyberphox said in Magic Mirror with AI:
                        I agree with you but HackerHouse originally made this and it is suffering from the same problems this one is and they aren’t answering questions very well… so I took a 1/2 a day on this… that’s enough.
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          Oh hell no. If you can’t get it then that leaves me out. :-/
                          cruunnerrC 1 Reply Last reply
                          Reply Quote 2
                          • cruunnerrC
                            cruunnerr @Mykle1
                            @Mykle1 said in Magic Mirror with AI:
                            me, too ^^
                              sispheor
                              Hi Guys,
                              I’m a member of Kalliope project team.
                              We’ve made a module to bind both project.
                              Here is a demo: https://youtu.be/QHwctPbJ2ZY
                              J 1 Reply Last reply
                              Reply Quote 2
                                joseska @sispheor
                                @sispheor said in Magic Mirror with AI:
                                Kalliope project
                                Wowww… can I try the module
                                Thanks…
                                  sispheor @joseska
                                  @joseska
                                  Info here: https://forum.magicmirror.builders/topic/6615/kalliope-assistant-mm
                                  • 3 / 4
