    Changing wether API?
    4 Posts 3 Posters 2.1k Views 3 Watching
    • N Offline
      navyvette87
      Can the weather API be changed? I have an API key for weatherunderground, but dont know which url to use, and do I only have to put it in the config file?
      Mykle1M D 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @navyvette87
        @navyvette87
        I’m not really sure I understand your question.
        What weather module are you trying to use?
          doubleT Module Developer @navyvette87
          @navyvette87
          If you’re talking about the default weather modules, they only work with keys for http://www.openweathermap.org
          But you can remove those from your config and add MMM-Wunderground instead following its instructions: https://github.com/RedNax67/MMM-WunderGround
            https://github.com/cowboysdude/MMM-NOAA also uses the Weather Underground API and it seems to be a very popular module with excellent support from the author
