    [MMM-MyRadio] Web Radio Player
    34 Posts 13 Posters 25.6k Views 12 Watching
    • tbbearT
      tbbear Module Developer
      Description:
      The module plays up to 4 diff. Radiostations and if they show sender and RDS data also, u can select the station and the volume
      with ur mouse, touchpad or touchscreen, soon also via MMM-voice.
      The module is based on the idea and code of MMM-TouchPlayerBasic by Pierre Broberg
      Download:
      [card:tbbear/MMM-MyRadio]
      Version 1.0
      Robert the Bear
      cowboysdudeC Cr4z33C 2 Replies Last reply
      Reply Quote 3
      • cowboysdudeC
        cowboysdude Module Developer @tbbear
        @tbbear I was just on here looking for a radio module!!! LOL
        THANKS!!!
          Rolandb
          Hello everybody.
          I have a little problem.
          When I start the mirror, the radio module starts to charge briefly and then stops. and i can not do anything
          tbbearT 1 Reply Last reply
          • tbbearT
            tbbear Module Developer @Rolandb
            @Rolandb are u using my modules? or still the MMM-RadioDe?
            Robert the Bear
              Rolandb
              I’m using your Module…
              • tbbearT
                The actuall Version is now ready V1.01 voice controlled with MMM-voice
                Robert the Bear
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @tbbear
                  @tbbear nice to read that you integrated your module into my voice recognition. Would be interested to see a demo video how well it works with the music playing at the same time 👍
                  • tbbearT
                    tbbear Module Developer @strawberry 3.141
                    @strawberry-3.141 Thanks, u did a great job with ur modules. Now my report:
                    Everything is working perfektly with voice in my Radio Player as long as i dont
                    start playing music… When i do, voice tries to understand the lyrics of the songs
                    and doesnt listen to commands anymore. At the moment i try to put the mic more away
                    from the speakers so i hope this will work better.
                    Robert the Bear
                    • strawberry 3.141S
                      @tbbear that’s what I kind of expected 😄
                      • tbbearT
                        Next step done, i hope that @fewieden is not angry that i raped his MMM-AlarmClock module, lol
                        So in my version of MMM-AlarmClock if u select “MyRadio” as sound it will start the the MyRadio Player.
                        if u do for ex. 30 min later the next alarm it will switch it off and also turn the Mirror display off.
                        (This is what my wife wants in the morning in the bathroom …)
                        Robert the Bear
                        • tbbearT
                          @strawberry-3.141 I will report u about the results with a longer distance from speaker to mic the next days
                          Robert the Bear
                          • G
                            gismo2006
                            Hey,
                            @tbbear
                            I use a other voice modul and a other music modul but the problem was the same. With headphones everything works fine but without the lyrics will crash the voice recognition.
                            I have tested several module and distance and and and. but nothing.
                            Maybe you can solve this problem.
                            Greets gismo
                            • tbbearT
                              Hey to all. ( @gismo2006 @strawberry-3.141 )
                              here are the first results of my testing: i use a USB MiniMic and now i took a 1meter Cable to put the mic
                              above the Mirror (its about 50 cm above), and the first tests worked fine. I will report more…
                              Robert the Bear
                                Rolandb
                                The module is really great. And especially the help of Robert in my problem. The module and the developer are really recommended. That’s a 1 with a star.
                                  pinsdorf Module Developer
                                  Nice module, indeed. Just an idea: Raspberry Pi 3 has Bluetooth. Would be cool to connect BT speakers and play the radio.
                                  We could also use it for remote audio notification". Say, the mirror is linked to a BT speaker in the next room and it plays a sound when certain notification is received, e.g. new mail …
                                  Anybody tried this?
                                  • tbbearT
                                    tbbear Module Developer @pinsdorf
                                    @pinsdorf Thanks, Bluetooth is no problem cause MyRadio can play on any audio output, u only need the correct config. and also if u want to start radio with a signal from another modules just do it
                                    with
                                    this.sendNotification(‘NEXT_RADIO’);
                                    like i do with the Alarmclock module.
                                    Robert the Bear
                                      Mike7400
                                      Any idea how to edit config to play on bluetooth device?
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @Mike7400
                                        @mike7400
                                        You might try alsamixer to choose your output device.
                                          Mike7400
                                          Output device is OK. When I run sh everything works, I can hear a music. But when I run MM I cannot hear nothing
                                            raspialex2018
                                            The same problem like Mike…No output over MM. If i start the script over bash sound and output ok. Can you help me please?
