    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 349.6k Views 54 Watching
      Mykle1 Project Sponsor Module Developer @hoofta
      @hoofta
      Good work, mate! I like it. :-)
        PaulB
        @cruunnerr,
        Thank you so much! What a great ‘How-to’- Guide :)
        You and your post helped a lot. :)
        • H Offline
          hnperkins
          hey all, im having a issue with my pir module. i have run the pir.py script and its constantly scrolling the … until i move and then it stops for a brief second, and when i load the module in my config file the screen just stays black. is this some kind of interference or do i just have it hooked up backwards or something?
          randomnoiseR 1 Reply Last reply Reply Quote 0
          • randomnoiseR Offline
            randomnoise @hnperkins
            @hnperkins if the script is working the opposite way round it could be that you have a pir board which uses inverted signals. The board I had originally worked this way. So when no motion is detected it gives you a 1 & when you move it gives you a 0. Instead of running the script try typing gpio read 0 (substitute the pin number you used here… remember gpio “wiring pi” numbering will be different to the number you input in your file. See https://pinout.xyz/). It only shows the current state so you need to keep putting this in as you move in front of the sensor to test it. Hit up + enter to “retype” the command quickly in the console.
            If this is the case then unfortunately the script will not work in your case… it’s written for true or 1 to be when movement is detected.
            If you use paviro’s module there is a configuration option to invert the input pin.
            As to the screen being black when starting mm. It’s probably an error in your configuration. Search the forum to find info on how to check the config as that has been well covered.
            H 1 Reply Last reply Reply Quote 1
            • H Offline
              hnperkins @randomnoise
              @randomnoise ok so when i do the gpio read command it always shows a 1, when i use a pin its not connected to it shows a 0, is this what you were talking about?
                @hnperkins yes, if it’s always showing a 1 then your sensor is ‘inverted’ to the standard way most pir boards work. Note it should go to 0 when the pir detects movement (you might need to continually wave your hand in front of the pir at the exact moment you hit enter after typing the gpio read to see the 0. If you never see a 0 then you may have a faulty pir).
                Although I initially did get my ‘inverted’ sensor working using the invert configuration option in paviros module, it eventually stopped working correctly (my mirror would register a false detection every 3 mins or so causing my screen to stay always on). Not sure why it broke… seemed to happen after I upgraded to a newer version of mm, but issue didn’t go away after I tried rolling back. Final thing I did to stop false triggering was to install a ferrite choke on my input wire & to move where my pi sat at the back of my monitor (it was quite close to the monitors power converter initially).
                Ultimately the way I got it working was to buy a different pir board (the kind with the 2 potentiometers for sensitivity & time adjustment) which also happened to be 0 for no movement & 1 for movement). I then used the pir.py script instead of the module to trigger screen on / off. I was fairly sure it wasn’t a single faulty pir unit (mine came in a pack of 3) but nothing I did got it working so in the end spending an extra fiver on a different type of pir seemed worth it to me.
                • F Offline
                  fabbr
                  I had the script running and all I got was “…” turns out I had the POWER and GROUND swapped because I was following the drawing on the initial post. I suggest looking at the your PIR board to make sure you are connecting the wires on the correct order.
                  Overall fantastic write up. Thanks for sharing
                  • H Offline
                    hnperkins @fabbr
                    @fabbr i just got it working today. hadn’t had time to mess with it much. i was able to invert it in the config for the plugin and its been working great
                    • F Offline
                      fabbr
                      I used the method 2.2 Using PIR-Script and it work fine however, after a long period of time (that the screen is off and I am not doing anything on the raspberry) when I move in front of the PIR I can see the ON signal is sent to my monitor (the monitor LED change) but all I get is a blank screen.
                      I did some testing and notice that when I connect with VNC to the raspberry the screen immediately comes back on so it makes me wonder if there’s some kind of screensaver or something of that nature that is on.
                      Does anyone knows anything about this or had this problem before?
                        Mykle1 Project Sponsor Module Developer @fabbr
                        @fabbr
                        Have you disabled the screensaver? The easiest, most common way of doing that is to install xscreensaver and disable the screensaver that way
                        F 1 Reply Last reply Reply Quote 1
                        • F Offline
                          fabbr @Mykle1
                          @Mykle1 Thank you that was the problem. Xscreensaver was easy use. Thanks
                          Another problem I had was: when I changed the orientation of my monitor when it was coming back on all I saw was a black screen… so I did more research and found that that I could replace the tvservice for:
                          vcgencmd display_power 0 turns off the screen
                          vcgencmd display_power 1 turns on the screen
                          That worked better with my monitor for some reason.
                            blebbens
                            Thanks for this tutorial…
                            I am using a PIR. The monitor switches on immediately after detection of motion. I am looking for an option to switch on the monitor if a person stands in front of it for 10 seconds. Mine is a floor mirror, so some people are crossing the floor many times a day without looking at the mirror.
                            cruunnerrC 1 Reply Last reply Reply Quote 0
                            • cruunnerrC Offline
                              cruunnerr @blebbens
                              @blebbens said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                              If u use the external PIR script (point 2.2) u could try to change line 25 in the script and define a TURNON-DELAY.
                              if turned_off and time.time() >= TURNON_DELAY:
                              The whole script would look like this:
                              #!/usr/bin/env python
                              import sys
                              import time
                              import RPi.GPIO as io
                              import subprocess
                              io.setmode(io.BCM)
                              SHUTOFF_DELAY = 120 # in seconds, how long the monitor will be on until next button press or PIR detection
                              TURNON_DELAY = 10
                              PIR_PIN = 22       # 15 on the board (this needn't to be a PIR. Can be a button also)
                              LED_PIN = 16      # optional, don't use as Relay-PIN. It just shows detection time of the PIR without delay time
                              def main():
                                  io.setup(PIR_PIN, io.IN)
                                  io.setup(LED_PIN, io.OUT)
                                  turned_off = False
                                  last_motion_time = time.time()
                                  while True:
                                      if io.input(PIR_PIN):
                                          io.output(LED_PIN, io.LOW)
                                          print ".",
                                          sys.stdout.flush()
                                              turned_off = False
                                              turn_on()
                                      else:
                                          if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                              turned_off = True
                                              turn_off()
                                          if not turned_off and time.time() > (last_motion_time + 1):
                                              io.output(LED_PIN, io.HIGH)
                                      time.sleep(.1)
                              def turn_on():
                              	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                              def turn_off():
                              	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                              if __name__ == '__main__':
                                  try:
                                      main()
                                  except KeyboardInterrupt:
                                      io.cleanup()
                              Don’t know if it will work. Just brainstorming cause i haven’t much time
                              K 1 Reply Last reply Reply Quote 1
                              • E Offline
                                erycken
                                This is really helpful! Thanks.
                                I have a PIR motion sensor set up, but I am trying to work out if it is possible (or better yet already exists) to have the motion sensor become unresponsive/display not actually active during night hours (predefined by me) as I have the mirror set up in my room and if I get up during the night I don’t want it coming on as I never turn lights on since it takes forever for me to get back to sleep!
                                I do want the motion sensor to work like normal during the day however. Does the Cronjob method prevent the sensor from working during the on hours?
                                  cruunnerr
                                  Hey mate,
                                  the way that will work in every case is to use a relay to interrupt the voltage for the pir.
                                  Then write two little bash files and execute them via cronjob.
                                  turn on relay with GPIO 7 and give the PIR voltage:
                                  gpio mode 7 out
                                  gpio write 7 1
                                  turn off the relay with GPIO 7 and interrupt the PIR voltage:
                                  gpio mode 7 out
                                  gpio write 7 0
                                  otherwise u could use if statement with a datetime check within the python script. something like this: https://stackoverflow.com/questions/10048249/how-do-i-determine-if-current-time-is-within-a-specified-range-using-pythons-da/10048290
                                  If i find some time, i will try to adjust the python script from this tutorial…
                                  • K Offline
                                    Kecko
                                    Hey, big thanks for this tutorial!
                                    i want to use method 2.2 the PIR-Script.
                                    My Problem is: it looks like there is always a movement detected!
                                    i stuck on the point
                                    “You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you several …
                                    End the test with “ctrl+c”
                                    It always print “…” for me.
                                    That means that there is a movement all time right?
                                    even if I disconnect the GPIO Pin there are all the dots…
                                    i Realy cant figure out what i do wrong in this case… i mean it is only copy and paste and i did it the third time right now. also tried the MMM-PIR-Sensor module… not happy with it.
                                    i realy dont know what to do now!
                                      cruunnerr
                                      Not much time, so here comes just a short think…
                                      1. You have two cogs on the pir. Move the time delay completely left or right (so it will just give a very short impulse).
                                      2. Set the Shutoff-delay in the script to 5 seconds (just to try)
                                      3. Try another GPIO…
                                      4. try a pull-up or pull-down resistor like used at thy button-method
                                      Bild Text
                                      K 1 Reply Last reply Reply Quote 2
                                      • K Offline
                                        Kecko @cruunnerr
                                        @cruunnerr oh my god… i love you
                                        it was realy just the Time-delay Adjust!!!
                                        i turned it completly left and it seems to work now!
                                        but i have to say i must work with the command display_power=0 - display_power=1
                                        so if the hdmi turns off my display shows for 1 second no signal
                                        if the display turns on it shows HDMI1
                                        but thats fine… i guess it is a “problem” of the display itself.
                                        thank you for the fast and easy response
                                        your tutorial is realy great i love it. also a noob can work with it!
                                        maybe you should add a line with a tip for the Time-delay Adjust
                                        • K Offline
                                          komodoteler @cruunnerr
                                          @cruunnerr Hello, My PIR works completely fine (with method #6, just turn black) but I also plan to build my mirror as floor mirror and wondering the same as @blebbens
                                          I tried your suggestion but unfortunately doesn’t seems to work. the screen is on instantly if motion detected. Any other suggestion?
                                            Magno99900
                                            Hey, so I’ve been trying to get this working over the past few days using method 2.2 (pir script) I’ve verified that monitor_on/off.sh works as they should as does pir.py when run from terminal. The problem seems to be that I’m unable to get the script to auto start on boot. Any suggestions would be greatly appreciated.
                                            • 4 / 9
