    MMM-Parcel
    24 Posts 11 Posters 14.3k Views 12 Watching
    • G Offline
      goprojojo
      Great module! Are the names of the packages customizable too?
        martinkooij @goprojojo
        @goprojojo Thanks! But also thanks to Aftership.com for providing the API.
        The parcel names (titles in aftership-speak) are customizable via the aftership app, or via the aftership.com website (login -> trackings). Just select the shipment, click edit and enter your own title in the title field. This name will then appear on the mirror-screen. Let me know if that helps and answers your question.
          martinkooij @modderhut
          @modderhut . Thanks for your comment and compliments! For now you can set maxWidth: "350px" in the module config parameters or whatever pixwidth works for you. Sorry, this was an undocumented feature ;).
          Your feedback also prompted me to consider the behavior of the module in a “narrow” space. I will soon release a functional enhancement for this module in order to autoadapt the module display to a narrow(er) space, maintaining effectiveness and the “look and feel”.
          • twosquirrelsT Offline
            twosquirrels
            This is a great module, but whenever I change the compactness to anything other than 1, it fails to load. I really want 2 for “very compact”, but it just displays this:
            alt text
              martinkooij @twosquirrels
              @twosquirrels Thank you for liking the module, and this clearly seems a bug that I haven’t seen yet, and can’t reproduce at home here. Sorry. I have dropped you a PM with my contact info, if you would be willing to help me debugging your situation.
              twosquirrelsT 1 Reply Last reply Reply Quote 0
                twosquirrels @martinkooij
                @martinkooij
                This wound up being due to my own impatience. I did get “undefined” after restarting magic mirror, but if I waited a few minutes, it would appear in the desired format. Perhaps the API call wasn’t being performed yet. I was just tinkering too much to wait. Thanks again for making this module!
                  martinkooij
                  To the users: thanks for your compliments. Your comments inspire me to add new functionality. Today (2018-03-30): a layout that caters for narrow spaces on the mirror and the possibility to automatically hide delivered packages after a configurable number of days. Have fun and keep on commenting!
                    twosquirrels
                    Great! But… I seem to have messed up the update, perhaps because I tried to update from the /config folder:
                    pi@magicmirror:~/MagicMirror/config $ git pull https://github.com/martinkooij/MMM-Parcel.git
                    warning: no common commits
                    remote: Counting objects: 241, done.
                    remote: Compressing objects: 100% (23/23), done.
                    remote: Total 241 (delta 11), reused 14 (delta 4), pack-reused 214
                    Receiving objects: 100% (241/241), 682.03 KiB | 0 bytes/s, done.
                    Resolving deltas: 100% (119/119), done.
                    From https://github.com/martinkooij/MMM-Parcel
                     * branch            HEAD       -> FETCH_HEAD
                    fatal: refusing to merge unrelated histories
                    pi@magicmirror:~/MagicMirror/modules/MMM-Parcel $ git pull
                    Updating a4093aa..31ec835
                    Fast-forward
                     MMM-Parcel.js  | 160 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------------------------
                     README.md      | 135 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------------------
                     node_helper.js |  10 +++++----
                     package.json   |   2 +-
                     4 files changed, 199 insertions(+), 108 deletions(-)
                    It’s stuck at “Loading Parcel module…” How do I remove MMM-Parcel so that I can put it back correctly?
                      @twosquirrels Basically the most radical way is to remove everything MMM-Parcel from both …/config and from …/modules and make a clean install with clone. I sent you a PM, let me know if it works for you.
                        @martinkooij
                        I installed the update and used the new module code. It worked, although the “hideDelivered” doesn’t seem to be working. I have it set for “3” and as of April 5, I still have a March 28 delivery showing as delivered.
                          hideDelivered: 3, // Hide delivered parcels after 15 days.
