    MMM-Sonos - To show what your SONOS is playing.
    29 Posts 17 Posters 30.7k Views 16 Watching
    • SnilleS
      Snille Module Developer
      Description:
      This is an modification of of @Vaggan MagicMirror-SonosModule and @CFenner MagicMirror-SonosModule. It was modified to get some enhancements in visualisation and configuration. Also the module hides itself when not playing now.
      Note from me: I’m new to the MagicMirror world and Node.js, this is my first attempt to modify a module. There are probably lot’s of things that could have been done better. :)
      Screenshots:
      When starting the Mirror:
      Module on the Left side of the Mirror:
      Module in the Center of the Mirror:
      Module in the Center of the Mirror playing in 3 different zones:
      Module on the Right side of the Mirror:
      And, this is my own look on my mirrors (@ top center) using some addition in the custom.css…
      If you want my look on it, use this CSS code in your custom.css.
      /* Sonos --------------------------------------------*/
      .sonos ul .type {
          font-size: 12px;
          padding: 0px 0px;
          line-height: 12px;
          width: 260px;
      .sonos ul .room {
          font-size: 16px;
          padding: 0px 0px;
          line-height: 16px;
          width: 260px;
      .sonos ul .song {
          padding: 0px 0px;
          position: relative;
      .sonos ul .art img {
          height: 60px;
          width: 60px;
          border-radius: 50%;
          margin: 0px 0px;
          border: 2px solid #FFF;
      .sonos ul .name {
          width: 200px;
          font-size: 16px;
          padding: 0px 4px;
          line-height: 16px;
      Download:
      [card:Snille/MMM-Sonos]
      Version 0.1
      • I’m guessing that’s Vaggans version…
      Version 0.2
      • Has to be CFenners version…
      Version 0.3
      • My version… :)
      • A
        Atreo
        Hi There.
        First i need to say that i am new to both Raspberry and Magic mirror.
        Sooo happy now when i know what it can do.
        I have i problem with the sonos module, Don´t know if you can help me.
        I can not make it work, i get on the mirror saying Loading music.
        And i can see that it is saying from the terminal.
        Sono_update
        Failure: Error: Connect ECONNREFUSED 192.168.0.100
        Kind regards
        Jonas
        L C 2 Replies Last reply Reply Quote 0
        • L
          Luttich @Atreo
          @Atreo same for me
            cederstrom Module Developer @Atreo
            @Atreo Have you tried the fix in the “Known issues” section of the README? https://github.com/Snille/MMM-Sonos#known-issues
              cohron
              Guess I’m total noob but I havent figured out exactly how to install MMM-Sonos.
              1. I’m confused on installing and running node-sonos-http-api part. Does it get installed on /usr/local/lib/node_modules (I dont have that folder) but I do have /home/pi/MagicMirror/node_modules.
              2. MM is on rPI3b using the default installation from the readme but the the documentation on the api says i should install the latest nodejs. do i need to update/install? I went to https://nodejs.org/download/release/latest/ and it looks like 7.9.0 is the latest. i assume i install this on the MM rPI also. I’ll have to figure out how to git that too if so.
              3. I have my mm.sh file that auto-starts MM using pm2. Do I add a line in the mm.sh file to auto run the api on boot?
                my mm.sh
                DISPLAY=:0 npm start
              • SnilleS
                @cohron First you need to “install” the node-sonos-http-api. You can put the node-sonos-http-api on the RPi I think. I have not tried that. I have mine installed on another server. But just try it, do the following (obs I have not tried this):
                cd ~
                git clone git@github.com:jishi/node-sonos-http-api.git
                cd node-sonos-http-api
                npm install --production
                npm start
                Now, see if you can get your zones via the link: http://yourmagicmirrorip:5005/zones
                If you do, you should be able to point your config to http://localhost
                And you should see something playing, if it is playing. :)
                Now you need to make sure the http-api is running all the time.
                Use the same procedure as for the MagicMirror.
                When you have the MagicMirror and http-api running type pm2 save (if you are using pm2).
                Otherwise you have to add it to your startup manually.
                I hope this helps a bit at least. :)
                  cohron @Snille
                  @Snille
                  All right, love trial and error. Got it all up and running on my MM rPI!!!
                  Through ssh pi@192.168.0.207 (my MM ip address)
                  cd ~ //which puts me at /home/pi
                  pi@magicpi:~ $ git clone https://github.com/jishi/node-sonos-http-api.git
                  npm start
                  verify, open a browser, point to your MM’s IP like so:
                  http://192.168.0.207:5005/zones
                  you should see a page full of sonos related text, if so the hard part is done…
                  create another pm2 script named sonos.sh in ~ directory
                  cd ~
                  sonos.sh file contents:
                  cd ~/node-sonos-http-api
                  pm2 start sonos.sh
                  pm2 start mm
                  pm2 save
                  now just do the normal git for the sonos module
                  pi@magicpi:~/MagicMirror/modules $ git clone https://github.com/Snille/MMM-Sonos.git
                  fill in your config, this is mine:
                  module: ‘MMM-Sonos’,
                  header: “Playing on SONOS”,
                  position: “top_center”, // This can be any of the regions, best results in center regions
                  classes: “default everyone”,
                  // See ‘Configuration options’ for more information.
                  showStoppedRoom: false,
                  showAlbumArt: true
                  I also copied your awsome custom css content!
                  D B 2 Replies Last reply Reply Quote 0
                  • SnilleS
                    @cohron So it’s working now? Congrats! Great work! :)
                      j.e.f.f Project Sponsor Module Developer @Snille
                      • brandongomezB
                        brandongomez
                        Great module! I am new to all of this and have the module working as intended. I listen to SiriusXM, Google Play and Spotify through Sonos.
                        Google Play looks great and pulls the Artist and Track Title correctly. However, SiriusXM is sending everything together. Is there a way to format what SiriusXM sends me?
                        For example, if I go to http://IP_Address:5005/zones when using Google Play, I see… {“currentTrack”:{“artist”:“Aretha Franklin”,“title”:“Respect”,“album”:“I Never Loved A Man The Way I Love You”,“albumArtUri”
                        But if I put on a SiriusXM channel, it looks like this… {“currentTrack”:{“title”:“BR P|TYPE=SNG|TITLE Cold Little Heart|ARTIST Michael Kiwanuka|ALBUM”,“albumArtUri”
                        As a result, the SiriusXM channel shows nothing for the Artist and “BR P|TYPE=SNG|TITLE Cold Little Heart|ARTIST Michael Kiwanuka|ALBUM” for the Track. Would love to get it to show something like “Cold Little Heart, Michael Kiwanuka” instead.
                        Any help is appreciated. Thanks!
                        • SnilleS
                          Hi! Hm… Looks like the SiriusMX information is not coming out in JSON format correctly from the SonosAPI.
                          I think you may have to contact Jimmi about this. Open an issue here: https://github.com/jishi/node-sonos-http-api/issues and describe your problem. As soon as the “output” is in correct JSON format, it should be working. Usually hes quick in fixing things. :)
                          Good luck.
                          • DesaydroneD
                            Desaydrone
                            I got two sonos (for now) but on my mirror i only want to show one of this two. I don’t find how to do that, is ti possible ?
                            • Y
                              yawns Moderator @Desaydrone
                              @Desaydrone
                              I don’t have any Sonos devices. According to the read me, you can exclude zones, I guess that’s what you are after, right?
                              Just follow the download link in first post and scroll down to the bottom for options
                              DesaydroneD 1 Reply Last reply Reply Quote 0
                              • DesaydroneD
                                Desaydrone @yawns
                                @yawns
                                Thaanks i didn’t see this options !!
                                THanks a lot
                                  SuperSchenk
                                  Thank you for your work @Snille! Got it working on my mirror yesterday. Works great!
                                    Damian @cohron
                                    @cohron
                                    @Snille
                                    Can you please explian how and where to create the sonos.sh file?
                                    And how to then add the rest into that file?
                                    I’m having trouble understanding what you mean by placing a script in ~ directory…
                                    And the next part cd~sonos.sh file contents:
                                    cd ~
                                    pm2 start sonos.sh
                                    pm2 start mm
                                    pm2 save
                                      Damian @Damian
                                      @Damian said in MMM-Sonos - To show what your SONOS is playing.:
                                      cd ~
                                      pm2 start sonos.sh
                                      pm2 start mm
                                      pm2 save
                                      Okay, so I opened up my directory… created a new file in /home/pi and named it sonos.sh… going by the jumbled up way things have been written in the example above, I have tried every combination to try and make sense of what it is saying to type into terminal
                                      cd ~ sonos.sh file contents
                                      sonos.sh
                                      I will no doubt be going around in circles here trying to decypher the instructions, so can I ask anyone to please decypher this for me and tell me what and where to enter these? do I manually input them into the sonos.sh file? do I get terminal to enter them?
                                      I a
                                      l already set up PM2 over a year ago to autostart MM, and sure it was never as hard as this?
                                      this is what I get when trying
                                      pi@raspi:~ $ cd ~sonos.sh
                                      bash: cd: ~sonos.sh: No such file or directory
                                      pi@raspi:~ $ sonos.sh
                                      bash: sonos.sh: command not found
                                      pi@raspi:~ $ sonos.sh file contents:
                                      pi@raspi:~ $ cd ~/node-sonos-http-api
                                      pi@raspi:~/node-sonos-http-api $ DISPLAY=:0 npm start
                                      > sonos-http-api@1.6.0 start /home/pi/node-sonos-http-api
                                      > node server.js
                                      2018-04-16T11:21:47.702Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
                                      2018-04-16T11:21:48.670Z INFO Presets loaded: { example:
                                         { players:
                                            [ { roomName: 'Bathroom', volume: 10 },
                                              { roomName: 'Kitchen', volume: 10 },
                                              { roomName: 'Office', volume: 10 },
                                              { roomName: 'Bedroom', volume: 10 },
                                              { roomName: 'TV Room', volume: 15 } ],
                                           playMode: { shuffle: true, repeat: 'all', crossfade: false },
                                           pauseOthers: false } }
                                      2018-04-16T11:21:54.317Z ERROR Port 5005 seems to be in use already. Make sure the sonos-http-api isn't
                                          already running, or that no other server uses that port. You can specify an alternative http port
                                          with property "port" in settings.json
                                      npm ERR! Linux 4.9.35-v7+
                                      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                      npm ERR! node v6.14.1
                                      npm ERR! npm  v3.10.10
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! sonos-http-api@1.6.0 start: `node server.js`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the sonos-http-api@1.6.0 start script 'node server.js'.
                                      npm ERR! If you do, this is most likely a problem with the sonos-http-api package,
                                      npm ERR! not with npm itself.
                                      npm ERR!     node server.js
                                      npm ERR!     npm bugs sonos-http-api
                                      npm ERR! Or if that isn't available, you can get their info via:
                                      npm ERR!     npm owner ls sonos-http-api
                                      npm ERR!     /home/pi/node-sonos-http-api/npm-debug.log
                                      pi@papaspi:~/node-sonos-http-api $ pm2 start sonos.sh
                                      [PM2][ERROR] script not found : /home/pi/node-sonos-http-api/sonos.sh
                                      │ Name │ mode │ status │ ↺ │ cpu │ memory │
                                      │ mm   │ fork │ online │ 0 │ 0%  │ 0 B    │
                                       Use `pm2 show ` to get more details about an app
                                        Damian @Damian
                                        @Mods
                                        Appreciate I have posted this twice in 2 seperate posts - but this one is FAO the Developer in his original post of 1 year ago, and to the poster who replied with his fix.
                                        The other post goes to anyone here who can help me with making and executing a script, going by the example given for this module.
                                        • F
                                          flopp
                                          When I play TV sound on my Beam it will show up in Magic Mirror even if that it seems to be that is should hide
                                                          // if Sonos Playbar is in TV mode, no title is provided and therefore the room should not be displayed
                                                          var isEmpty = (artist && artist.trim().length) == 0
        && (track && track.trim().length) == 0
        && (cover && cover.trim().length) == 0;
                                          • F
                                            flopp @flopp
                                            @flopp said in MMM-Sonos - To show what your SONOS is playing.:
                                            I now have forked this and correct the problem and also done some small changes. Added radio station name when playing Radio. Showing artist and track when playing radio.
                                            https://github.com/flopp999/MMM-Sonos
