    MMM-Sonos - To show what your SONOS is playing.
    29 Posts 17 Posters 30.3k Views 16 Watching
    • DesaydroneD Offline
      Desaydrone
      I got two sonos (for now) but on my mirror i only want to show one of this two. I don’t find how to do that, is ti possible ?
      • Y Offline
        yawns Moderator @Desaydrone
        @Desaydrone
        I don’t have any Sonos devices. According to the read me, you can exclude zones, I guess that’s what you are after, right?
        Just follow the download link in first post and scroll down to the bottom for options
        DesaydroneD 1 Reply Last reply Reply Quote 0
          Desaydrone @yawns
          @yawns
          Thaanks i didn’t see this options !!
          THanks a lot
            SuperSchenk
            Thank you for your work @Snille! Got it working on my mirror yesterday. Works great!
              Damian @cohron
              @cohron
              @Snille
              Can you please explian how and where to create the sonos.sh file?
              And how to then add the rest into that file?
              I’m having trouble understanding what you mean by placing a script in ~ directory…
              And the next part cd~sonos.sh file contents:
              create another pm2 script named sonos.sh in ~ directory
              cd ~
              cd ~/node-sonos-http-api
              DISPLAY=:0 npm start
              pm2 start sonos.sh
              pm2 start mm
              pm2 save
                Damian @Damian
                @Damian said in MMM-Sonos - To show what your SONOS is playing.:
                cd ~
                pm2 start sonos.sh
                pm2 start mm
                pm2 save
                Okay, so I opened up my directory… created a new file in /home/pi and named it sonos.sh… going by the jumbled up way things have been written in the example above, I have tried every combination to try and make sense of what it is saying to type into terminal
                cd ~ sonos.sh file contents
                sonos.sh
                I will no doubt be going around in circles here trying to decypher the instructions, so can I ask anyone to please decypher this for me and tell me what and where to enter these? do I manually input them into the sonos.sh file? do I get terminal to enter them?
                I a
                l already set up PM2 over a year ago to autostart MM, and sure it was never as hard as this?
                this is what I get when trying
                pi@raspi:~ $ cd ~sonos.sh
                bash: cd: ~sonos.sh: No such file or directory
                pi@raspi:~ $ sonos.sh
                bash: sonos.sh: command not found
                pi@raspi:~ $ sonos.sh file contents:
                pi@raspi:~ $ cd ~/node-sonos-http-api
                pi@raspi:~/node-sonos-http-api $ DISPLAY=:0 npm start
                > sonos-http-api@1.6.0 start /home/pi/node-sonos-http-api
                > node server.js
                2018-04-16T11:21:47.702Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
                2018-04-16T11:21:48.670Z INFO Presets loaded: { example:
                   { players:
                      [ { roomName: 'Bathroom', volume: 10 },
                        { roomName: 'Kitchen', volume: 10 },
                        { roomName: 'Office', volume: 10 },
                        { roomName: 'Bedroom', volume: 10 },
                        { roomName: 'TV Room', volume: 15 } ],
                     playMode: { shuffle: true, repeat: 'all', crossfade: false },
                     pauseOthers: false } }
                2018-04-16T11:21:54.317Z ERROR Port 5005 seems to be in use already. Make sure the sonos-http-api isn't
                    already running, or that no other server uses that port. You can specify an alternative http port
                    with property "port" in settings.json
                npm ERR! Linux 4.9.35-v7+
                npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                npm ERR! node v6.14.1
                npm ERR! npm  v3.10.10
                npm ERR! code ELIFECYCLE
                npm ERR! sonos-http-api@1.6.0 start: `node server.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the sonos-http-api@1.6.0 start script 'node server.js'.
                npm ERR! If you do, this is most likely a problem with the sonos-http-api package,
                npm ERR! not with npm itself.
                npm ERR!     node server.js
                npm ERR!     npm bugs sonos-http-api
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!     npm owner ls sonos-http-api
                npm ERR!     /home/pi/node-sonos-http-api/npm-debug.log
                pi@papaspi:~/node-sonos-http-api $ pm2 start sonos.sh
                [PM2][ERROR] script not found : /home/pi/node-sonos-http-api/sonos.sh
                │ Name │ mode │ status │ ↺ │ cpu │ memory │
                │ mm   │ fork │ online │ 0 │ 0%  │ 0 B    │
                 Use `pm2 show ` to get more details about an app
                  Damian @Damian
                  @Mods
                  Appreciate I have posted this twice in 2 seperate posts - but this one is FAO the Developer in his original post of 1 year ago, and to the poster who replied with his fix.
                  The other post goes to anyone here who can help me with making and executing a script, going by the example given for this module.
                  • F Offline
                    flopp
                    When I play TV sound on my Beam it will show up in Magic Mirror even if that it seems to be that is should hide
                                    // if Sonos Playbar is in TV mode, no title is provided and therefore the room should not be displayed
                                    var isEmpty = (artist && artist.trim().length) == 0
                                            && (track && track.trim().length) == 0
                                            && (cover && cover.trim().length) == 0;
                    • F Offline
                      flopp @flopp
                      @flopp said in MMM-Sonos - To show what your SONOS is playing.:
                      I now have forked this and correct the problem and also done some small changes. Added radio station name when playing Radio. Showing artist and track when playing radio.
                      https://github.com/flopp999/MMM-Sonos
                        BD0G
                        Looks like I am missing settings.json under /home/pi/node-sonos-http-api. I went to magicmirrors IP address:5005/zones and saw the output from my sonos one time , but then on reboot I can no longer get the output to show up by visiting the above specified URL . I think it may be a result of this missing settings.json file.
                        • StoffbeuteluweS Offline
                          Stoffbeuteluwe Project Sponsor @flopp
                          @flopp when I play Apple Music from my Sonos, is no artwork showing, anybody same problem
                            BD0G @cohron
                            @cohron OK , Im getting somewhere. When I visit http://192.168.1.5:5005/zones after installing sonos-http-api and then doing npm install --production and then npm start. I do see a webpage of output information from my sonos device.
                            However, when I run my sonos.sh file after creating it like this
                            cd ~
                            pm2 start sonos.sh
                            pm2 start mm
                            pm2 save
                            It does start sonos as noted here
                            │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                            │ 0 │ MagicMirror │ fork │ 2 │ stopped │ 0% │ 0b │
                            │ 1 │ sonos │ fork │ 212 │ online │ 0% │ 2.4mb │
                            Then if I visit the same address (http://192.168.1.5:5005/zones) to see if there is still output . There is not!
                            I realize that the Magic Mirror is not started as I stopped it as I just wanted to see if there was still output on http://192.168.1.5:5005/zones
                            Sonos is playing when I visit http://192.168.1.5:5005/zones so there should be data being output.
                              BD0G
                              I finally solved this. Turned out I left out the tilde (~) in front of the /node-sonos-http-api within the sonos.sh file. So in essence the directory was never switched to execute the npm start command. So even though my PM2 status of running processes showed Sonos as a running process it was not providing the output data so that the module could display it
                                BD0G
                                Any way to remove the Source: specifier?
                                I tried
                                showSource:False,
                                within the config.js to no avail.
                                  BD0G
                                  I added the code to my custom.css file that was entered within one of the first posts and expected it to provide a new layout and look , but nothing changed?
                                  Its as if the entries in the custom.css are not being recognized.
                                  Do I need to add .MMM-Sonos right above the entires?
                                  Update: Tried that and still no effect.
                                  • G Offline
                                    gekberlin
                                    Hi @Snille,
                                    i tried to achieve to display the different zones side by side. Unfortunately I didn’t find a correct box to float. Could you give me a hint ?
                                    Happy new Year in advance from Berlin
                                    • cowboysdudeC Offline
                                      VERY late to the party but Thank you so much for this…works like a charm!!!
                                        msulzer @cowboysdude
                                        I started my magic mirror project recently and I am struggling to customize the module as follows:
                                        Module on the Left side of the Mirror:
                                        Could somebody please be so kind and share the changes I need to make.
