    MMM-Sonos - To show what your SONOS is playing.
    29 Posts 17 Posters 30.7k Views 16 Watching
    • F
      flopp @flopp
      @flopp said in MMM-Sonos - To show what your SONOS is playing.:
      When I play TV sound on my Beam it will show up in Magic Mirror even if that it seems to be that is should hide
                      // if Sonos Playbar is in TV mode, no title is provided and therefore the room should not be displayed
                      var isEmpty = (artist && artist.trim().length) == 0
                              && (track && track.trim().length) == 0
                              && (cover && cover.trim().length) == 0;
      I now have forked this and correct the problem and also done some small changes. Added radio station name when playing Radio. Showing artist and track when playing radio.
      https://github.com/flopp999/MMM-Sonos
        BD0G
        Looks like I am missing settings.json under /home/pi/node-sonos-http-api. I went to magicmirrors IP address:5005/zones and saw the output from my sonos one time , but then on reboot I can no longer get the output to show up by visiting the above specified URL . I think it may be a result of this missing settings.json file.
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @flopp
          @flopp when I play Apple Music from my Sonos, is no artwork showing, anybody same problem
            BD0G @cohron
            @cohron OK , Im getting somewhere. When I visit http://192.168.1.5:5005/zones after installing sonos-http-api and then doing npm install --production and then npm start. I do see a webpage of output information from my sonos device.
            However, when I run my sonos.sh file after creating it like this
            create another pm2 script named sonos.sh in ~ directory
            cd ~
            sonos.sh file contents:
            cd ~/node-sonos-http-api
            DISPLAY=:0 npm start
            pm2 start sonos.sh
            pm2 start mm
            pm2 save
            It does start sonos as noted here
            │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
            │ 0 │ MagicMirror │ fork │ 2 │ stopped │ 0% │ 0b │
            │ 1 │ sonos │ fork │ 212 │ online │ 0% │ 2.4mb │
            Then if I visit the same address (http://192.168.1.5:5005/zones) to see if there is still output . There is not!
            I realize that the Magic Mirror is not started as I stopped it as I just wanted to see if there was still output on http://192.168.1.5:5005/zones
            Sonos is playing when I visit http://192.168.1.5:5005/zones so there should be data being output.
              BD0G
              I finally solved this. Turned out I left out the tilde (~) in front of the /node-sonos-http-api within the sonos.sh file. So in essence the directory was never switched to execute the npm start command. So even though my PM2 status of running processes showed Sonos as a running process it was not providing the output data so that the module could display it
                BD0G
                Any way to remove the Source: specifier?
                I tried
                showSource:False,
                within the config.js to no avail.
                  BD0G
                  I added the code to my custom.css file that was entered within one of the first posts and expected it to provide a new layout and look , but nothing changed?
                  Its as if the entries in the custom.css are not being recognized.
                  Do I need to add .MMM-Sonos right above the entires?
                  Update: Tried that and still no effect.
                  • G
                    gekberlin
                    Hi @Snille,
                    i tried to achieve to display the different zones side by side. Unfortunately I didn’t find a correct box to float. Could you give me a hint ?
                    Happy new Year in advance from Berlin
                    • cowboysdudeC
                      VERY late to the party but Thank you so much for this…works like a charm!!!
                        msulzer @cowboysdude
                        I started my magic mirror project recently and I am struggling to customize the module as follows:
                        Module on the Left side of the Mirror:
                        Could somebody please be so kind and share the changes I need to make.
