    MMM-Sonos - To show what your SONOS is playing.
    29 Posts 17 Posters 31.0k Views 16 Watching
      SuperSchenk
      Thank you for your work @Snille! Got it working on my mirror yesterday. Works great!
        Damian @cohron
        @cohron
        @Snille
        Can you please explian how and where to create the sonos.sh file?
        And how to then add the rest into that file?
        I’m having trouble understanding what you mean by placing a script in ~ directory…
        And the next part cd~sonos.sh file contents:
        create another pm2 script named sonos.sh in ~ directory
        cd ~
        cd ~/node-sonos-http-api
        DISPLAY=:0 npm start
        pm2 start sonos.sh
        pm2 start mm
        pm2 save
        D 1 Reply Last reply
          Damian @Damian
          @Damian said in MMM-Sonos - To show what your SONOS is playing.:
          cd ~
          pm2 start sonos.sh
          pm2 start mm
          pm2 save
          Okay, so I opened up my directory… created a new file in /home/pi and named it sonos.sh… going by the jumbled up way things have been written in the example above, I have tried every combination to try and make sense of what it is saying to type into terminal
          cd ~ sonos.sh file contents
          sonos.sh
          I will no doubt be going around in circles here trying to decypher the instructions, so can I ask anyone to please decypher this for me and tell me what and where to enter these? do I manually input them into the sonos.sh file? do I get terminal to enter them?
          I a
          l already set up PM2 over a year ago to autostart MM, and sure it was never as hard as this?
          this is what I get when trying
          pi@raspi:~ $ cd ~sonos.sh
          bash: cd: ~sonos.sh: No such file or directory
          pi@raspi:~ $ sonos.sh
          bash: sonos.sh: command not found
          pi@raspi:~ $ sonos.sh file contents:
          pi@raspi:~ $ cd ~/node-sonos-http-api
          pi@raspi:~/node-sonos-http-api $ DISPLAY=:0 npm start
          > sonos-http-api@1.6.0 start /home/pi/node-sonos-http-api
          > node server.js
          2018-04-16T11:21:47.702Z INFO Could not find file /home/pi/node-sonos-http-api/settings.json
          2018-04-16T11:21:48.670Z INFO Presets loaded: { example:
             { players:
                [ { roomName: 'Bathroom', volume: 10 },
                  { roomName: 'Kitchen', volume: 10 },
                  { roomName: 'Office', volume: 10 },
                  { roomName: 'Bedroom', volume: 10 },
                  { roomName: 'TV Room', volume: 15 } ],
               playMode: { shuffle: true, repeat: 'all', crossfade: false },
               pauseOthers: false } }
          2018-04-16T11:21:54.317Z ERROR Port 5005 seems to be in use already. Make sure the sonos-http-api isn't
              already running, or that no other server uses that port. You can specify an alternative http port
              with property "port" in settings.json
          npm ERR! Linux 4.9.35-v7+
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
          npm ERR! node v6.14.1
          npm ERR! npm  v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! sonos-http-api@1.6.0 start: `node server.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the sonos-http-api@1.6.0 start script 'node server.js'.
          npm ERR! If you do, this is most likely a problem with the sonos-http-api package,
          npm ERR! not with npm itself.
          npm ERR!     node server.js
          npm ERR!     npm bugs sonos-http-api
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls sonos-http-api
          npm ERR!     /home/pi/node-sonos-http-api/npm-debug.log
          pi@papaspi:~/node-sonos-http-api $ pm2 start sonos.sh
          [PM2][ERROR] script not found : /home/pi/node-sonos-http-api/sonos.sh
          │ Name │ mode │ status │ ↺ │ cpu │ memory │
          │ mm   │ fork │ online │ 0 │ 0%  │ 0 B    │
           Use `pm2 show ` to get more details about an app
            Damian @Damian
            @Mods
            Appreciate I have posted this twice in 2 seperate posts - but this one is FAO the Developer in his original post of 1 year ago, and to the poster who replied with his fix.
            The other post goes to anyone here who can help me with making and executing a script, going by the example given for this module.
            • F
              flopp
              When I play TV sound on my Beam it will show up in Magic Mirror even if that it seems to be that is should hide
                              // if Sonos Playbar is in TV mode, no title is provided and therefore the room should not be displayed
                              var isEmpty = (artist && artist.trim().length) == 0
                                      && (track && track.trim().length) == 0
                                      && (cover && cover.trim().length) == 0;
              F 1 Reply Last reply
              • F
                flopp @flopp
                @flopp said in MMM-Sonos - To show what your SONOS is playing.:
                I now have forked this and correct the problem and also done some small changes. Added radio station name when playing Radio. Showing artist and track when playing radio.
                https://github.com/flopp999/MMM-Sonos
                StoffbeuteluweS 1 Reply Last reply
                  BD0G
                  Looks like I am missing settings.json under /home/pi/node-sonos-http-api. I went to magicmirrors IP address:5005/zones and saw the output from my sonos one time , but then on reboot I can no longer get the output to show up by visiting the above specified URL . I think it may be a result of this missing settings.json file.
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor @flopp
                    @flopp when I play Apple Music from my Sonos, is no artwork showing, anybody same problem
                      BD0G @cohron
                      @cohron OK , Im getting somewhere. When I visit http://192.168.1.5:5005/zones after installing sonos-http-api and then doing npm install --production and then npm start. I do see a webpage of output information from my sonos device.
                      However, when I run my sonos.sh file after creating it like this
                      cd ~
                      pm2 start sonos.sh
                      pm2 start mm
                      pm2 save
                      It does start sonos as noted here
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 0 │ MagicMirror │ fork │ 2 │ stopped │ 0% │ 0b │
                      │ 1 │ sonos │ fork │ 212 │ online │ 0% │ 2.4mb │
                      Then if I visit the same address (http://192.168.1.5:5005/zones) to see if there is still output . There is not!
                      I realize that the Magic Mirror is not started as I stopped it as I just wanted to see if there was still output on http://192.168.1.5:5005/zones
                      Sonos is playing when I visit http://192.168.1.5:5005/zones so there should be data being output.
                        BD0G
                        I finally solved this. Turned out I left out the tilde (~) in front of the /node-sonos-http-api within the sonos.sh file. So in essence the directory was never switched to execute the npm start command. So even though my PM2 status of running processes showed Sonos as a running process it was not providing the output data so that the module could display it
                          BD0G
                          Any way to remove the Source: specifier?
                          I tried
                          showSource:False,
                          within the config.js to no avail.
                            BD0G
                            I added the code to my custom.css file that was entered within one of the first posts and expected it to provide a new layout and look , but nothing changed?
                            Its as if the entries in the custom.css are not being recognized.
                            Do I need to add .MMM-Sonos right above the entires?
                            Update: Tried that and still no effect.
                            • G
                              gekberlin
                              Hi @Snille,
                              i tried to achieve to display the different zones side by side. Unfortunately I didn’t find a correct box to float. Could you give me a hint ?
                              Happy new Year in advance from Berlin
                              • cowboysdudeC
                                VERY late to the party but Thank you so much for this…works like a charm!!!
                                M 1 Reply Last reply
                                  msulzer @cowboysdude
                                  I started my magic mirror project recently and I am struggling to customize the module as follows:
                                  Module on the Left side of the Mirror:
                                  Could somebody please be so kind and share the changes I need to make.
